sute à upgrade, le plugin plantę au bout de 10 secondes.
Ci après le lot :
[2024-10-03 14:15:08] INFO : Start demond
[2024-10-03 14:15:08] INFO : Log level: debug
[2024-10-03 14:15:08] INFO : Socket port: 55070
[2024-10-03 14:15:08] INFO : Socket host: localhost
[2024-10-03 14:15:08] INFO : PID file: /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
[2024-10-03 14:15:08] INFO : Device: auto
[2024-10-03 14:15:08] INFO : User: olivier@clemot.com
[2024-10-03 14:15:08] INFO : Pin ocde: 2053-2071-6687
[2024-10-03 14:15:08] INFO : Box IP: https://192.168.1.130:8443
[2024-10-03 14:15:08] INFO : Tahoma token: 66fe943078c8cbde3a89
[2024-10-03 14:15:08] INFO : *-------------------------------------------------------------------------*
[2024-10-03 14:15:08] INFO : Writing PID 107558 to /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
[2024-10-03 14:15:08] INFO : Init request module v2.32.3
[2024-10-03 14:15:08] DEBUG : Starting new HTTP connection (1): 127.0.0.1:81
[2024-10-03 14:15:08] DEBUG : http://127.0.0.1:81 "GET /plugins/tahomalocalapi/core/php/jeeTahomalocalapi.php?apikey=qZqVP9479dgMqmeD6vWYhiNPSGG9SpuP8LDiG23TjhG40ogrNG0TGXwSr5ck30vn HTTP/11" 200 0
[2024-10-03 14:15:08] DEBUG : Listen socket jeedom
[2024-10-03 14:15:08] INFO : Socket interface started
[2024-10-03 14:15:08] INFO : LoopNetServer Thread started
[2024-10-03 14:15:08] DEBUG : * Retrieve gateways list
[2024-10-03 14:15:08] INFO : Listening on: [localhost:55070]
[2024-10-03 14:15:08] DEBUG : Gateways list : [{'gatewayId': '2053-2071-6687', 'connectivity': {'status': 'OK', 'protocolVersion': '2024.4.3-11'}}]
[2024-10-03 14:15:08] INFO : Send to jeedom : {'gatewaysList': [{'gatewayId': '2053-2071-6687', 'connectivity': {'status': 'OK', 'protocolVersion': '2024.4.3-11'}}]}
[2024-10-03 14:15:08] DEBUG : * Retrieve devices list
[2024-10-03 14:15:09] INFO : Send to jeedom : {'devicesList': [{'controllableName': 'io:LightMicroModuleSomfyIOComponent', 'enabled': True, 'synced': True, ..., 'nparams': 1}], 'type': 'ACTUATOR', 'widgetName': 'StatefulOnOff', 'uiClass': 'OnOff'}}]}
[2024-10-03 14:15:09] DEBUG : * Register listener
[2024-10-03 14:15:19] DEBUG : Signal 15 caught, exiting...
[2024-10-03 14:15:19] DEBUG : Shutdown
[2024-10-03 14:15:19] DEBUG : Removing PID file /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
Est ce un problème connu ?
