Je suis en dernière version de Jeedom 3.5, sur RPI3, avec Debian 9 Stretch.
J’ai acheté le plugin Arlo pour configurer la sonnette que je viens de recevoir.
Je suis en dépendance NOK mais sans aucun message d’erreur dans les logs :
* Launch install of dependencies *
vendredi 23 octobre 2020, 16:40:10 (UTC+0000)
Atteint:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Réception de:2 http://archive.raspberrypi.org/debian stretch InRelease [25,4 kB]
Réception de:3 https://download.docker.com/linux/raspbian stretch InRelease [31,1 kB]
56,4 ko réceptionnés en 4s (11,4 ko/s)
Lecture des listes de paquets…
Install modules using apt-get
Construction de l'arbre des dépendances…
Lecture des informations d'état…
python3 is already the newest version (3.5.3-1).
python3-requests is already the newest version (2.12.4-1).
python3-setuptools is already the newest version (33.1.1-1).
python3-pip is already the newest version (9.0.1-2+rpt2).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 7 non mis à jour.
Install the required python libraries
Requirement already satisfied: monotonic>=1.5 in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: requests>=2.12.4 in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: sseclient==0.0.18 in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.5/dist-packages (from requests>=2.12.4)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.5/dist-packages (from requests>=2.12.4)
Requirement already satisfied: chardet<4,>=3.0.2 in /usr/local/lib/python3.5/dist-packages (from requests>=2.12.4)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.5/dist-packages (from requests>=2.12.4)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from sseclient==0.0.18)
Install ffmpeg 4
ffmpeg version 4.2.1-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516
configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-6 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libxml2 --enable-libxvid --enable-libzimg
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
vendredi 23 octobre 2020, 16:40:34 (UTC+0000)
* Install ended *
J’ai vu dans un autre sujet qui fallait être en Buster.
J’aimerai passer à Buster et Jeedom 4, mais ce n’est pas prévu à court terme.
Une idée de ce qui coince pour la validation de l’étape ?
Le « même problème » c’est difficile à dire puisqu’on ne connait pas le problème de @nicolas-albert
L’installation ne s’arrête pas à 50%, cela a probablement été trop rapide pour pouvoir afficher la progression jusque 100%.
De ce que je vois les dépendances sont installées correctement.
Donc quel est le symptôme? les dépendances restent en NOK?
En tout cas ceci n’est pas bon:
pip3 doit retourner une version python 3.x et pas 2.x
Je ne sais pas ce que vous avez fait pour arriver à une telle situation, vous avez probablement exécuté certaines commandes pour certaines raisons… un problème avec un autre plugin?
Désinstaller pip3 et le réinstaller pourra peut-être rétablir la situation:
