Pb de génération du cookie alexa
J’ai un pb de génération de cookie depuis quelques jours.
[2021-03-29 14:25:20][INFO] :  Lancement du démon cookie
[2021-03-29 14:25:20][INFO] :  Démon cookie lancé
Alexa-Config - Lancement de /var/www/html/plugins/alexaapi/resources/initCookie.js
{Remote} ║ Use as Login-Amazon-URL: amazon.fr DEBUG
{Remote} ║ Use as Base-URL: alexa.amazon.fr DEBUG
{Remote} ║ No cookie given, generate one !!!!!!!!!!  DEBUG
{Cookie} ║ ┌──────────────────────────────────────────────────────────────────────────────────────────────────── INFO
{Cookie} ║ │        Récupération du Cookie Amazon    INFO
{Cookie} ║ ├──────────────────────────────────────────────────────────────────────────────────────────────────── INFO
{Cookie} ║ │ Use as Login-Amazon-URL: amazon.fr DEBUG
{Cookie} ║ │ Use as Base-Amazon-URL: amazon.com DEBUG
{Cookie} ║ │ Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 DEBUG
{Cookie} ║ │ Use as Accept-Language: fr-FR DEBUG
{Cookie} ║ │ Proxy mode disabled DEBUG
Proxy Init: loaded temp data store ass fallback former data
Proxy Init: reuse frc from former data
Proxy Init: reuse map-md from former data
Proxy Init: reuse deviceId from former data
/var/www/html/plugins/alexaapi/resources/lib/proxy.js:355
const myProxy = proxy('!/cookie-success', optionsAlexa);
TypeError: proxy is not a function
at Object.initAmazonProxy (/var/www/html/plugins/alexaapi/resources/lib/proxy.js:355:21)
at AlexaCookie.generateAlexaCookie (/var/www/html/plugins/alexaapi/resources/lib/alexa-cookie.js:395:25)
at AlexaRemote.generateCookie (/var/www/html/plugins/alexaapi/resources/lib/alexa-remote.js:776:26)
at getCookie (/var/www/html/plugins/alexaapi/resources/lib/alexa-remote.js:127:22)
at AlexaRemote.init (/var/www/html/plugins/alexaapi/resources/lib/alexa-remote.js:176:9)
at Object.<anonymous> (/var/www/html/plugins/alexaapi/resources/initCookie.js:12:7)
at Module._compile (internal/modules/cjs/loader.js:999:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
at Module.load (internal/modules/cjs/loader.js:863:32)
at Function.Module._load (internal/modules/cjs/loader.js:708:14)
Je suis en dernière version bêta.
Merci d’avance
Patrice
Salut il faudrait indiqué version de Jeedom et du plugin
Jeedom 4.1.21
Plugin 2021-03-21 08:54:17
Quelle version d’OS et quelle version de nodejs car votre description n’est pas à jour :wink:
Buster dernière mise à jour effectuée et nodejs 12.20.1
passage vers la stable puis de nouveau vers la beta ??
Passage en stable fixe le pb. J’y reste.
normalement si tu repasse a nouveau en beta ca fonctionnera, il devait rester un fichier ou deux qui trainait et qui ont ete ecrasé par cette mannip
