Bonjour @akenad.
voici le résultat, toujours rien
pi@jeedom:/etc/usb_modeswitch.d $ ls
12d1:157d
pi@jeedom:/etc/usb_modeswitch.d $ cat 12d1:157d
# Huawei E3531
TargetVendor=0x12d1
TargetProduct=0x157d
MessageContent="55534243123456780000000000000011062000000100000000000000000000"
pi@jeedom:/etc/usb_modeswitch.d $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 001 Device 008: ID 12d1:157d Huawei Technologies Co., Ltd.
Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@jeedom:/etc/usb_modeswitch.d $ dmesg | grep USB
[ 0.400149] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.403566] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.403600] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.404191] hub 1-0:1.0: USB hub found
[ 0.404796] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.404833] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.405210] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.405243] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.405804] hub 2-0:1.0: USB hub found
[ 0.414751] usbhid: USB HID core driver
[ 0.768238] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.950876] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 0.950914] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.950941] usb 1-1: Product: USB2.0 Hub
[ 0.952625] hub 1-1:1.0: USB hub found
[ 1.288255] usb 1-1.4: new high-speed USB device number 3 using xhci_hcd
[ 1.420714] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[ 1.420772] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.420816] usb 1-1.4: Product: USB2.0 Hub
[ 1.423206] hub 1-1.4:1.0: USB hub found
[ 1.748233] usb 1-1.4.1: new full-speed USB device number 4 using xhci_hcd
[ 1.885281] usb 1-1.4.1: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 1.885321] usb 1-1.4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.338248] usb 1-1.4.4: new high-speed USB device number 6 using xhci_hcd
[ 3.469673] usb 1-1.4.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[ 3.469690] usb 1-1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 3.469703] usb 1-1.4.4: Product: USB 10/100/1000 LAN
[ 3.578816] usb 1-1.4.4: reset high-speed USB device number 6 using xhci_hcd
[ 4.386194] cdc_acm 1-1.4.1:1.0: ttyACM0: USB ACM device
[ 4.387325] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.798279] usb 1-1.4.3: new high-speed USB device number 7 using xhci_hcd
[ 5.930398] usb 1-1.4.3: New USB device found, idVendor=12d1, idProduct=157d, bcdDevice= 1.02
[ 5.930417] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.940389] usb-storage 1-1.4.3:1.0: USB Mass Storage device detected
[ 6.991257] usb-storage 1-1.4.3:2.2: USB Mass Storage device detected
[ 7.282751] usb 1-1.4.3: USB disconnect, device number 7
[ 12.438234] usb 1-1.4.3: new high-speed USB device number 8 using xhci_hcd
[ 12.570213] usb 1-1.4.3: New USB device found, idVendor=12d1, idProduct=157d, bcdDevice= 1.02
[ 12.570227] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 12.574666] usb-storage 1-1.4.3:1.0: USB Mass Storage device detected
Est que tu peux voir si mon fichier usb_modeswhich.conf est correct ?
pi@jeedom:/etc/usb_modeswitch.d $ cat /etc/usb_modeswitch.conf
# Configuration for the usb_modeswitch package, a mode switching tool for
# USB devices providing multiple states or modes
# Evaluated by the wrapper script /usr/sbin/usb_modeswitch_dispatcher
# To enable an option, set it to "1", "yes" or "true" (case doesn't matter)
# Everything else counts as "disable"
# Disable automatic mode switching globally (e.g. to access the original
# install storage)
DisableSwitching=0
# Disable check for MBIM module presence and configuration globally (to aid
# special embedded environments). Available as per-device parameter
# 'NoMBIMCheck'
DisableMBIMGlobal=0
# Enable logging (results in a extensive report file in /var/log, named
# "usb_modeswitch_<interface-name>" and probably others
EnableLogging=0
# Optional increase of "delay_use" for the usb-storage driver; there are hints
# that a recent kernel default change to 1 sec. may lead to problems, particu-
# larly with USB 3.0 ports. Set this to at least 3 (seconds) in that case.
# Does nothing if the current system value is same or higher
#SetStorageDelay=4
# If the configuration for your Huawei modem uses the standard switching method,
# you can globally set an alternative method here which provides a different mode:
# either plain serial PPP (for older modems) or NCM which integrates nicely
# with recent Linux distributions, possibly avoiding configuration through a
# modem built-in web page. All other modems are not affected.
# Available as per-device parameter 'AltHuaweiMode'
HuaweiAltModeGlobal=0
