PHP Error lors de demande de reboot
v4.2 alpha mise à jour ce matin.
Je demande via menu de reboot Jedoom
Après reboot je regarde mes logs et je trouve cette erreur dans le log http_error
0000|kill: (4503): No such process
0001|kill: (4528): No such process
0002|[Sat Jan 15 10:40:40.476255 2022] [core:notice] [pid 27103] AH00052: child pid 27110 exit signal Segmentation fault (11)
0003|[Sat Jan 15 10:40:40.476337 2022] [core:notice] [pid 27103] AH00052: child pid 28947 exit signal Segmentation fault (11)
0004|[Sat Jan 15 10:40:40.769428 2022] [mpm_prefork:notice] [pid 27103] AH00169: caught SIGTERM, shutting down
0005|[Sat Jan 15 10:40:55.419877 2022] [mpm_prefork:notice] [pid 667] AH00163: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
0006|[Sat Jan 15 10:40:55.434604 2022] [core:notice] [pid 667] AH00094: Command line: '/usr/sbin/apache2'
0007|[Sat Jan 15 10:40:55.614794 2022] [php7:error] [pid 717] [client 192.168.1.250:60835] PHP Fatal error:  Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
0008|Stack trace:
0009|#0 {main}
0010|thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.1.107/index.php?v=d&p=reboot
0011|[Sat Jan 15 10:40:55.634962 2022] [php7:error] [pid 715] [client 192.168.1.250:60853] PHP Fatal error:  Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
0012|Stack trace:
0013|#0 {main}
0014|thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.1.107/index.php?v=d&p=dashboard&object_id=27
0015|[Sat Jan 15 10:40:55.727876 2022] [php7:error] [pid 716] [client 192.168.1.250:60854] PHP Fatal error:  Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
0016|Stack trace:
0017|#0 {main}
0018|thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.1.107/index.php?v=d&p=reboot
0019|[Sat Jan 15 10:40:55.738504 2022] [php7:error] [pid 718] [client 192.168.1.250:60855] PHP Fatal error:  Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
0020|Stack trace:
0021|#0 {main}
0022|thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.1.107/index.php?v=d&p=dashboard&object_id=27
Ça peut arriver le temps que Jeedom finisse de redémarrer
Ok merci. Comme je n’avais jamais vu je pensais a un bug
Ça arrive pas a tous les coups c’est vraiment pendant un très court laps de temps que ça peut arriver
