Depuis peu, certainement l’issue d’une mise à jour j’ai perdu les fonctionnalités du plugin TahomaLocal.
Après divers essais, je me trouve dans la situation ou je ne peux plus installer mes dépendances, avec un message d’erreur :
et le log suivant :
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_TaHomaLocal
0003|+ echo 1
0004|+ echo 2
0005|+ sudo killall apt apt-get unattended-upgr
0006|apt: no process found
0007|apt-get: no process found
0008|unattended-upgr: no process found
0009|+ sudo rm /var/lib/apt/lists/lock
0010|+ sudo rm /var/cache/apt/archives/lock
0011|+ sudo rm /var/lib/dpkg/lock /var/lib/dpkg/lock-frontend
0012|+ sudo sudo dpkg --configure -a --force-confdef
0013|+ sudo apt update
0014|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0015|Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
0016|Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
0017|Hit:3 http://archive.raspberrypi.org/debian buster InRelease
0018|Reading package lists...
0019|Building dependency tree...
0020|Reading state information...
0021|All packages are up to date.
0022|+ echo 3
0023|+ sudo apt install -o Dpkg::Options::=--force-confdef -y avahi-daemon
0024|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0025|Reading package lists...
0026|Building dependency tree...
0027|Reading state information...
0028|avahi-daemon is already the newest version (0.7-4+deb10u3).
0029|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0030|+ echo 4
0031|+ sudo apt install -o Dpkg::Options::=--force-confdef -y avahi-utils
0032|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0033|Reading package lists...
0034|Building dependency tree...
0035|Reading state information...
0036|avahi-utils is already the newest version (0.7-4+deb10u3).
0037|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0038|+ echo 5
0039|+ sudo apt install -o Dpkg::Options::=--force-confdef -y curl
0040|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0041|Reading package lists...
0042|Building dependency tree...
0043|Reading state information...
0044|curl is already the newest version (7.64.0-4+deb10u9).
0045|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0046|+ echo 6
0047|+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
0048|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0049|Reading package lists...
0050|Building dependency tree...
0051|Reading state information...
0052|php-yaml is already the newest version (2.0.2+1.3.1-4+b1).
0053|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0054|+ echo 7
0055|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
0056|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0057|Reading package lists...
0058|Building dependency tree...
0059|Reading state information...
0060|python3-pyudev is already the newest version (0.21.0-1).
0061|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0062|+ echo 8
0063|+ sudo systemctl restart apache2
0064|Warning: The unit file, source configuration file or drop-ins of apache2.service changed on disk. Run 'systemctl daemon-reload' to reload units.
0065|+ echo 9
0066|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end TaHomaLocal
0067|+ echo 10
0068|+ rm /tmp/jeedom_install_in_progress_TaHomaLocal
0069|+ echo '*******************End of package installation******************'
0070|*******************End of package installation******************
J’avoue être un peu perdu !
Merci d’avance pour votre aide
Informations Jeedom
Core : 4.4.9 (V4-stable)
DNS Jeedom : non
Plugin : TaHomaLocal
Version : 2024-07-24 16:16:41 (stable)
Statut Démon : ne démarre plus !
Vous êtes encore sous debian buster = 10, c’est peut être la cause car il n’est plus maintenu par debian depuis le 1er juillet. De ce fait, les dépôts aussi.
Il faut penser à faire une nouvelle installatio ou figer votre jeedom en l’état.
Après bascule sur Debian 11,pas d’évolution, le problématiques sont identiques et j’ai même ajouté la perte de la maitrise du plugin Jeeduino et mes MCP23017.
Pourriez-vous passer en Log Debug sur le plugin TahomaLocal, relancer les dépendances et me renvoyer le Log TaHomaLocal_packages et les messages d’erreur si il y en a.
Pas de message d’erreur à l’installation des dépendances.
Le log :
0003|+ echo 1
0004|+ echo 2
0008|+ sudo rm /var/lib/apt/lists/lock
0009|+ sudo rm /var/cache/apt/archives/lock
0010|+ sudo rm /var/lib/dpkg/lock /var/lib/dpkg/lock-frontend
0011|+ sudo sudo dpkg --configure -a --force-confdef
0012|+ sudo apt update
0013|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0014|Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
0015|Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
0016|Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
0017|Reading package lists...
0018|Building dependency tree...
0019|Reading state information...
0020|All packages are up to date.
0021|+ echo 3
0022|+ sudo apt install -o Dpkg::Options::=--force-confdef -y avahi-daemon
0023|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0024|Reading package lists...
0025|Building dependency tree...
0026|Reading state information...
0027|avahi-daemon is already the newest version (0.8-5+deb11u2).
0028|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0029|+ echo 4
0030|+ sudo apt install -o Dpkg::Options::=--force-confdef -y avahi-utils
0031|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0032|Reading package lists...
0033|Building dependency tree...
0034|Reading state information...
0035|avahi-utils is already the newest version (0.8-5+deb11u2).
0036|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0037|+ echo 5
0038|+ sudo apt install -o Dpkg::Options::=--force-confdef -y curl
0039|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0040|Reading package lists...
0041|Building dependency tree...
0042|Reading state information...
0043|curl is already the newest version (7.74.0-1.3+deb11u12).
0044|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0045|+ echo 6
0046|+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
0047|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0048|Reading package lists...
0049|Building dependency tree...
0050|Reading state information...
0051|php-yaml is already the newest version (2.2.1+2.1.0+2.0.4+1.3.2-2).
0052|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0053|+ echo 7
0054|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
0055|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0056|Reading package lists...
0057|Building dependency tree...
0058|Reading state information...
0059|python3-pyudev is already the newest version (0.22.0-2).
0060|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0061|+ echo 8
0062|+ sudo systemctl restart apache2
0063|+ echo 9
0064|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end TaHomaLocal
0065|+ echo 10
0066|+ rm /tmp/jeedom_install_in_progress_TaHomaLocal
0067|+ echo '*******************End of package installation******************'
0068|*******************End of package installation******************`Texte préformaté`
Vous n’avez plus les messages d’erreur.
Le Log d’installation des dépendances est maintenant normal …
Donc nous sommes passés à un problème différent !
J’ignore pourquoi votre box Tahoma n’est pas découverte ?
Vous avez quel modèle de box Somfy ?
Si votre box n’est pas découverte, vous avez, avec le plugin, la possibilité de passer en Mode IP.
Vous devez saisir l’adresse IPv4 et le PIN de la box.
Après avoir résolu des problèmes sur un autre plugin (sur conseils de passionnés du forum !), je pensais que ça aurait pu débloquer ceux_là… mais non !
Le log TahomaLocal à l’installation des dépendances (qui ne dépasse jamais les 7%) :
+ echo 1
+ echo 2
+ sudo apt update
+ echo 3
+ echo 4
+ echo 5
+ echo 6
+ echo 7
+ echo 8
+ echo 9
+ echo 10
Il n’y aurait pas des packages qui ne se seraient pas bien mis à jour,qu’il faudrait que je fasse en ligne de commande en SSH (non prévue par jeedom pour debian 11 ? )
