Merci pour l’ajout du module RWL022 dans la stable de ce jour.
Cependant uniquement le bouton du haut est fonctionnel.
Je vous joins le log zigbee avec appui successif sur les 4 boutons.
Pour les modos : désolé, dans plugin - protocole domotique, le tag plug-zigbee n’est pas présent dans la liste ! je vois amélioration, bug, plugin-alexaapi, plugin-deconz, … zwave mais pas plugin-zigbee. On fait comment ?
[2021-05-03 15:23:28][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"cmd":{"0":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1":{"value":"1","cluster_name":"PhilipsRemoteCluster"},"1.1":{"value":"3145728","cluster_name":"PhilipsRemoteCluster"},"1.2":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.3":{"value":"33","cluster_name":"PhilipsRemoteCluster"},"1.4":{"value":"1","cluster_name":"PhilipsRemoteCluster"},"1.5":{"value":"0","cluster_name":"PhilipsRemoteCluster"}},"event":{"on_short_release":{"value":{"button":"on","press_type":"short_release","command_id":0,"args":[1,3145728,2,33,1,0]},"cluster_name":"PhilipsRemoteCluster"}}}}}}}
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::0 => 0
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1 => 1
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.1 => 3145728
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.2 => 2
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.3 => 33
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.4 => 1
[2021-05-03 15:23:28][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.5 => 0
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_short_release::button => on
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_short_release::press_type => short_release
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_short_release::command_id => 1
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_short_release::args => Array
[2021-05-03 15:23:28][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"event":{"on_press":{"value":{"button":"on","press_type":"press","command_id":0,"args":[1,3145728,0,33,0,0]},"cluster_name":"PhilipsRemoteCluster"}}}}}}}
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_press::button => on
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_press::press_type => press
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_press::command_id => 1
[2021-05-03 15:23:28][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::on_press::args => Array
[2021-05-03 15:23:29][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"6":{"cmd":[{"value":"1","cluster_name":"On\/Off"},{"value":"[]","cluster_name":"On\/Off"}]}}}}}
[2021-05-03 15:23:29][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::6::cmd::0 => 1
[2021-05-03 15:23:30][DEBUG] : {"devices":{"04:cf:8c:df:3c:7f:1e:e6":{"1":{"1024":[{"value":"21523","cluster_name":"Illuminance Measurement"}]}}}}
[2021-05-03 15:23:30][DEBUG] : Search attribut for 04:cf:8c:df:3c:7f:1e:e6 logicalId : 1::1024::0 => 21523
[2021-05-03 15:23:31][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"cmd":{"0":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.1":{"value":"3145728","cluster_name":"PhilipsRemoteCluster"},"1.2":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1.3":{"value":"33","cluster_name":"PhilipsRemoteCluster"},"1.4":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1.5":{"value":"0","cluster_name":"PhilipsRemoteCluster"}}},"8":{"cmd":{"0":{"value":"2","cluster_name":"Level control"},"1":{"value":"0","cluster_name":"Level control"},"1.1":{"value":"30","cluster_name":"Level control"},"1.2":{"value":"9","cluster_name":"Level control"}}}}}}}
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::0 => 0
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1 => 2
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.1 => 3145728
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.2 => 0
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.3 => 33
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.4 => 0
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.5 => 0
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::0 => 2
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::1 => 0
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::1.1 => 30
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::1.2 => 9
[2021-05-03 15:23:31][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"event":{"up_short_release":{"value":{"button":"up","press_type":"short_release","command_id":0,"args":[2,3145728,2,33,2,0]},"cluster_name":"PhilipsRemoteCluster"}},"cmd":{"0":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.1":{"value":"3145728","cluster_name":"PhilipsRemoteCluster"},"1.2":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.3":{"value":"33","cluster_name":"PhilipsRemoteCluster"},"1.4":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.5":{"value":"0","cluster_name":"PhilipsRemoteCluster"}}}}}}}
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_short_release::button => up
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_short_release::press_type => short_release
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_short_release::command_id => 1
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_short_release::args => Array
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.2 => 2
[2021-05-03 15:23:31][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.4 => 2
[2021-05-03 15:23:31][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"event":{"up_press":{"value":{"button":"up","press_type":"press","command_id":0,"args":[2,3145728,0,33,0,0]},"cluster_name":"PhilipsRemoteCluster"}}}}}}}
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_press::button => up
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_press::press_type => press
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_press::command_id => 1
[2021-05-03 15:23:31][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::up_press::args => Array
[2021-05-03 15:23:32][DEBUG] : {"devices":{"84:2e:14:ff:fe:03:43:aa":{"1":{"768":{"8":{"value":"enum8.undefined_0x02","cluster_name":"Color Control"},"color":{"value":"#fbff00","cluster_name":"Color Control"},"7":{"value":"454","cluster_name":"Color Control"}}}}}}
[2021-05-03 15:23:32][DEBUG] : Search attribut for 84:2e:14:ff:fe:03:43:aa logicalId : 1::768::8 => enum8.undefined_0x02
[2021-05-03 15:23:32][DEBUG] : Search attribut for 84:2e:14:ff:fe:03:43:aa logicalId : 1::768::color => #fbff00
[2021-05-03 15:23:32][DEBUG] : Search attribut for 84:2e:14:ff:fe:03:43:aa logicalId : 1::768::7 => 454
[2021-05-03 15:23:33][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"cmd":{"0":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1":{"value":"3","cluster_name":"PhilipsRemoteCluster"},"1.1":{"value":"3145728","cluster_name":"PhilipsRemoteCluster"},"1.2":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.3":{"value":"33","cluster_name":"PhilipsRemoteCluster"},"1.4":{"value":"1","cluster_name":"PhilipsRemoteCluster"},"1.5":{"value":"0","cluster_name":"PhilipsRemoteCluster"}},"event":{"down_short_release":{"value":{"button":"down","press_type":"short_release","command_id":0,"args":[3,3145728,2,33,1,0]},"cluster_name":"PhilipsRemoteCluster"}}},"8":{"cmd":{"0":{"value":"2","cluster_name":"Level control"},"1":{"value":"1","cluster_name":"Level control"},"1.1":{"value":"30","cluster_name":"Level control"},"1.2":{"value":"9","cluster_name":"Level control"}}}}}}}
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::0 => 0
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1 => 3
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.1 => 3145728
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.2 => 2
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.3 => 33
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.4 => 1
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.5 => 0
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_short_release::button => down
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_short_release::press_type => short_release
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_short_release::command_id => 1
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_short_release::args => Array
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::0 => 2
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::1 => 1
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::1.1 => 30
[2021-05-03 15:23:33][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::8::cmd::1.2 => 9
[2021-05-03 15:23:33][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"event":{"down_press":{"value":{"button":"down","press_type":"press","command_id":0,"args":[3,3145728,0,33,0,0]},"cluster_name":"PhilipsRemoteCluster"}}}}}}}
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_press::button => down
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_press::press_type => press
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_press::command_id => 1
[2021-05-03 15:23:33][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::down_press::args => Array
[2021-05-03 15:23:35][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"cmd":{"0":{"value":"0","cluster_name":"PhilipsRemoteCluster"},"1":{"value":"4","cluster_name":"PhilipsRemoteCluster"},"1.1":{"value":"3145728","cluster_name":"PhilipsRemoteCluster"},"1.2":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.3":{"value":"33","cluster_name":"PhilipsRemoteCluster"},"1.4":{"value":"2","cluster_name":"PhilipsRemoteCluster"},"1.5":{"value":"0","cluster_name":"PhilipsRemoteCluster"}},"event":{"off_short_release":{"value":{"button":"off","press_type":"short_release","command_id":0,"args":[4,3145728,2,33,2,0]},"cluster_name":"PhilipsRemoteCluster"}}},"5":{"cmd":{"5":{"value":348261,"cluster_name":"Scenes"}}}}}}}
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::0 => 0
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1 => 4
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.1 => 3145728
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.2 => 2
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.3 => 33
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.4 => 2
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::cmd::1.5 => 0
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_short_release::button => off
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_short_release::press_type => short_release
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_short_release::command_id => 1
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_short_release::args => Array
[2021-05-03 15:23:35][DEBUG] : Search command for 00:17:88:01:09:27:c6:15 logicalId : 1::5::cmd::5 => 348261
[2021-05-03 15:23:35][DEBUG] : {"devices":{"00:17:88:01:09:27:c6:15":{"1":{"64512":{"event":{"off_press":{"value":{"button":"off","press_type":"press","command_id":0,"args":[4,3145728,0,33,0,0]},"cluster_name":"PhilipsRemoteCluster"}}}}}}}
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_press::button => off
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_press::press_type => press
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_press::command_id => 1
[2021-05-03 15:23:35][DEBUG] : Search event command for 00:17:88:01:09:27:c6:15 logicalId : 1::64512::event::off_press::args => Array
