depuis quelques jours j’ai des problèmes sur la remontés des Etats de certains devices ikea comme les prises ou certaines ampoules (E27)
les commandes ON/OFF fonctionnent mais l’état ne bouge pas.
j’ai rebranché rebranché mais ca change rien alors que ca fonctionnait.
je suis sur la version beta du plugin et jeedom en 4.2.3
j’ai fait des tests avec une ampoule GU10 d’ikea qui fonctionne bien et sur laquelle j’ai bien l’etat qui remonte:
[2021-09-05 10:16:17][DEBUG] : {"ieee":"00:0b:57:ff:fe:8a:b3:92","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-09-05 10:16:18][DEBUG] : {"ieee":"00:0b:57:ff:fe:8a:b3:92","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-09-05 10:16:18][DEBUG] : {"ieee":"00:0b:57:ff:fe:8a:b3:92","endpoint":1,"cluster":8,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-09-05 10:16:18][DEBUG] : {"devices":{"00:0b:57:ff:fe:8a:b3:92":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}],"8":[{"value":"200","cluster_name":"Level control"}]}}}}
[2021-09-05 10:16:18][DEBUG] : Search attribut for 00:0b:57:ff:fe:8a:b3:92 logicalId : 1::6::0 => Bool.true convert to 1
[2021-09-05 10:16:18][DEBUG] : Search attribut for 00:0b:57:ff:fe:8a:b3:92 logicalId : 1::8::0 => 200 convert to 200
[2021-09-05 10:17:00][DEBUG] : {"ieee":"00:0b:57:ff:fe:8a:b3:92","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2021-09-05 10:17:01][DEBUG] : {"ieee":"00:0b:57:ff:fe:8a:b3:92","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-09-05 10:17:01][DEBUG] : {"ieee":"00:0b:57:ff:fe:8a:b3:92","endpoint":1,"cluster":8,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-09-05 10:17:02][DEBUG] : {"devices":{"00:0b:57:ff:fe:8a:b3:92":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}],"8":[{"value":"200","cluster_name":"Level control"}]}}}}
[2021-09-05 10:17:02][DEBUG] : Search attribut for 00:0b:57:ff:fe:8a:b3:92 logicalId : 1::6::0 => Bool.false convert to 0
[2021-09-05 10:17:02][DEBUG] : Search attribut for 00:0b:57:ff:fe:8a:b3:92 logicalId : 1::8::0 => 200 convert to 200
et avec une prise ca donne ca :
[2021-09-05 10:20:09][DEBUG] : {"ieee":"08:6b:d7:ff:fe:05:75:9d","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-09-05 10:20:18][DEBUG] : {"ieee":"08:6b:d7:ff:fe:05:75:9d","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
je me demande si c’est pas un pb de firmware ikea
