Je tourne sur cette version d’OS Linux jeedom 4.4.26-v7+ #915 SMP Thu Oct 20 17:08:44 BST 2016 armv7l GNU/Linux [8.0]
Je suis en version jeedom 3.39 et je viens d’installer la mise à jour du 18/01 du plgin espEaysy et comme d’autres apprement, les dépendances ne s’installent pas correctement.
Voici mes log d’installation des dépendances
Début de l'installation
converted 'https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh' (UTF-8)
--2020-01-27 19:58:21-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... XXX.XXX.XXX.XXX
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|XXX.XXX.XXX.XXX|:XXX... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1491 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 1.86M=0.001s
2020-01-27 19:58:21 (1.86 MB/s) - 'dependencies.sh' saved [1491/1491]
dependencies.sh: 3: [: espeasy: unexpected operator
Nodejs non installé
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit https://deb.nodesource.com jessie InRelease
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit https://deb.nodesource.com jessie/main Sources
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:1 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign http://archive.raspberrypi.org jessie/main Translation-en
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 341 not upgraded.
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
dependencies.sh: 37: [: armv7l: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
## You seem to be using Devuan version jessie.
## This maps to Debian "jessie"... Adjusting for you...
## Confirming "jessie" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/jessie/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
OK
## Creating apt sources list file for the NodeSource Node.js 12.x repo...
+ echo 'deb https://deb.nodesource.com/node_12.x jessie main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_12.x jessie main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nodejs : Depends: libstdc++6 (>= 5.2) but 4.9.2-10 is to be installed
E: Unable to correct problems, you have held broken packages.
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
dependencies.sh: 59: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
J’ai trouvé ce sujet mais je ne suis pas sûr que cela soit exactement le même problème
le (résolu) Pb instalation dépendances Espeasy - Forum Communauté Jeedom
Avant de lancer des commandes en ssh sans savoir ce qu’elles font (et donc faire potentiellement plus de mal que de bien), je fais appel à vous pour avoir vos idées des commandes à passer au vu de mes log.
Quelqu’un pourrait-il m’aider ?
