Je ne sais pas s’il y a une page pour le support du plugin Rflink.
Je pense qu’il faut faire une correction pour le mettre à jour.
Voici le message d’erreur que j’obtiens :
Error: The module '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1065:18)
at Module.load (internal/modules/cjs/loader.js:879:32)
at Function.Module._load (internal/modules/cjs/loader.js:724:14)
at Module.require (internal/modules/cjs/loader.js:903:19)
at require (internal/modules/cjs/helpers.js:74:18)
at bindings (/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:112:48)
at Object.<anonymous> (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (internal/modules/cjs/loader.js:1015:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1035:10)
at Object.<anonymous> (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/index.js:14:22)
