Je pense que depuis la dernière maj du plugin j’ai le deamon ko:
== Error message :
Collecting paho-mqtt==1.6.1 (from -r /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/f8/dd/4b75dcba025f8647bc9862ac17299e0d7d12d3beadbf026d8c8d74215c12/paho-mqtt-1.6.1.tar.gz (99kB)
Collecting requests==2.27.1 (from -r /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt (line 2))
Downloading https://files.pythonhosted.org/packages/2d/61/08076519c80041bc0ffa1a8af0cbd3bf3e2b62af10435d269a9d0f40564d/requests-2.27.1-py2.py3-none-any.whl (63kB)
Collecting websocket-client==1.3.2 (from -r /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt (line 3))
Could not find a version that satisfies the requirement websocket-client==1.3.2 (from -r /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt (line 3)) (from versions: 0.3, 0.4, 0.4.1, 0.5.0a0, 0.5.0, 0.5.1, 0.6.0, 0.7.0, 0.8.0, 0.9.0, 0.10.0, 0.11.0, 0.12.0, 0.13.0, 0.14.0, 0.14.1, 0.15.0, 0.16.0a0, 0.16.0, 0.17.0, 0.18.0, 0.19.0, 0.20.0, 0.21.0, 0.22.0, 0.23.0, 0.24.0, 0.25.0, 0.26.0, 0.27.0, 0.28.0, 0.29.0, 0.30.0, 0.31.0, 0.32.0, 0.33.0, 0.34.0, 0.35.0, 0.36.0, 0.37.0, 0.39.0, 0.40.0, 0.42.0, 0.42.1, 0.43.0, 0.44.0, 0.45.0, 0.46.0, 0.47.0, 0.48.0, 0.49.0, 0.50.0, 0.51.0, 0.52.0, 0.53.0, 0.54.0, 0.55.0, 0.56.0, 0.57.0, 0.58.0, 0.59.0, 1.0.0, 1.0.1, 1.1.0, 1.1.1, 1.2.0, 1.2.1, 1.2.2, 1.2.3, 1.3.0, 1.3.1)
No matching distribution found for websocket-client==1.3.2 (from -r /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt (line 3))
mon réflexe:
root@Ubuntu-Jeedom:/home/jc# cat /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt
paho-mqtt==1.6.1
requests==2.27.1
root@Ubuntu-Jeedom:/home/jc# pip3 install websocket-client
Requirement already satisfied: websocket-client in /usr/local/lib/python3.6/dist-packages
root@Ubuntu-Jeedom:/home/jc# pip install websocket-client
Requirement already satisfied: websocket-client in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from websocket-client)
alors oui je suis sur ubuntu et pas debian :-/. si quelqu’un as une idée
merci par avance.
