Plugin Peugeotcars
Hello, mon plugin fonctionnait depuis pas mal de temps, et depuis lundi, j’ai fait une mise à jour du core et de qqs plugins (zwavejs), ça ne fonctionne plus.
Dans les logs, j’ai Erreur Login API PSA
Quand je refais la procédure pour avoir l’OTP, j’ai
Requested API level 33 is larger than maximum we have, returning API level 28 instead.
RES_TABLE_LIBRARY_TYPE chunk is not supported
400  - server_error : Internal Server Error
File "/var/www/html/plugins/peugeotcars/core/ajax/../../3rdparty/psa_jeedom_daemon/jeedom_otp.py", line 69, in
res = firstLaunchConfig(pkg_name, mail, password, country)
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psa/setup/app_decoder.py", line 94, in firstLaunchConfig
psacc.connect(client_email, client_password)
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 34, in connect
self.manager.init_with_user_credentials_realm(user, password, self.realm)
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psa/oauth.py", line 28, in init_with_user_credentials_realm
self._token_request(self._grant_password_request_realm(login, password, realm), True)
File "/usr/local/lib/python3.7/dist-packages/oauth2_client/credentials_manager.py", line 190, in _token_request
CredentialManager._handle_bad_response(response)
File "/usr/local/lib/python3.7/dist-packages/oauth2_client/credentials_manager.py", line 78, in _handle_bad_response
raise OAuthError(HTTPStatus(response.status_code), error.get('error'), error.get('error_description'))
oauth2_client.credentials_manager.OAuthError: 400  - server_error : Internal Server Error
y a-t-il un truc à mettre à jour?
puis-je aider?
Mulb
