Le démon Jeezigbee de ma jeedom est killé regulierement
killed
> zigbee2mqtt@2.9.1 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2026-03-26 21:52:36] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2026-03-26 21:52:36] e[34mdebuge[39m: z2m: Can't load state from file /var/www/html/plugins/z2m/data/state.json (doesn't exist)
[2026-03-26 21:52:36] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.9.1 (commit #85875aee)
[2026-03-26 21:52:36] e[32minfoe[39m: z2m: Starting zigbee-herdsman (9.0.9)
[2026-03-26 21:52:36] e[34mdebuge[39m: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":58215,\"extendedPanID\":[246,64,33,46,53,201,78,176],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/var/www/html/plugins/z2m/data/database.db\",\"databaseBackupPath\":\"/var/www/html/plugins/z2m/data/database.db.backup\",\"backupPath\":\"/var/www/html/plugins/z2m/data/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5032d00788c2ef11bfb0c7138148b910-if00-port0\",\"adapter\":\"ember\"},\"adapter\":{\"disableLED\":false}}"'
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyACM0","manufacturer":"0658","pnpId":"usb-0658_0200-if00","vendorId":"0658","productId":"0200"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"5032d00788c2ef11bfb0c7138148b910","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5032d00788c2ef11bfb0c7138148b910-if00-port0","vendorId":"10c4","productId":"ea60"}]
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:adapter:discovery: Unable to match USB adapter: ember | /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5032d00788c2ef11bfb0c7138148b910-if00-port0
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember: Using default stack config.
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","extendedPanID":[246,64,33,46,53,201,78,176],"panID":58215,"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5032d00788c2ef11bfb0c7138148b910-if00-port0","adapter":"ember"},"adapter":{"disableLED":false},"databasePath":"/var/www/html/plugins/z2m/data/database.db","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json"}'
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:ember:uart:ash: Opening serial port with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5032d00788c2ef11bfb0c7138148b910-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember:uart:ash: Serial port opened
[2026-03-26 21:52:36] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=RST]
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 0/5000
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 100/5000
[2026-03-26 21:52:36] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 200/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 300/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 400/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 500/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 600/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 700/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 800/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 900/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: Waiting for RSTACK... 1000/5000
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=RSTACK]
[2026-03-26 21:52:37] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH connected ========
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=ACK frmRx=0](ackRx=0)
[2026-03-26 21:52:37] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH started ========
[2026-03-26 21:52:37] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP started ========
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: ===> [FRAME: ID=0:"VERSION" Seq=0 Len=4]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=DATA frmTx=0 frmRx=0](ackRx=0)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=1](ackRx=0 frmTx=1)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=1 frmNum=0](frmRx=0) Added to rxQueue
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=ACK frmRx=1](ackRx=1)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: <=== [FRAME: ID=0:"VERSION" Seq=0 Len=7]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: ===> [FRAME: ID=0:"VERSION" Seq=1 Len=6]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=DATA frmTx=1 frmRx=1](ackRx=1)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=2](ackRx=1 frmTx=2)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=2 frmNum=1](frmRx=1) Added to rxQueue
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=ACK frmRx=2](ackRx=2)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: <=== [FRAME: ID=0:"VERSION" Seq=1 Len=9]
[2026-03-26 21:52:37] e[32minfoe[39m: zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember: Adapter info: EZSPVersion=13 StackType=2 StackVersion=29760
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: ===> [FRAME: ID=170:"GET_VALUE" Seq=2 Len=6]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=DATA frmTx=2 frmRx=2](ackRx=2)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=3](ackRx=2 frmTx=3)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=3 frmNum=2](frmRx=2) Added to rxQueue
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=ACK frmRx=3](ackRx=3)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: <=== [FRAME: ID=170:"GET_VALUE" Seq=2 Len=14]
[2026-03-26 21:52:37] e[32minfoe[39m: zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.4 [GA]","build":0,"major":7,"minor":4,"patch":4,"special":0,"type":170}
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: ===> [FRAME: ID=83:"SET_CONFIGURATION_VALUE" Seq=3 Len=8]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=DATA frmTx=3 frmRx=3](ackRx=3)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=4](ackRx=3 frmTx=4)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=4 frmNum=3](frmRx=3) Added to rxQueue
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=ACK frmRx=4](ackRx=4)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: <=== [FRAME: ID=83:"SET_CONFIGURATION_VALUE" Seq=3 Len=6]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember: [EzspConfigId] SET 'TRUST_CENTER_ADDRESS_CACHE_SIZE' TO '2' with status=OK.
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:ezsp: ===> [FRAME: ID=83:"SET_CONFIGURATION_VALUE" Seq=4 Len=8]
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: ---> [FRAME type=DATA frmTx=4 frmRx=4](ackRx=4)
[2026-03-26 21:52:37] e[34mdebuge[39m: zh:ember:uart:ash: <--- [FRAME type=DATA ackNum=5](ackRx=4 frmTx=5)
:"strobelevel","type":48}],"required":true}},"commandsResponse":{}},"ssIasZone":{"ID":1280,"attributes":{"currentZoneSensitivityLevel":{"ID":19,"default":0,"max":255,"type":32,"write":true},"develcoAlarmOffDelay":{"ID":32769,"manufacturerCode":4117,"max":65535,"type":33,"write":true},"iasCieAddr":{"ID":16,"required":true,"type":240,"write":true},"numZoneSensitivityLevelsSupported":{"ID":18,"default":2,"max":255,"min":2,"type":32},"zoneId":{"ID":17,"default":255,"max":255,"required":true,"type":32},"zoneState":{"ID":0,"default":0,"required":true,"type":48},"zoneStatus":{"ID":2,"default":0,"required":true,"type":25},"zoneType":{"ID":1,"required":true,"type":49}},"commands":{"enrollRsp":{"ID":0,"parameters":[{"name":"enrollrspcode","type":48},{"name":"zoneid","type":32}],"required":true},"initNormalOpMode":{"ID":1,"parameters":[]},"initTestMode":{"ID":2,"parameters":[{"name":"testModeDuration","type":32},{"name":"currentZoneSensitivityLevel","type":32}]}},"commandsResponse":{"enrollReq":{"ID":1,"parameters":[{"name":"zonetype","type":49},{"name":"manucode","type":33}],"required":true},"statusChangeNotification":{"ID":0,"parameters":[{"name":"zonestatus","type":25},{"name":"extendedstatus","type":24},{"name":"zoneID","type":32},{"name":"delay","type":33}],"required":true}}},"telecommunicationsChatting":{"ID":2309,"attributes":{"cID":{"ID":16,"max":65535,"required":true,"type":33},"enableAddChat":{"ID":18,"type":16},"name":{"ID":17,"required":true,"type":66},"nickname":{"ID":1,"required":true,"type":66},"uID":{"ID":0,"max":65535,"required":true,"type":33}},"commands":{"chatMessage":{"ID":5,"parameters":[{"name":"destUID","type":33},{"name":"srcUID","type":33},{"name":"cID","type":33},{"name":"nickname","type":66},{"name":"message","type":66}],"required":true},"getNodeInfoReq":{"ID":6,"parameters":[{"name":"cID","type":33},{"name":"uID","type":33}],"response":8},"joinChatReq":{"ID":0,"parameters":[{"name":"uID","type":33},{"name":"nickname","type":66},{"name":"cID","type":33}],"required":true,"response":1},"leaveChatReq":{"ID":1,"parameters":[{"name":"cID","type":33},{"name":"uID","type":33}],"required":true},"searchChatReq":{"ID":2,"parameters":[],"required":true,"response":4},"startChatReq":{"ID":4,"parameters":[{"name":"name","type":66},{"name":"uID","type":33},{"name":"nickname","type":66}],"response":0},"switchCharmanRsp":{"ID":3,"parameters":[{"name":"cID","type":33},{"name":"uID","type":33}]}},"commandsResponse":{"getNodeInfoRsp":{"ID":8,"parameters":[{"name":"status","type":48},{"name":"cID","type":33},{"name":"uID","type":33},{"name":"address","type":9},{"name":"endpoint","type":32},{"name":"nickName","type":66}],"required":true},"joinChatRsp":{"ID":1,"parameters":[{"name":"status","type":48},{"name":"cID","type":33}],"required":true},"searchChatRsp":{"ID":4,"parameters":[{"name":"options","type":24}],"required":true},"startChatRsp":{"ID":0,"parameters":[{"name":"status","type":48},{"name":"cID","type":33}],"required":true},"switchChairmanConfirm":{"ID":6,"parameters":[{"name":"cID","type":33}],"required":true},"switchChairmanNotification":{"ID":7,"parameters":[{"name":"cID","type":33},{"name":"uID","type":33},{"name":"address","type":9},{"name":"endpoint","type":32}],"required":true},"switchChairmanReq":{"ID":5,"parameters":[{"name":"cID","type":33}],"required":true},"userJoined":{"ID":3,"parameters":[{"name":"cID","type":33},{"name":"uID","type":33},{"name":"nickName","type":66}],"required":true},"userLeft":{"ID":2,"parameters":[{"name":"cID","type":33},{"name":"uID","type":33},{"name":"nickName","type":66}],"required":true}}},"telecommunicationsInformation":{"ID":2304,"attributes":{"contentRootID":{"ID":17,"max":65535,"type":33},"deliveryEnable":{"ID":1,"required":true,"type":16},"enableSecureConfiguration":{"ID":3,"required":true,"type":16},"nodeDescription":{"ID":0,"required":true,"type":66},"numberOfContents":{"ID":16,"max":65535,"type":33},"pushInformationTimer":{"ID":2,"type":35}},"commands":{"configureDeliveryEnable":{"ID":7,"parameters":[]},"configureNodeDescription":{"ID":6,"parameters":[]},"configurePushInfoTimer":{"ID":8,"parameters":[]},"configureSetRootId":{"ID":9,"parameters":[]},"delete":{"ID":5,"parameters":[],"response":6},"pushInfoResponse":{"ID":1,"parameters":[],"required":true},"requestInfo":{"ID":0,"parameters":[],"required":true,"response":0},"requestPreferenceRsp":{"ID":3,"parameters":[]},"sendPreference":{"ID":2,"parameters":[],"response":2},"update":{"ID":4,"parameters":[],"response":5}},"commandsResponse":{"deleteRsp":{"ID":6,"parameters":[],"required":true},"pushInfo":{"ID":1,"parameters":[],"required":true},"requestInfoRsp":{"ID":0,"parameters":[],"required":true},"requestPreferenceConfirmation":{"ID":4,"parameters":[],"required":true},"sendPreferenceRsp":{"ID":2,"parameters":[],"required":true},"serverRequestPreference":{"ID":3,"parameters":[],"required":true},"updateRsp":{"ID":5,"parameters":[],"required":true}}},"telecommunicationsVoiceOverZigbee":{"ID":2308,"attributes":{"codecType":{"ID":0,"required":true,"type":48,"write":true},"codecTypeSub1":{"ID":4,"type":48,"write":true},"codecTypeSub2":{"ID":5,"type":48,"write":true},"codecTypeSub3":{"ID":6,"type":48,"write":true},"codecrate":{"ID":2,"required":true,"type":48,"write":true},"compressionRate":{"ID":8,"type":48},"compressionType":{"ID":7,"type":48},"establishmentTimeout":{"ID":3,"max":255,"min":1,"required":true,"type":32},"optionFlags":{"ID":9,"max":255,"type":24,"write":true},"samplingFrequency":{"ID":1,"required":true,"type":48,"write":true},"threshold":{"ID":10,"max":255,"type":32,"write":true}},"commands":{"controlResponse":{"ID":0,"parameters":[{"name":"status","type":48}]},"establishmentRequest":{"ID":0,"parameters":[{"name":"flag","type":24},{"name":"codecType","type":48},{"name":"sampFreq","type":48},{"name":"codecRate","type":48},{"name":"serviceType","type":48},{"conditions":[{"mask":1,"param":"flag","type":"bitMaskSet"}],"name":"codecTypeS1","type":48},{"conditions":[{"mask":2,"param":"flag","type":"bitMaskSet"}],"name":"codecTypeS2","type":48},{"conditions":[{"mask":4,"param":"flag","type":"bitMaskSet"}],"name":"codecTypeS3","type":48},{"conditions":[{"mask":8,"param":"flag","type":"bitMaskSet"}],"name":"compType","type":48},{"conditions":[{"mask":8,"param":"flag","type":"bitMaskSet"}],"name":"compRate","type":48}],"required":true,"response":0},"voiceTransmission":{"ID":0,"parameters":[{"name":"voiceData","type":255}],"required":true},"voiceTransmissionCompletion":{"ID":0,"parameters":[{"name":"zclHeader","type":255}]}},"commandsResponse":{"control":{"ID":2,"parameters":[{"name":"controlType","type":48}]},"establishmentRsp":{"ID":0,"parameters":[{"name":"status","type":48},{"name":"codecType","type":48}],"required":true},"voiceTransmissionRsp":{"ID":1,"parameters":[{"name":"zclHeaderSeqNum","type":32},{"name":"errorFlag","type":48}],"required":true}}},"touchlink":{"ID":4096,"attributes":{},"commands":{"deviceInformation":{"ID":2,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"startIndex","type":32}],"required":true,"response":3},"getEndpointList":{"ID":66,"parameters":[{"name":"startIndex","type":32}],"response":66},"getGroupIdentifiers":{"ID":65,"parameters":[{"name":"startIndex","type":32}],"response":65},"identifyRequest":{"ID":6,"parameters":[{"min":1,"name":"transactionID","type":35},{"max":65535,"name":"duration","special":[["ExitIdentifyMode","0000"],["IdentifyForReceiverKnownTime","ffff"]],"type":33}],"required":true},"networkJoinEndDevice":{"ID":20,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"extendedPANID","type":240},{"max":15,"name":"keyIndex","type":32},{"name":"encryptedNetworkKey","type":241},{"name":"networkUpdateID","type":32},{"name":"logicalChannel","type":32},{"max":65534,"min":1,"name":"panID","type":33},{"max":65527,"min":1,"name":"nwkAddr","type":33},{"name":"groupIDsBegin","type":33},{"name":"groupIDsEnd","type":33},{"name":"freeNwkAddrRangeBegin","type":33},{"name":"freeNwkAddrRangeEnd","type":33},{"name":"freeGroupIDRangeBegin","type":33},{"name":"freeGroupIDRangeEnd","type":33}],"required":true,"response":21},"networkJoinRouter":{"ID":18,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"extendedPANID","type":240},{"max":15,"name":"keyIndex","type":32},{"name":"encryptedNetworkKey","type":241},{"name":"networkUpdateID","type":32},{"name":"logicalChannel","type":32},{"max":65534,"min":1,"name":"panID","type":33},{"max":65527,"min":1,"name":"nwkAddr","type":33},{"name":"groupIDsBegin","type":33},{"name":"groupIDsEnd","type":33},{"name":"freeNwkAddrRangeBegin","type":33},{"name":"freeNwkAddrRangeEnd","type":33},{"name":"freeGroupIDRangeBegin","type":33},{"name":"freeGroupIDRangeEnd","type":33}],"required":true,"response":19},"networkStart":{"ID":16,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"extendedPANID","type":240},{"max":15,"name":"keyIndex","type":32},{"name":"encryptedNetworkKey","type":241},{"name":"logicalChannel","type":32},{"max":65534,"name":"panID","type":33},{"max":65527,"min":1,"name":"nwkAddr","type":33},{"name":"groupIDsBegin","type":33},{"name":"groupIDsEnd","type":33},{"name":"freeNwkAddrRangeBegin","type":33},{"name":"freeNwkAddrRangeEnd","type":33},{"name":"freeGroupIDRangeBegin","type":33},{"name":"freeGroupIDRangeEnd","type":33},{"name":"initiatorIEEE","type":240},{"name":"initiatorNwkAddr","type":33}],"required":true,"response":17},"networkUpdate":{"ID":22,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"extendedPANID","type":240},{"name":"networkUpdateID","type":32},{"name":"logicalChannel","type":32},{"max":65534,"min":1,"name":"panID","type":33},{"max":65527,"min":1,"name":"nwkAddr","type":33}],"required":true},"resetToFactoryNew":{"ID":7,"parameters":[{"min":1,"name":"transactionID","type":35}],"required":true},"scanRequest":{"ID":0,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"zigbeeInformation","type":24},{"name":"touchlinkInformation","type":24}],"required":true,"response":1}},"commandsResponse":{"deviceInformation":{"ID":3,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"numberOfSubDevices","type":32},{"name":"startIndex","type":32},{"max":5,"name":"deviceInfoCount","type":32}],"required":true},"endpointInformation":{"ID":64,"parameters":[{"name":"ieeeAddress","type":240},{"name":"networkAddress","type":33},{"name":"endpointID","type":32},{"name":"profileID","type":33},{"name":"deviceID","type":33},{"name":"version","type":32}]},"getEndpointList":{"ID":66,"parameters":[{"name":"total","type":32},{"name":"startIndex","type":32},{"name":"count","type":32}]},"getGroupIdentifiers":{"ID":65,"parameters":[{"name":"total","type":32},{"name":"startIndex","type":32},{"name":"count","type":32}]},"networkJoinEndDevice":{"ID":21,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"status","type":32}],"required":true},"networkJoinRouter":{"ID":19,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"status","type":32}],"required":true},"networkStart":{"ID":17,"parameters":[{"min":1,"name":"transactionID","type":35},{"name":"status","type":32},{"name":"extendedPANID","type":240},{"name":"networkUpdateID","type":32},{"name":"logicalChannel","type":32},{"name":"panID","type":33}],"required":true},"scanResponse":{"ID":1,"parameters":[{"min":1,"name":"transactionID","type":35},{"max":20,"min":0,"name":"rssiCorrection","type":32},{"name":"zigbeeInformation","type":24},{"name":"touchlinkInformation","type":24},{"name":"keyBitmask","type":25},{"name":"responseID","type":35},{"name":"extendedPanID","type":240},{"name":"networkUpdateID","type":32},{"name":"logicalChannel","type":32},{"name":"panID","type":33},{"max":65527,"min":1,"name":"networkAddress","type":33},{"name":"numberOfSubDevices","type":32},{"name":"totalGroupIdentifiers","type":32},{"conditions":[{"field":"numberOfSubDevices","type":"fieldEquals","value":1}],"name":"endpointID","type":32},{"conditions":[{"field":"numberOfSubDevices","type":"fieldEquals","value":1}],"name":"profileID","type":33},{"conditions":[{"field":"numberOfSubDevices","type":"fieldEquals","value":1}],"name":"deviceID","type":33},{"conditions":[{"field":"numberOfSubDevices","type":"fieldEquals","value":1}],"name":"version","type":32},{"conditions":[{"field":"numberOfSubDevices","type":"fieldEquals","value":1}],"name":"groupIDCount","type":32}],"required":true}}},"zosungIRControl":{"ID":57348,"attributes":{},"commands":{"zosungControlIRCommand00":{"ID":0,"parameters":[{"name":"data","type":1008}]}},"commandsResponse":{}},"zosungIRTransmit":{"ID":60672,"attributes":{},"commands":{"zosungSendIRCode00":{"ID":0,"parameters":[{"max":65535,"name":"seq","type":33},{"max":4294967295,"name":"length","type":35},{"max":4294967295,"name":"unk1","type":35},{"max":65535,"name":"unk2","type":33},{"max":255,"name":"unk3","type":32},{"max":255,"name":"cmd","type":32},{"max":65535,"name":"unk4","type":33}]},"zosungSendIRCode01":{"ID":1,"parameters":[{"max":255,"name":"zero","type":32},{"max":65535,"name":"seq","type":33},{"max":4294967295,"name":"length","type":35},{"max":4294967295,"name":"unk1","type":35},{"max":65535,"name":"unk2","type":33},{"max":255,"name":"unk3","type":32},{"max":255,"name":"cmd","type":32},{"max":65535,"name":"unk4","type":33}]},"zosungSendIRCode02":{"ID":2,"parameters":[{"max":65535,"name":"seq","type":33},{"max":4294967295,"name":"position","type":35},{"max":255,"name":"maxlen","type":32}]},"zosungSendIRCode03":{"ID":3,"parameters":[{"max":255,"name":"zero","type":32},{"max":65535,"name":"seq","type":33},{"max":4294967295,"name":"position","type":35},{"name":"msgpart","type":65},{"max":255,"name":"msgpartcrc","type":32}]},"zosungSendIRCode04":{"ID":4,"parameters":[{"max":255,"name":"zero0","type":32},{"max":65535,"name":"seq","type":33},{"max":65535,"name":"zero1","type":33}]},"zosungSendIRCode05":{"ID":5,"parameters":[{"max":65535,"name":"seq","type":33},{"max":65535,"name":"zero","type":33}]}},"commandsResponse":{"zosungSendIRCode03Resp":{"ID":3,"parameters":[{"max":255,"name":"zero","type":32},{"max":65535,"name":"seq","type":33},{"max":4294967295,"name":"position","type":35},{"name":"msgpart","type":65},{"max":255,"name":"msgpartcrc","type":32}]},"zosungSendIRCode05Resp":{"ID":5,"parameters":[{"max":65535,"name":"seq","type":33},{"max":65535,"name":"zero","type":33}]}}}},"custom_clusters":{}}'
[2026-03-26 21:52:38] e[34mdebuge[39m: z2m:mqtt: Received MQTT message on 'zigbee2mqtt/bridge/extensions' with data '[]'
[2026-03-26 21:52:38] e[32minfoe[39m: z2m: Started frontend on port 0.0.0.0:8080
[2026-03-26 21:52:38] e[32minfoe[39m: z2m: Zigbee2MQTT started!
Killed
Je suis sur Debian et Jeedom 4.5.2.
Quelqu un aurait une idée ?
En vous remerciant d avance
David
