ca fait 2 jours que le plugin google cast ne fonctionne plus.
Tout mes équipements sont « not connected »
J’ai réinstallé les dépendances, relancé le démon et relancé un scan mais la situation ne change pas
je suis sur rpi3b+ sous buster
le plug in fonctionnait correctement depuis plus d’un an
voici les logs google cast local
[2021-08-02 08:03:05][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:51958]
[2021-08-02 08:03:05][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "7587beef-73c7-eed2-1f1d-979f4362cf6d"}
[2021-08-02 08:03:05][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:51958]
[2021-08-02 08:03:05][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:51964]
[2021-08-02 08:03:05][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ac489417-1577-993a-4851-cbd5c4c3db87"}
[2021-08-02 08:03:05][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:51964]
[2021-08-02 08:03:05][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:03:05][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:03:05][DEBUG] : SOCKET-READ------Now playing for 7587beef-73c7-eed2-1f1d-979f4362cf6d not activated because is offline
[2021-08-02 08:03:06][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:03:06][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:03:06][DEBUG] : SOCKET-READ------Now playing for ac489417-1577-993a-4851-cbd5c4c3db87 not activated because is offline
[2021-08-02 08:03:06][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:51974]
[2021-08-02 08:03:06][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "4c2a89cc-a768-47b3-ed2c-369698699c5f"}
[2021-08-02 08:03:06][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:51974]
[2021-08-02 08:03:06][DEBUG] : SOCKET-READ------Now playing for 4c2a89cc-a768-47b3-ed2c-369698699c5f not activated because is offline
[2021-08-02 08:03:06][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:51980]
[2021-08-02 08:03:06][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "74b8f738-3c10-c9c9-2a4c-3bb800806905"}
[2021-08-02 08:03:06][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:51980]
[2021-08-02 08:03:07][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:03:07][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:03:07][DEBUG] : SOCKET-READ------Now playing for 74b8f738-3c10-c9c9-2a4c-3bb800806905 not activated because is offline
[2021-08-02 08:04:05][DEBUG] : SCANNER------ Start scanning... (schedule)
[2021-08-02 08:04:05][DEBUG] : MEMORY---- Total CPU time used : 5.284s (1.76%) | Last 62 sec : 0.351s (0.57%) | Memory : 26 Mo
[2021-08-02 08:04:05][INFO] : SCANNER------ Adding chromecast : Hub Salon
[2021-08-02 08:04:05][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:04:05][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 2133, in scanner
globals.GCAST_DEVICES[uuid] = JeedomChromeCast(
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 107, in __init__
self.gcast.wait(timeout=globals.SCAN_TIMEOUT)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/__init__.py", line 444, in wait
if not self.socket_client.isAlive():
AttributeError: 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:04:38][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:53108]
[2021-08-02 08:04:38][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "388e705b-a3df-a910-fc71-a332af4419ac"}
[2021-08-02 08:04:38][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:53108]
[2021-08-02 08:04:38][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:04:38][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:04:38][DEBUG] : SOCKET-READ------Now playing for 388e705b-a3df-a910-fc71-a332af4419ac not activated because is offline
[2021-08-02 08:04:39][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:53142]
[2021-08-02 08:04:39][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ab8ac01c-1b0c-fb2b-f64e-c983a723d47c"}
[2021-08-02 08:04:39][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:53142]
[2021-08-02 08:04:40][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:53146]
[2021-08-02 08:04:40][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "aa11dec8-b636-932a-dc28-8a81bc0089a4"}
[2021-08-02 08:04:40][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:53146]
[2021-08-02 08:04:40][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:04:40][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:04:40][DEBUG] : SOCKET-READ------Now playing for ab8ac01c-1b0c-fb2b-f64e-c983a723d47c not activated because is offline
[2021-08-02 08:04:40][DEBUG] : SOCKET-READ------Now playing for aa11dec8-b636-932a-dc28-8a81bc0089a4 not activated because is offline
[2021-08-02 08:05:07][DEBUG] : SCANNER------ Start scanning... (schedule)
[2021-08-02 08:05:07][DEBUG] : MEMORY---- Total CPU time used : 5.601s (1.55%) | Last 62 sec : 0.317s (0.51%) | Memory : 26 Mo
[2021-08-02 08:05:07][INFO] : SCANNER------ Adding chromecast : Hub Salon
[2021-08-02 08:05:07][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:05:07][DEBUG] : Traceback (most recent call last):
[2021-08-02 08:06:08][DEBUG] : SCANNER------ Start scanning... (schedule)
[2021-08-02 08:06:08][DEBUG] : MEMORY---- Total CPU time used : 5.844s (1.38%) | Last 61 sec : 0.243s (0.40%) | Memory : 26 Mo
[2021-08-02 08:06:08][INFO] : SCANNER------ Adding chromecast : Hub Salon
[2021-08-02 08:06:08][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:06:08][DEBUG] : Traceback (most recent call last):
[2021-08-02 08:06:36][DEBUG] : SENDER------Send to jeedom : {'heartbeat': 1, 'source': 'local'}
[2021-08-02 08:07:10][DEBUG] : SCANNER------ Start scanning... (schedule)
[2021-08-02 08:07:10][DEBUG] : MEMORY---- Total CPU time used : 6.174s (1.27%) | Last 62 sec : 0.330s (0.53%) | Memory : 27 Mo
[2021-08-02 08:07:10][INFO] : SCANNER------ Adding chromecast : Hub Salon
[2021-08-02 08:07:10][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:07:10][DEBUG] : Traceback (most recent call last):
[2021-08-02 08:07:33][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55302]
[2021-08-02 08:07:33][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "388e705b-a3df-a910-fc71-a332af4419ac"}
[2021-08-02 08:07:33][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55302]
[2021-08-02 08:07:33][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:33][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:33][DEBUG] : SOCKET-READ------Now playing for 388e705b-a3df-a910-fc71-a332af4419ac not activated because is offline
[2021-08-02 08:07:34][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55314]
[2021-08-02 08:07:34][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ad87456b-13d5-40e1-37ef-03a9270a094d"}
[2021-08-02 08:07:34][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55314]
[2021-08-02 08:07:34][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:34][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:34][DEBUG] : SOCKET-READ------Now playing for ad87456b-13d5-40e1-37ef-03a9270a094d not activated because is offline
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55326]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ab8ac01c-1b0c-fb2b-f64e-c983a723d47c"}
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55326]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55328]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "aa11dec8-b636-932a-dc28-8a81bc0089a4"}
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55328]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55332]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ac489417-1577-993a-4851-cbd5c4c3db87"}
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55332]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55330]
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "7587beef-73c7-eed2-1f1d-979f4362cf6d"}
[2021-08-02 08:07:35][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55330]
[2021-08-02 08:07:35][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:35][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:35][DEBUG] : SOCKET-READ------Now playing for ab8ac01c-1b0c-fb2b-f64e-c983a723d47c not activated because is offline
[2021-08-02 08:07:35][DEBUG] : SOCKET-READ------Now playing for aa11dec8-b636-932a-dc28-8a81bc0089a4 not activated because is offline
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55350]
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "4c2a89cc-a768-47b3-ed2c-369698699c5f"}
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55350]
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55352]
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "74b8f738-3c10-c9c9-2a4c-3bb800806905"}
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55352]
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55354]
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "388e705b-a3df-a910-fc71-a332af4419ac"}
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55354]
[2021-08-02 08:07:36][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:36][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:36][DEBUG] : SOCKET-READ------Now playing for ac489417-1577-993a-4851-cbd5c4c3db87 not activated because is offline
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55356]
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ad87456b-13d5-40e1-37ef-03a9270a094d"}
[2021-08-02 08:07:36][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55356]
[2021-08-02 08:07:36][DEBUG] : SOCKET-READ------Now playing for 7587beef-73c7-eed2-1f1d-979f4362cf6d not activated because is offline
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55364]
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ad5fa860-efaf-a000-c0c0-38cae929231d"}
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55364]
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55366]
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "e92c0cd8-6eb9-4e2e-9dc2-2be62f0b61df"}
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55366]
[2021-08-02 08:07:37][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:37][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:37][DEBUG] : SOCKET-READ------Now playing for 4c2a89cc-a768-47b3-ed2c-369698699c5f not activated because is offline
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55372]
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ab8ac01c-1b0c-fb2b-f64e-c983a723d47c"}
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55372]
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55378]
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "aa11dec8-b636-932a-dc28-8a81bc0089a4"}
[2021-08-02 08:07:37][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55378]
[2021-08-02 08:07:37][DEBUG] : SOCKET-READ------Now playing for 74b8f738-3c10-c9c9-2a4c-3bb800806905 not activated because is offline
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55390]
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "7587beef-73c7-eed2-1f1d-979f4362cf6d"}
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55390]
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55392]
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ac489417-1577-993a-4851-cbd5c4c3db87"}
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55392]
[2021-08-02 08:07:38][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:38][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:38][DEBUG] : SOCKET-READ------Now playing for 388e705b-a3df-a910-fc71-a332af4419ac not activated because is offline
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55394]
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "4c2a89cc-a768-47b3-ed2c-369698699c5f"}
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55394]
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55402]
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "74b8f738-3c10-c9c9-2a4c-3bb800806905"}
[2021-08-02 08:07:38][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55402]
[2021-08-02 08:07:38][DEBUG] : SOCKET-READ------Now playing for ad87456b-13d5-40e1-37ef-03a9270a094d not activated because is offline
[2021-08-02 08:07:39][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:39][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:39][DEBUG] : SOCKET-READ------Now playing for ad5fa860-efaf-a000-c0c0-38cae929231d not activated because is offline
[2021-08-02 08:07:39][DEBUG] : SOCKET-READ------Now playing for e92c0cd8-6eb9-4e2e-9dc2-2be62f0b61df not activated because is offline
[2021-08-02 08:07:40][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55420]
[2021-08-02 08:07:40][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "ad5fa860-efaf-a000-c0c0-38cae929231d"}
[2021-08-02 08:07:40][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55420]
[2021-08-02 08:07:40][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:55422]
[2021-08-02 08:07:40][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "nowplaying", "uuid": "e92c0cd8-6eb9-4e2e-9dc2-2be62f0b61df"}
[2021-08-02 08:07:40][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:55422]
[2021-08-02 08:07:40][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:40][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:40][DEBUG] : SOCKET-READ------Now playing for ab8ac01c-1b0c-fb2b-f64e-c983a723d47c not activated because is offline
[2021-08-02 08:07:40][DEBUG] : SOCKET-READ------Now playing for aa11dec8-b636-932a-dc28-8a81bc0089a4 not activated because is offline
[2021-08-02 08:07:41][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:41][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:41][DEBUG] : SOCKET-READ------Now playing for 7587beef-73c7-eed2-1f1d-979f4362cf6d not activated because is offline
[2021-08-02 08:07:41][DEBUG] : SOCKET-READ------Now playing for ac489417-1577-993a-4851-cbd5c4c3db87 not activated because is offline
[2021-08-02 08:07:42][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:42][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:42][DEBUG] : SOCKET-READ------Now playing for 4c2a89cc-a768-47b3-ed2c-369698699c5f not activated because is offline
[2021-08-02 08:07:42][DEBUG] : SOCKET-READ------Now playing for 74b8f738-3c10-c9c9-2a4c-3bb800806905 not activated because is offline
[2021-08-02 08:07:43][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-08-02 08:07:43][DEBUG] : SOCKET-READ------Received command from jeedom : nowplaying
[2021-08-02 08:07:43][DEBUG] : SOCKET-READ------Now playing for ad5fa860-efaf-a000-c0c0-38cae929231d not activated because is offline
[2021-08-02 08:07:43][DEBUG] : SOCKET-READ------Now playing for e92c0cd8-6eb9-4e2e-9dc2-2be62f0b61df not activated because is offline
[2021-08-02 08:08:12][DEBUG] : SCANNER------ Start scanning... (schedule)
[2021-08-02 08:08:12][DEBUG] : MEMORY---- Total CPU time used : 6.519s (1.19%) | Last 62 sec : 0.346s (0.56%) | Memory : 27 Mo
[2021-08-02 08:08:12][INFO] : SCANNER------ Adding chromecast : Hub Salon
[2021-08-02 08:08:12][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:08:12][DEBUG] : Traceback (most recent call last):
[2021-08-02 08:09:14][DEBUG] : SCANNER------ Start scanning... (schedule)
[2021-08-02 08:09:14][DEBUG] : MEMORY---- Total CPU time used : 6.758s (1.11%) | Last 62 sec : 0.239s (0.39%) | Memory : 27 Mo
[2021-08-02 08:09:14][INFO] : SCANNER------ Adding chromecast : Hub Salon
[2021-08-02 08:09:14][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2021-08-02 08:09:14][DEBUG] : Traceback (most recent call last):
et google cast update
Launch install of googlecast dependancies
-- Current OS version :
Description: Raspbian GNU/Linux 10 (buster)
-- Updating repo...
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://phoscon.de/apt/deconz buster InRelease
Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 178 not upgraded.
-- Installed version of Python :
Python 3.9.1
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python-requests is already the newest version (2.21.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5+rpt1).
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-1).
-- Installation of TTS libraries
Package libttspico-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libttspico-utils' has no installation candidate
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.1.6-1~deb10u1+rpt2).
-- Upgrade setuptools with command pip3.9 if not up to date
WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
You should consider upgrading via the '/usr/local/bin/python3.9 -m pip install --upgrade pip' command.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.9/site-packages (49.2.1)
-- Installed version of pip :
pip 20.2.3 from /usr/local/lib/python3.9/site-packages/pip (python 3.9)
-- Installation of python library 'requests' with command pip3.9
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.9/site-packages (2.26.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/site-packages (from requests>=2.21.0) (2021.5.30)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.9/site-packages (from requests>=2.21.0) (1.26.6)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.9/site-packages (from requests>=2.21.0) (3.2)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.9/site-packages (from requests>=2.21.0) (2.0.3)
-- Installation of python library 'protobuf' with command pip3.9
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.9/site-packages (3.17.3)
Requirement already satisfied: six>=1.9 in /usr/local/lib/python3.9/site-packages (from protobuf>=3.11.0) (1.16.0)
-- Installation of python library 'zeroconf' with command pip3.9
Requirement already satisfied: zeroconf>=0.25.1 in /usr/local/lib/python3.9/site-packages (0.33.2)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.9/site-packages (from zeroconf>=0.25.1) (0.1.7)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.9
Requirement already satisfied: click in /usr/local/lib/python3.9/site-packages (8.0.1)
Requirement already satisfied: bs4 in /usr/local/lib/python3.9/site-packages (0.0.1)
Requirement already satisfied: six in /usr/local/lib/python3.9/site-packages (1.16.0)
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.9/site-packages (from bs4) (4.9.3)
Requirement already satisfied: soupsieve>1.2; python_version >= "3.0" in /usr/local/lib/python3.9/site-packages (from beautifulsoup4->bs4) (2.2.1)
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3.9
Requirement already satisfied: tqdm in /usr/local/lib/python3.9/site-packages (4.62.0)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.9/site-packages (1.1.0)
Requirement already satisfied: casttube in /usr/local/lib/python3.9/site-packages (0.2.1)
Requirement already satisfied: requests in /usr/local/lib/python3.9/site-packages (from casttube) (2.26.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/site-packages (from requests->casttube) (2021.5.30)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.9/site-packages (from requests->casttube) (1.26.6)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.9/site-packages (from requests->casttube) (3.2)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.9/site-packages (from requests->casttube) (2.0.3)
-- Installation of dependencies is done !
Merci d’avance pour votre aide
