Pour améliorer la portée de ma Smart Enocean j’essaye d’activer le mode répéteur d’une prise nodon D2-01-0B.
En persévérant j’ai réussi à activer le mode répéteur.
J’ai par ailleurs passé le mode répétition de toutes mes commandes info de ce module en « Répéter toujours » et il semble qu’aucune répétition ne se fasse :
Voici sa config :
Avez vous une idée pour débloquer la situation ? Je n’ai rien vu dans les logs :
[2019-11-25 20:43:40][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:43:40][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:45:02][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 3, 1, 162, 255, 189, 128, 0, 255, 167, 227, 0, 74, 0, 118]
[2019-11-25 20:45:02][DEBUG] : [False, True, True, True]
[2019-11-25 20:45:02][DEBUG] : 01:A2:FF:BD->FF:A7:E3:00 (-74 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x3', '0x1', '0xa2', '0xff', '0xbd', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x4a', '0x0'] OrderedDict()
[2019-11-25 20:45:02][DEBUG] : Message is repeated 0 times
[2019-11-25 20:45:02][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:45:02][DEBUG] : Parsing Packet
[2019-11-25 20:45:02][DEBUG] : Decode data : {"repeat": "0", "dBm": "-74", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 3.0, "MV": {"value": 3.0, "description": "Measurement value", "unit": "", "raw_value": 3}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "01A2FFBD", "manufacturer": "00"}
[2019-11-25 20:45:02][DEBUG] : Send to jeedom : {'devices': {'01A2FFBD': {'repeat': '0', 'dBm': '-74', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 3.0, u'MV': {u'value': 3.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 3}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '01A2FFBD', 'manufacturer': '00'}}}
[2019-11-25 20:45:02][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:45:02][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:45:13][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 71, 0, 216]
[2019-11-25 20:45:13][DEBUG] : [False, True, True, True]
[2019-11-25 20:45:13][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-71 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x47', '0x0'] OrderedDict()
[2019-11-25 20:45:13][DEBUG] : Message is repeated 0 times
[2019-11-25 20:45:13][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:45:13][DEBUG] : Parsing Packet
[2019-11-25 20:45:13][DEBUG] : Decode data : {"repeat": "0", "dBm": "-71", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:45:13][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-71', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:45:13][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:45:13][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:46:46][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 71, 0, 216]
[2019-11-25 20:46:46][DEBUG] : [False, True, True, True]
[2019-11-25 20:46:46][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-71 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x47', '0x0'] OrderedDict()
[2019-11-25 20:46:46][DEBUG] : Message is repeated 0 times
[2019-11-25 20:46:46][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:46:46][DEBUG] : Parsing Packet
[2019-11-25 20:46:46][DEBUG] : Decode data : {"repeat": "0", "dBm": "-71", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:46:46][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-71', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:46:46][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:46:46][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:47:05][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 3, 1, 162, 255, 189, 128, 0, 255, 167, 227, 0, 74, 0, 118]
[2019-11-25 20:47:05][DEBUG] : [False, True, True, True]
[2019-11-25 20:47:05][DEBUG] : 01:A2:FF:BD->FF:A7:E3:00 (-74 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x3', '0x1', '0xa2', '0xff', '0xbd', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x4a', '0x0'] OrderedDict()
[2019-11-25 20:47:05][DEBUG] : Message is repeated 0 times
[2019-11-25 20:47:05][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:47:05][DEBUG] : Parsing Packet
[2019-11-25 20:47:05][DEBUG] : Decode data : {"repeat": "0", "dBm": "-74", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 3.0, "MV": {"value": 3.0, "description": "Measurement value", "unit": "", "raw_value": 3}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "01A2FFBD", "manufacturer": "00"}
[2019-11-25 20:47:06][DEBUG] : Send to jeedom : {'devices': {'01A2FFBD': {'repeat': '0', 'dBm': '-74', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 3.0, u'MV': {u'value': 3.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 3}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '01A2FFBD', 'manufacturer': '00'}}}
[2019-11-25 20:47:06][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:47:06][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:48:19][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 71, 0, 216]
[2019-11-25 20:48:19][DEBUG] : [False, True, True, True]
[2019-11-25 20:48:19][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-71 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x47', '0x0'] OrderedDict()
[2019-11-25 20:48:19][DEBUG] : Message is repeated 0 times
[2019-11-25 20:48:19][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:48:19][DEBUG] : Parsing Packet
[2019-11-25 20:48:19][DEBUG] : Decode data : {"repeat": "0", "dBm": "-71", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:48:19][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-71', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:48:19][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:48:19][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:49:09][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 3, 1, 162, 255, 189, 128, 0, 255, 167, 227, 0, 74, 0, 118]
[2019-11-25 20:49:09][DEBUG] : [False, True, True, True]
[2019-11-25 20:49:09][DEBUG] : 01:A2:FF:BD->FF:A7:E3:00 (-74 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x3', '0x1', '0xa2', '0xff', '0xbd', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x4a', '0x0'] OrderedDict()
[2019-11-25 20:49:09][DEBUG] : Message is repeated 0 times
[2019-11-25 20:49:09][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:49:09][DEBUG] : Parsing Packet
[2019-11-25 20:49:09][DEBUG] : Decode data : {"repeat": "0", "dBm": "-74", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 3.0, "MV": {"value": 3.0, "description": "Measurement value", "unit": "", "raw_value": 3}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "01A2FFBD", "manufacturer": "00"}
[2019-11-25 20:49:09][DEBUG] : Send to jeedom : {'devices': {'01A2FFBD': {'repeat': '0', 'dBm': '-74', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 3.0, u'MV': {u'value': 3.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 3}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '01A2FFBD', 'manufacturer': '00'}}}
[2019-11-25 20:49:09][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:49:09][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:49:52][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 71, 0, 216]
[2019-11-25 20:49:52][DEBUG] : [False, True, True, True]
[2019-11-25 20:49:52][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-71 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x47', '0x0'] OrderedDict()
[2019-11-25 20:49:52][DEBUG] : Message is repeated 0 times
[2019-11-25 20:49:52][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:49:52][DEBUG] : Parsing Packet
[2019-11-25 20:49:52][DEBUG] : Decode data : {"repeat": "0", "dBm": "-71", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:49:52][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-71', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:49:52][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:49:52][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:50:53][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 2, 1, 162, 255, 189, 128, 0, 255, 167, 227, 0, 74, 0, 226]
[2019-11-25 20:50:53][DEBUG] : [False, True, True, True]
[2019-11-25 20:50:53][DEBUG] : 01:A2:FF:BD->FF:A7:E3:00 (-74 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x2', '0x1', '0xa2', '0xff', '0xbd', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x4a', '0x0'] OrderedDict()
[2019-11-25 20:50:53][DEBUG] : Message is repeated 0 times
[2019-11-25 20:50:53][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:50:53][DEBUG] : Parsing Packet
[2019-11-25 20:50:53][DEBUG] : Decode data : {"repeat": "0", "dBm": "-74", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 2.0, "MV": {"value": 2.0, "description": "Measurement value", "unit": "", "raw_value": 2}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "01A2FFBD", "manufacturer": "00"}
[2019-11-25 20:50:53][DEBUG] : Send to jeedom : {'devices': {'01A2FFBD': {'repeat': '0', 'dBm': '-74', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 2.0, u'MV': {u'value': 2.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 2}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '01A2FFBD', 'manufacturer': '00'}}}
[2019-11-25 20:50:53][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:50:53][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:51:25][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 71, 0, 216]
[2019-11-25 20:51:25][DEBUG] : [False, True, True, True]
[2019-11-25 20:51:25][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-71 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x47', '0x0'] OrderedDict()
[2019-11-25 20:51:25][DEBUG] : Message is repeated 0 times
[2019-11-25 20:51:25][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:51:25][DEBUG] : Parsing Packet
[2019-11-25 20:51:25][DEBUG] : Decode data : {"repeat": "0", "dBm": "-71", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:51:25][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-71', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:51:25][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:51:25][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:51:56][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 3, 1, 162, 255, 189, 128, 0, 255, 167, 227, 0, 74, 0, 118]
[2019-11-25 20:51:56][DEBUG] : [False, True, True, True]
[2019-11-25 20:51:56][DEBUG] : 01:A2:FF:BD->FF:A7:E3:00 (-74 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x3', '0x1', '0xa2', '0xff', '0xbd', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x4a', '0x0'] OrderedDict()
[2019-11-25 20:51:56][DEBUG] : Message is repeated 0 times
[2019-11-25 20:51:56][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:51:56][DEBUG] : Parsing Packet
[2019-11-25 20:51:56][DEBUG] : Decode data : {"repeat": "0", "dBm": "-74", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 3.0, "MV": {"value": 3.0, "description": "Measurement value", "unit": "", "raw_value": 3}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "01A2FFBD", "manufacturer": "00"}
[2019-11-25 20:51:56][DEBUG] : Send to jeedom : {'devices': {'01A2FFBD': {'repeat': '0', 'dBm': '-74', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 3.0, u'MV': {u'value': 3.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 3}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '01A2FFBD', 'manufacturer': '00'}}}
[2019-11-25 20:51:56][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:51:56][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:52:58][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 71, 0, 216]
[2019-11-25 20:52:58][DEBUG] : [False, True, True, True]
[2019-11-25 20:52:58][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-71 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x47', '0x0'] OrderedDict()
[2019-11-25 20:52:58][DEBUG] : Message is repeated 0 times
[2019-11-25 20:52:58][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:52:58][DEBUG] : Parsing Packet
[2019-11-25 20:52:58][DEBUG] : Decode data : {"repeat": "0", "dBm": "-71", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:52:58][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-71', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:52:58][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:52:59][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:53:59][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 3, 1, 162, 255, 189, 128, 0, 255, 167, 227, 0, 77, 0, 29]
[2019-11-25 20:53:59][DEBUG] : [False, True, True, True]
[2019-11-25 20:53:59][DEBUG] : 01:A2:FF:BD->FF:A7:E3:00 (-77 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x3', '0x1', '0xa2', '0xff', '0xbd', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x4d', '0x0'] OrderedDict()
[2019-11-25 20:53:59][DEBUG] : Message is repeated 0 times
[2019-11-25 20:53:59][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:53:59][DEBUG] : Parsing Packet
[2019-11-25 20:53:59][DEBUG] : Decode data : {"repeat": "0", "dBm": "-77", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 3.0, "MV": {"value": 3.0, "description": "Measurement value", "unit": "", "raw_value": 3}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "01A2FFBD", "manufacturer": "00"}
[2019-11-25 20:53:59][DEBUG] : Send to jeedom : {'devices': {'01A2FFBD': {'repeat': '0', 'dBm': '-77', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 3.0, u'MV': {u'value': 3.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 3}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '01A2FFBD', 'manufacturer': '00'}}}
[2019-11-25 20:53:59][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:54:00][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
[2019-11-25 20:54:31][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 144, 5, 7, 25, 180, 128, 0, 255, 167, 227, 0, 70, 0, 205]
[2019-11-25 20:54:31][DEBUG] : [False, True, True, True]
[2019-11-25 20:54:31][DEBUG] : 05:07:19:B4->FF:A7:E3:00 (-70 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x90', '0x5', '0x7', '0x19', '0xb4', '0x80'] ['0x0', '0xff', '0xa7', '0xe3', '0x0', '0x46', '0x0'] OrderedDict()
[2019-11-25 20:54:31][DEBUG] : Message is repeated 0 times
[2019-11-25 20:54:31][DEBUG] : Its a VLD message with command : 7
[2019-11-25 20:54:31][DEBUG] : Parsing Packet
[2019-11-25 20:54:31][DEBUG] : Decode data : {"repeat": "0", "dBm": "-70", "IO": {"value": "Output channel 0 (to load)", "description": "I/O channel", "unit": "", "raw_value": 0}, "P1": 144.0, "MV": {"value": 144.0, "description": "Measurement value", "unit": "", "raw_value": 144}, "rorg": "d2", "CMD": {"value": "Command ID 7", "description": "Command indentifier", "unit": "", "raw_value": 7}, "UN": {"value": "Power [W]", "description": "Unit", "unit": "", "raw_value": 3}, "packet_type": "1", "func": "01", "type": "0b", "id": "050719B4", "manufacturer": "00"}
[2019-11-25 20:54:31][DEBUG] : Send to jeedom : {'devices': {'050719B4': {'repeat': '0', 'dBm': '-70', u'IO': {u'value': u'Output channel 0 (to load)', u'description': u'I/O channel', u'unit': u'', u'raw_value': 0}, 'P1': 144.0, u'MV': {u'value': 144.0, u'description': u'Measurement value', u'unit': u'', u'raw_value': 144}, 'rorg': u'd2', u'CMD': {u'value': u'Command ID 7', u'description': u'Command indentifier', u'unit': u'', u'raw_value': 7}, u'UN': {u'value': u'Power [W]', u'description': u'Unit', u'unit': u'', u'raw_value': 3}, 'packet_type': '1', 'func': u'01', 'type': u'0b', 'id': '050719B4', 'manufacturer': '00'}}}
[2019-11-25 20:54:31][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2019-11-25 20:54:31][DEBUG] : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=lGDZ7Ptln1NeSiN4NpK43cfMExt3b6IK HTTP/1.1" 200 0
