Plugin Zigbee - Ajout interrupteur Tuya simple
J’essaie de comprendre comment ajouter manuellement les commandes à un interrupteur Zigbee que j’ai reçu récemment.
Quand je l’ai ajouté sur le plugin Zigbee, je ne vois pas clairement les id qu’il faut mettre pour avoir l’état et le On/Off contrairement à d’autres équipements qui sont clairs dans leur configuration.
Voici ce que j’ai déjà dans la configuration de l’appareil:
    "ieee": "60:a4:23:ff:fe:aa:f7:37",
    "nwk": 47606,
    "status": 2,
    "lqi": "203",
    "rssi": "-47",
    "last_seen": "1621415113.5589159",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZE200_amp6tsvy",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 66
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_amp6tsvy"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    0,
                    4,
                    5,
                    61184
                    25,
                    10
    "class": "zigpy.device"
Ensuite, quand je mets le plugin en debug et que je fais des clic sur le bouton, j’ai bien jeedom qui recois des cmd. Les voici:
[2021-05-19 11:04:01][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"57","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 57
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 15
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 4
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 2
[2021-05-19 11:04:01][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"58","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 58
[2021-05-19 11:04:01][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:02][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:02][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:02][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:03][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 14
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 4
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:03][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"60","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 60
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 15
[2021-05-19 11:04:03][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 2
[2021-05-19 11:04:04][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"61","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"1","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 61
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:04][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 1
[2021-05-19 11:04:05][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"62","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 62
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 14
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 4
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:05][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:06][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"63","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 63
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 15
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 4
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:06][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 2
[2021-05-19 11:04:51][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:51][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:51][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:51][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:52][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:52][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:53][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:53][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:54][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:54][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:55][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:55][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:56][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:56][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:57][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"59","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::0 => 1
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1 => 0
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 59
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 1
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 1
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.4 => 0
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.5 => 1
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.6 => 0
[2021-05-19 11:04:57][DEBUG] : {"devices":{"60:a4:23:ff:fe:aa:f7:37":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"60","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.1 => 60
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.2 => 14
[2021-05-19 11:04:57][DEBUG] : Search command for 60:a4:23:ff:fe:aa:f7:37 logicalId : 1::61184::cmd::1.3 => 4
On peut donc constater qu’il y a des id cachées dans l’id 1::61184 qui est pourtant vide dans la configuration.
l’id 1 reste toujours à 0, l’id 0 toujours à 1. l’id 1.1 c’est le nombre total de clic depuis le début car à chaque clic ca monte de 1. pour les 5 autres id ensuite, ca revient toujours au bout d’un moment sur 4 / 0 / 1 / 2 quel que soit l’état de l’interrupteur.
je n’arrive donc pas à récupérer l’id de l’état et encore moins les commandes On/Off.
Pourriez vous m’aider?
Je ne pense pas qu’il puisse etre compatible lui d’après la log…
Après avoir fouillé sur d’autres appareils compatible, je pense en effet que celui-là ne propose pas dans sa config les id qu’il faut pour le contrôler. C’est dommage.
Quel interrupteur Zigbee filaire avec arrière rond pour rentrer dans les boîtiers EU conseillez vous et permettant de faire On/Off et retour d’état marchant avec le plugin Zigbee?
Bonjour Héraclès44,
Au vu de la date de ton message j’espère qu’il n’est pas trop tard, j’ai commandé exactement le même interrupteur que toi. C’est un interrupteur simple j’ai utilisé dans la rubrique Tuya TZE200 TS601 MOES - Module dimmer simple.
Pour l’instant il fonctionne bien sur ce modèle la bien évidemment je n’ utilise pas la partie dimmer juste la partie On Off et état.
J’ose espérer que nous avons suffisamment d’informations sur la marque MOES pour pouvoir développer l’équipement.
