je vient de passer en mode debug et j’ai ceci dans le log
021-06-16T19:20:30.642Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
2021-06-16T19:20:30.643Z zigbee-herdsman:deconz:adapter response received
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc', payload '{"device":{"applicationVersion":67,"dateCode":"","friendlyName":"0x847127fffe8f7acc","hardwareVersion":1,"ieeeAddr":"0x847127fffe8f7acc","manufacturerID":4098,"manufacturerName":"_TZ3000_ew3ldmgx","model":"TS011F_plug","networkAddress":23996,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"linkquality":255,"power_outage_memory":"restore","state":"OFF"}'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/power_outage_memory', payload 'restore'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/state', payload 'OFF'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-friendlyName', payload '0x847127fffe8f7acc'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/linkquality', payload '255'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-model', payload 'TS011F_plug'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-ieeeAddr', payload '0x847127fffe8f7acc'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-networkAddress', payload '23996'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-type', payload 'Router'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-manufacturerID', payload '4098'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-manufacturerName', payload '_TZ3000_ew3ldmgx'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-powerSource', payload 'Mains (single phase)'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-applicationVersion', payload '67'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-stackVersion', payload '0'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-zclVersion', payload '3'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-hardwareVersion', payload '1'
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-dateCode', payload ''
e[32mZigbee2MQTT:info e[39m 2021-06-16 21:20:30: MQTT publish: topic 'zigbee2mqtt/0x847127fffe8f7acc/device-softwareBuildID', payload ''
2021-06-16T19:20:30.706Z zigbee-herdsman:deconz:driver query aps data indication
2021-06-16T19:20:30.711Z zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 163
2021-06-16T19:20:30.719Z zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 163 srcAddr: 0x5dbc destAddr: 0x0 profile id: 0x104 cluster id: 0x6 lqi: 255
2021-06-16T19:20:30.719Z zigbee-herdsman:deconz:frameParser response payload: 24,25,10,0,0,16,0
2021-06-16T19:20:30.721Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":25,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":16,"attrData":0}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":23996,"endpoint":1,"linkquality":255,"groupID":null,"wasBroadcast":false,"destinationEndpoint":1}'
e[34mZigbee2MQTT:debuge[39m 2021-06-16 21:20:30: Received Zigbee message from '0x847127fffe8f7acc', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
2021-06-16T19:20:30.727Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
c’est même pire dans zigbee2mqtt j’ai plus que des N/A sur toute les remonter
