[1/22/2021, 12:22:17 PM] [Jeedom] [DEBUG] eqLogic > {"id":"104","name":"Eclairage Couloir","logicalId":"","generic_type":null,"object_id":"9","eqType_name":"virtual","isVisible":1,"isEnable":1,"order":"1","comment":null,"tags":null,"status":{"lastCommunication":"2021-01-22 12:05:45","timeout":0,"warning":0,"danger":0},"pseudo":"La lumière du couloir","sendToHomebridge":1,"services":{"light":[null,{"state":{"id":"764","logicalId":"","generic_type":"LIGHT_STATE","eqType":"virtual","name":"etat","order":"2","type":"info","subType":"numeric","eqLogic_id":"104","value":"2649","isVisible":1,"alert":{"warningif":"","warningduring":"","dangerif":"","dangerduring":""},"currentValue":0,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}},{"on":{"id":"765","logicalId":"","generic_type":"LIGHT_ON","eqType":"virtual","name":"ON","order":"3","type":"action","subType":"other","eqLogic_id":"104","value":"764","isVisible":1,"alert":[],"display":{"icon":"<i class=\"icon jeedom-lumiere-on\"></i>","invertBinary":0}}},{"off":{"id":"767","logicalId":"","generic_type":"LIGHT_OFF","eqType":"virtual","name":"OFF","order":"4","type":"action","subType":"other","eqLogic_id":"104","value":"764","isVisible":1,"alert":[],"display":{"icon":"<i class=\"icon jeedom-lumiere-off\"></i>","invertBinary":0}}}]}}
[1/22/2021, 12:22:17 PM] [Jeedom] ┌──── Couloir > Eclairage Couloir > pseudo: La lumière du couloir (104)
[1/22/2021, 12:22:17 PM] [Jeedom] [INFO] La lumière n'a pas de variateur
[1/22/2021, 12:22:17 PM] [Jeedom] [INFO] La lumière est du type : Switch
[1/22/2021, 12:22:17 PM] [Jeedom] [DEBUG] Vérification d'existance de l'accessoire dans le cache Homebridge...
[1/22/2021, 12:22:17 PM] [Jeedom] [DEBUG] Accessoire déjà existant dans le cache Homebridge
[1/22/2021, 12:22:17 PM] [Jeedom] [DEBUG] Suppression service :La lumière du couloir subtype:104-764- UUID:00000043-0000-1000-8000-0026BB765291
[1/22/2021, 12:22:17 PM] [Jeedom] [DEBUG] Caractéristique :Name valeur cache:La lumière du couloir
[1/22/2021, 12:22:17 PM] [Jeedom] [DEBUG] Caractéristique :On valeur cache:false
[1/22/2021, 12:22:18 PM] [Jeedom] [DEBUG] Ajout service :La lumière du couloir subtype:104-764- cmd_id:764 UUID:00000043-0000-1000-8000-0026BB765291
[1/22/2021, 12:22:18 PM] [Jeedom] [DEBUG] Caractéristique :On valeur initiale:false
[1/22/2021, 12:22:18 PM] [Jeedom] │ OK : Mise à jour de l'accessoire (La lumière du couloir)
tu peux être plus précis ?
peux tu faire un test :
- avoir l’etat sur le dashboard de ton virtuel + celui dans « Maison » qui sont les mêmes
- modifier l’etat de ta lumière sur l’équipement derrière ton virtuel, constater que cette valeur est bien mise à jour dans ton virtuel sur le dashboard, et puis regarder homebridge_daemon et voir que la commande 764 a recu une mise à jour et que ca met à jour la valeur dans homebridge, puis constater dans « Maison » que c’est bien correct
Avant hier soir un éclairage allumé alors qu’il est bien éteint, Hier je n’ai pas constaté de pb, et ce matin deux équipements, une prise et un éclairage allumé alors qu’ils sont éteints en réel et sur jeedom.
Les trois équipements sont différents et pour les 3 le retour d’état était bon sur jeedom
le test est à faire de chez toi pour être certain d’avoir du temps réel évidemment
Oui bien sûr, j’ai constaté le pb quand j’étais chez moi.
J’utilise Homebridge depuis un moment maintenant et jamais eu le pb
je parle de ce test
Ok je teste ce soir.
tout fonctionne parfaitement…
Le problème est aléatoire donc
ok, donc c’est pas ce que je pensais
(changelog :
Homebridge ne recevra plus les evenements jeedom des commandes appartenant à des équipements non envoyés dans homebridge.)
