Désolé, j’étais en vacances, voici les logs après installation version stable, réinstallation des dépendances renseignement des identifiants ewelink. Le demon ne se lance toujours pas.
code: 'EADDRNOTAVAIL',
errno: 'EADDRNOTAVAIL',
syscall: 'listen',
address: '27.0.0.1',
port: 6005
http://192.168.31.221:80 SSL ? non
events.js:292
throw er; // Unhandled 'error' event
Error: listen EADDRNOTAVAIL: address not available 27.0.0.1:6005
at Server.setupListenHandle [as _listen2] (net.js:1296:21)
at listenInCluster (net.js:1361:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8)
Emitted 'error' event on Server instance at:
at emitErrorNT (net.js:1340:8)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
events.js:292
syscall: 'listen',
port: 6005
–0%
–10%
Lancement de l’installation/mise à jour des dépendances eWeJee
–20%
Get:1 Index of /debian buster InRelease [32.6 kB]
Hit:2 Index of /raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Get:4 Index of /debian buster/main armhf Packages [331 kB]
Fetched 363 kB in 3s (108 kB/s)
Reading package lists…
E: dpkg was interrupted, you must manually run ‹ sudo dpkg --configure -a › to correct the problem.
–30%
Version actuelle : v12.18.1
Ok, version suffisante
–50%
–60%
Installation de eWeJee… Cette partie est très longue, veuillez attendre les 100%
npm WARN deprecated request@2.88.2: request has been deprecated, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
websocket@1.0.31 install /var/www/html/plugins/ewejee/resources/node_modules/websocket
(node-gyp rebuild 2> builderror.log) || (exit 0)
make: Entering directory ‹ /var/www/html/plugins/ewejee/resources/node_modules/websocket/build ›
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
SOLINK_MODULE(target) Release/obj.target/bufferutil.node
COPY Release/bufferutil.node
CXX(target) Release/obj.target/validation/src/validation.o
SOLINK_MODULE(target) Release/obj.target/validation.node
COPY Release/validation.node
make: Leaving directory ‹ /var/www/html/plugins/ewejee/resources/node_modules/websocket/build ›
core-js@2.6.11 postinstall /var/www/html/plugins/ewejee/resources/node_modules/core-js
node -e « try{require(‹ ./postinstall ›)}catch(e){} »
e[96mThank you for using core-js (e[94m GitHub - zloirock/core-js: Standard Library e[96m) for polyfilling JavaScript standard library!e[0m
e[96mThe project needs your help! Please consider supporting of core-js on Open Collective or Patreon: e[0m
e[96m>e[94m core-js - Open Collective e[0m
e[96m>e[94m Denis Pushkarev | creating core-js | Patreon e[0m
e[96mAlso, the author of core-js (e[94m zloirock (Denis Pushkarev) · GitHub e[96m) is looking for a good job -)e[0m
npm WARN saveError ENOENT: no such file or directory, open ‹ /var/www/html/plugins/ewejee/resources/package.json ›
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN enoent ENOENT: no such file or directory, open ‹ /var/www/html/plugins/ewejee/resources/package.json ›
npm WARN resources No description
npm WARN resources No repository field.
npm WARN resources No README data
npm WARN resources No license field.
- ewelink-api@1.10.0
added 96 packages from 95 contributors and audited 96 packages in 25.774s
14 packages are looking for funding
run npm fund for details
found 0 vulnerabilities
- express@4.17.1
added 47 packages from 33 contributors and audited 217 packages in 7.207s
COREJS
RES
–70%
–80%
–90%
–95%
–100%
Installation des dépendances eWeJee terminée, vérifiez qu’il n’y a pas d’erreur
Merci de ton aide
