@Loic
Voici les informations pour une serrure Xiaomi (Vima) en Zigbee que j’ai inclus avec une Zigate wifi en v3.1d. La serrure possède 5 clés à puce, donc j’ai récupéré le DEBUG pour chaque clé insérée dans la serrure.
Je sais pas si ça pourra être intégré dans le plugin, mais au cas où…
« model »: « lumi.lock.v1 »
Informations brutes:
"ieee": "00:15:8d:00:02:9a:7f:1b",
"nwk": 52554,
"status": 2,
"lqi": "36",
"rssi": "0",
"last_seen": "1610802713.0869913",
"node_descriptor": "01:40:84:37:10:7f:64:00:01:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 10,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.lock.v1",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 0
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 37
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.lock.v1"
"id": 6,
"name": "date_code",
"value": "04-03-2018"
"id": 7,
"name": "power_source",
"value": 3
"id": 3,
"name": "Identify",
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 2,
"name": "Device Temperature",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 132,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 1,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 10,
"input_clusters": [
0,
3,
1,
2,
25,
10
25,
10
"class": "zigpy.device"
Clé numéro 1
[2021-01-16 14:09:22][DEBUG] : Frame received: 8002001e460001040000010102cd4a0200001c5f11140a30ff27ffffffffff02011212
[2021-01-16 14:09:22][DEBUG] : data received 0x8002 b'0001040000010102cd4a0200001c5f11140a30ff27ffffffffff020112' LQI:18
[2021-01-16 14:09:22][DEBUG] : zigate_callback_handler [0, 260, 0, 1, 1, <Address address_mode=ADDRESS_MODE.NWK address=0xcd4a>, <Address address_mode=ADDRESS_MODE.NWK address=0x0000>, b"\x1c_\x11\x14
0\xff'\xff\xff\xff\xff\xff\x02\x01\x12"]
[2021-01-16 14:09:22][DEBUG] : [0xcd4a:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=True disable_default_response=True> manufacturer=4447 tsn=20 command_id=Command.Report_Attributes>
[2021-01-16 14:09:22][DEBUG] : [0xcd4a:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297321466194296831>)]]
[2021-01-16 14:09:22][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.general_command] Cluster: <zigpy.zcl.clusters.general.Basic object at 0xffff7c6e6c88> ClusterId: 0x0000 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=False disable_default_response=True> manufacturer=4447 tsn=20 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297321466194296831>)]],)
[2021-01-16 14:09:22][DEBUG] : [0xcd4a:1:0x0000] Attribute report received: 65328=1297321466194296831
[2021-01-16 14:09:22][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.attribute_updated] Received an attribute update 65328=1297321466194296831 on cluster 0
[2021-01-16 14:09:22][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff7d7a9d50>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (00:15:8d:00:02:9a:7f:1b, 1, 0, 65328, 1297321466194296831))
[2021-01-16 14:09:22][DEBUG] : returning <sqlite3.Cursor object at 0xffff7d7b59d0>
[2021-01-16 14:09:22][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0xffff7d7a9d50>)
[2021-01-16 14:09:22][DEBUG] : returning None
[2021-01-16 14:09:22][DEBUG] : Send to jeedom : {'devices': {'00:15:8d:00:02:9a:7f:1b': {'1': {'0': {'65328': {'value': '1297321466194296831', 'cluster_name': 'Basic'}}}}}}
Clé numéro 2
[2021-01-16 14:10:09][DEBUG] : Frame received: 8002001e4d0001040000010102cd4a0200001c5f11150a30ff27ffffffffff0401121e
[2021-01-16 14:10:09][DEBUG] : data received 0x8002 b'0001040000010102cd4a0200001c5f11150a30ff27ffffffffff040112' LQI:30
[2021-01-16 14:10:09][DEBUG] : zigate_callback_handler [0, 260, 0, 1, 1, <Address address_mode=ADDRESS_MODE.NWK address=0xcd4a>, <Address address_mode=ADDRESS_MODE.NWK address=0x0000>, b"\x1c_\x11\x15
0\xff'\xff\xff\xff\xff\xff\x04\x01\x12"]
[2021-01-16 14:10:09][DEBUG] : [0xcd4a:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=True disable_default_response=True> manufacturer=4447 tsn=21 command_id=Command.Report_Attributes>
[2021-01-16 14:10:09][DEBUG] : [0xcd4a:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297323665217552383>)]]
[2021-01-16 14:10:09][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.general_command] Cluster: <zigpy.zcl.clusters.general.Basic object at 0xffff7c6e6c88> ClusterId: 0x0000 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=False disable_default_response=True> manufacturer=4447 tsn=21 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297323665217552383>)]],)
[2021-01-16 14:10:09][DEBUG] : [0xcd4a:1:0x0000] Attribute report received: 65328=1297323665217552383
[2021-01-16 14:10:09][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.attribute_updated] Received an attribute update 65328=1297323665217552383 on cluster 0
[2021-01-16 14:10:09][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff7d7a9d50>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (00:15:8d:00:02:9a:7f:1b, 1, 0, 65328, 1297323665217552383))
[2021-01-16 14:10:09][DEBUG] : returning <sqlite3.Cursor object at 0xffff7d7b59d0>
[2021-01-16 14:10:09][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0xffff7d7a9d50>)
[2021-01-16 14:10:09][DEBUG] : returning None
[2021-01-16 14:10:09][DEBUG] : Send to jeedom : {'devices': {'00:15:8d:00:02:9a:7f:1b': {'1': {'0': {'65328': {'value': '1297323665217552383', 'cluster_name': 'Basic'}}}}}}
Clé numéro 3
[2021-01-16 14:10:42][DEBUG] : Frame received: 8002001e7e0001040000010102cd4a0200001c5f11170a30ff27ffffffffff0101122a
[2021-01-16 14:10:42][DEBUG] : data received 0x8002 b'0001040000010102cd4a0200001c5f11170a30ff27ffffffffff010112' LQI:42
[2021-01-16 14:10:42][DEBUG] : zigate_callback_handler [0, 260, 0, 1, 1, <Address address_mode=ADDRESS_MODE.NWK address=0xcd4a>, <Address address_mode=ADDRESS_MODE.NWK address=0x0000>, b"\x1c_\x11\x17
0\xff'\xff\xff\xff\xff\xff\x01\x01\x12"]
[2021-01-16 14:10:42][DEBUG] : [0xcd4a:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=True disable_default_response=True> manufacturer=4447 tsn=23 command_id=Command.Report_Attributes>
[2021-01-16 14:10:42][DEBUG] : [0xcd4a:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297320366682669055>)]]
[2021-01-16 14:10:42][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.general_command] Cluster: <zigpy.zcl.clusters.general.Basic object at 0xffff7c6e6c88> ClusterId: 0x0000 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=False disable_default_response=True> manufacturer=4447 tsn=23 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297320366682669055>)]],)
[2021-01-16 14:10:42][DEBUG] : [0xcd4a:1:0x0000] Attribute report received: 65328=1297320366682669055
[2021-01-16 14:10:42][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.attribute_updated] Received an attribute update 65328=1297320366682669055 on cluster 0
[2021-01-16 14:10:42][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff7d7a9d50>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (00:15:8d:00:02:9a:7f:1b, 1, 0, 65328, 1297320366682669055))
[2021-01-16 14:10:42][DEBUG] : returning <sqlite3.Cursor object at 0xffff7d7b59d0>
[2021-01-16 14:10:42][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0xffff7d7a9d50>)
[2021-01-16 14:10:42][DEBUG] : returning None
[2021-01-16 14:10:42][DEBUG] : Send to jeedom : {'devices': {'00:15:8d:00:02:9a:7f:1b': {'1': {'0': {'65328': {'value': '1297320366682669055', 'cluster_name': 'Basic'}}}}}}
Clé numéro 4
[2021-01-16 14:11:31][DEBUG] : Frame received: 8002001e480001040000010102cd4a0200001c5f111a0a30ff27ffffffffff05011215
[2021-01-16 14:11:31][DEBUG] : data received 0x8002 b'0001040000010102cd4a0200001c5f111a0a30ff27ffffffffff050112' LQI:21
[2021-01-16 14:11:31][DEBUG] : zigate_callback_handler [0, 260, 0, 1, 1, <Address address_mode=ADDRESS_MODE.NWK address=0xcd4a>, <Address address_mode=ADDRESS_MODE.NWK address=0x0000>, b"\x1c_\x11\x1a
0\xff'\xff\xff\xff\xff\xff\x05\x01\x12"]
[2021-01-16 14:11:31][DEBUG] : [0xcd4a:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=True disable_default_response=True> manufacturer=4447 tsn=26 command_id=Command.Report_Attributes>
[2021-01-16 14:11:31][DEBUG] : [0xcd4a:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297324764729180159>)]]
[2021-01-16 14:11:31][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.general_command] Cluster: <zigpy.zcl.clusters.general.Basic object at 0xffff7c6e6c88> ClusterId: 0x0000 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=False disable_default_response=True> manufacturer=4447 tsn=26 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=65328, value=<TypeValue type=uint64_t, value=1297324764729180159>)]],)
[2021-01-16 14:11:31][DEBUG] : [0xcd4a:1:0x0000] Attribute report received: 65328=1297324764729180159
[2021-01-16 14:11:31][INFO] : [00:15:8d:00:02:9a:7f:1b][listener.attribute_updated] Received an attribute update 65328=1297324764729180159 on cluster 0
[2021-01-16 14:11:31][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff7d7a9d50>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (00:15:8d:00:02:9a:7f:1b, 1, 0, 65328, 1297324764729180159))
[2021-01-16 14:11:31][DEBUG] : returning <sqlite3.Cursor object at 0xffff7d7b5b20>
[2021-01-16 14:11:31][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0xffff7d7a9d50>)
[2021-01-16 14:11:31][DEBUG] : returning None
[2021-01-16 14:11:31][DEBUG] : Send to jeedom : {'devices': {'00:15:8d:00:02:9a:7f:1b': {'1': {'0': {'65328': {'value': '1297324764729180159', 'cluster_name': 'Basic'}}}}}}
