Hello Mips
Le démon est tombé et impossible de le redémarrer.
Exception in thread Thread-7779:
[2022-04-27 07:12:52][WARNING] : Connection pool is full, discarding connection: api.authentication.husqvarnagroup.dev
Exception in thread Thread-4402:
File "/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py", line 706, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.7/http/client.py", line 1352, in getresponse
response.begin()
File "/usr/lib/python3.7/http/client.py", line 310, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.7/http/client.py", line 279, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py", line 756, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/dist-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.7/dist-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
chunked=chunked,
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/usr/lib/python3.7/threading.py", line 1166, in run
self.function(*self.args, **self.kwargs)
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 257, in _check_if_ws_connected
self._on_ws_failure_callback()
File "/var/www/html/plugins/gardena/resources/gardenad/gardena_handler.py", line 32, in on_ws_failure
self.smart_system.quit()
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 102, in quit
headers={"X-Api-Key": self.client_id},
File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 624, in delete
return self.request('DELETE', url, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 516, in request
method, url, headers=headers, data=data, **kwargs
File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
[2022-04-27 10:20:31][DEBUG] : Signal 15 caught, exiting...
[2022-04-27 10:20:31][INFO] : Shuting down
[2022-04-27 10:20:33][INFO] : Starting daemon
[2022-04-27 10:20:33][INFO] : Log level: debug
[2022-04-27 10:20:33][DEBUG] : Socket port: 55070
[2022-04-27 10:20:33][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:20:33][DEBUG] : Init request module v2.25.1
[2022-04-27 10:20:33][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:20:33][INFO] : Shuting down
[2022-04-27 10:20:33][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:20:33][DEBUG] : Exit 0
[2022-04-27 10:25:03][INFO] : Starting daemon
[2022-04-27 10:25:03][INFO] : Log level: debug
[2022-04-27 10:25:03][DEBUG] : Socket port: 55070
[2022-04-27 10:25:03][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:25:03][DEBUG] : Init request module v2.25.1
[2022-04-27 10:25:04][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:25:04][INFO] : Shuting down
[2022-04-27 10:25:04][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:25:04][DEBUG] : Exit 0
[2022-04-27 10:30:04][INFO] : Starting daemon
[2022-04-27 10:30:04][INFO] : Log level: debug
[2022-04-27 10:30:04][DEBUG] : Socket port: 55070
[2022-04-27 10:30:04][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:30:04][DEBUG] : Init request module v2.25.1
[2022-04-27 10:30:05][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:30:05][INFO] : Shuting down
[2022-04-27 10:30:05][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:30:05][DEBUG] : Exit 0
[2022-04-27 10:35:03][INFO] : Starting daemon
[2022-04-27 10:35:03][INFO] : Log level: debug
[2022-04-27 10:35:03][DEBUG] : Socket port: 55070
[2022-04-27 10:35:03][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:35:03][DEBUG] : Init request module v2.25.1
[2022-04-27 10:35:04][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:35:04][INFO] : Shuting down
[2022-04-27 10:35:04][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:35:04][DEBUG] : Exit 0
[2022-04-27 10:40:04][INFO] : Starting daemon
[2022-04-27 10:40:04][INFO] : Log level: debug
[2022-04-27 10:40:04][DEBUG] : Socket port: 55070
[2022-04-27 10:40:04][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:40:04][DEBUG] : Init request module v2.25.1
[2022-04-27 10:40:05][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:40:05][INFO] : Shuting down
[2022-04-27 10:40:05][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:40:05][DEBUG] : Exit 0
[2022-04-27 10:45:03][INFO] : Starting daemon
[2022-04-27 10:45:03][INFO] : Log level: debug
[2022-04-27 10:45:03][DEBUG] : Socket port: 55070
[2022-04-27 10:45:03][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:45:03][DEBUG] : Init request module v2.25.1
[2022-04-27 10:45:04][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:45:04][INFO] : Shuting down
[2022-04-27 10:45:04][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:45:04][DEBUG] : Exit 0
[2022-04-27 10:50:04][INFO] : Starting daemon
[2022-04-27 10:50:04][INFO] : Log level: debug
[2022-04-27 10:50:04][DEBUG] : Socket port: 55070
[2022-04-27 10:50:04][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:50:04][DEBUG] : Init request module v2.25.1
[2022-04-27 10:50:05][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:50:05][INFO] : Shuting down
[2022-04-27 10:50:05][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:50:05][DEBUG] : Exit 0
[2022-04-27 10:55:03][INFO] : Starting daemon
[2022-04-27 10:55:03][INFO] : Log level: debug
[2022-04-27 10:55:03][DEBUG] : Socket port: 55070
[2022-04-27 10:55:03][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:55:03][DEBUG] : Init request module v2.25.1
[2022-04-27 10:55:04][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 10:55:04][INFO] : Shuting down
[2022-04-27 10:55:04][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 10:55:04][DEBUG] : Exit 0
[2022-04-27 11:00:04][INFO] : Starting daemon
[2022-04-27 11:00:04][INFO] : Log level: debug
[2022-04-27 11:00:04][DEBUG] : Socket port: 55070
[2022-04-27 11:00:04][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 11:00:04][DEBUG] : Init request module v2.25.1
[2022-04-27 11:00:05][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 11:00:05][INFO] : Shuting down
[2022-04-27 11:00:05][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 11:00:05][DEBUG] : Exit 0
[2022-04-27 11:05:03][INFO] : Starting daemon
[2022-04-27 11:05:03][INFO] : Log level: debug
[2022-04-27 11:05:03][DEBUG] : Socket port: 55070
[2022-04-27 11:05:03][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 11:05:03][DEBUG] : Init request module v2.25.1
[2022-04-27 11:05:04][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 11:05:04][INFO] : Shuting down
[2022-04-27 11:05:04][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 11:05:04][DEBUG] : Exit 0
[2022-04-27 11:08:35][INFO] : Starting daemon
[2022-04-27 11:08:35][INFO] : Log level: debug
[2022-04-27 11:08:35][DEBUG] : Socket port: 55070
[2022-04-27 11:08:35][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2022-04-27 11:08:35][DEBUG] : Init request module v2.25.1
[2022-04-27 11:08:35][ERROR] : Fatal error: (missing_token) Missing access token parameter.
[2022-04-27 11:08:35][INFO] : Shuting down
[2022-04-27 11:08:35][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2022-04-27 11:08:35][DEBUG] : Exit 0
Tu as toujours les infos sur le compte Husqvarna.
