Ah. Bon et bien on en apprend tous les jours,merci. Peut etre que reset le contrôleur serait la bonne solution ?
Voici les logs :
Log zwavejs
[2024-12-16 11:01:00] INFO : Arrêt du démon ZwaveJS
[2024-12-16 11:02:30] INFO : Arrêt du démon ZwaveJS
[2024-12-16 11:02:30] DEBUG : [configureSettings] Informations reçues de MQTT Manager : {"ip":"127.0.0.1","port":"1883","protocol":"mqtt","user":"jeedom","password":"khKJVDnF4IkwAQiP1G0VkpBKHvqpVvKU1oEMzRFzcsJ6eyRevToVNKZ6K6wjBVRQ"}
[2024-12-16 11:02:30] INFO : Démarrage du démon ZwaveJS : STORE_DIR=/var/www/html/plugins/zwavejs/data/store KEY_S0_Legacy=84B2E2FC6E42B99CF262DF748117ED62 KEY_S2_Unauthenticated=85811031AE4A7AEC2F8DF102DCDAB0A5 KEY_S2_Authenticated=0CBE787CE0C1D4AF9186D4D2A2EF3C0F KEY_S2_AccessControl=A6999161ACC978657D9AE5B3BF738583 SESSION_SECRET=jeedomSession npm start
log zwawejs_package
Log brut
+ touch /tmp/jeedom_install_in_progress_zwavejs
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ echo 'Pre installation de l'\''installation/mise à jour des dépendances zwavejs'
Pre installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
++ cd /var/www/html/core/class/../../plugins/zwavejs/resources
++ pwd
+ BASEDIR=/var/www/html/plugins/zwavejs/resources
+ cd /var/www/html/plugins/zwavejs/resources
+ source ../core/config/zwavejs.config.ini
+ echo 'Wanted Version: 9.20.0'
+ rm -R zwave-js-ui
rm: cannot remove 'zwave-js-ui': No such file or directory
+ git clone --branch v9.20.0 --depth 1 https://github.com/zwave-js/zwave-js-ui
Cloning into 'zwave-js-ui'...
Note: checking out 'bf3bdc3f13d903cf100b0ba9c3333101ffd29418'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
+ echo 'Pre install finished'
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
apt: no process found
apt-get: no process found
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Hit:2 http://ftp.fr.debian.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Fetched 34.8 kB in 2s (16.2 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
apt-utils is already the newest version (1.8.2.3).
build-essential is already the newest version (12.6).
lsb-release is already the newest version (10.2019051400).
lsb-release set to manually installed.
git is already the newest version (1:2.20.1-2+deb10u9).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[Check Version NodeJS actuelle : Aucune : [ KO ]
Installation de NodeJS 18
Utilisation du dépot officiel
deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
nodejs
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 29.6 MB of archives.
After this operation, 187 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.20.5-1nodesource1 [29.6 MB]
Fetched 29.6 MB in 6s (4584 kB/s)
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 65469 files and directories currently installed.)
Preparing to unpack .../nodejs_18.20.5-1nodesource1_amd64.deb ...
Unpacking nodejs (18.20.5-1nodesource1) ...
Setting up nodejs (18.20.5-1nodesource1) ...
Processing triggers for man-db (2.8.5-2+deb10u1) ...
[Check Version NodeJS après install : v18.20.5 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
[Check Version NodeJS actuelle : v18.20.5 : [ OK ]
--2024-12-16 09:56:46-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 54.36.53.46, 2001:41d0:302:1100::8:104f
Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58444 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 87% 427K 0s
50K ....... 100% 36.9M=0.1s
2024-12-16 09:56:47 (487 KB/s) - 'composer-setup.php' saved [58444/58444]
Begin installation of composer
All settings correct for using Composer
Downloading...
Composer (version 2.8.4) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
added 121 packages, and audited 122 packages in 26s
21 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Generating RSA private key, 2048 bit long modulus (2 primes)
e is 65537 (0x010001)
Signature ok
subject=C = FR, ST = Paris, L = Paris, O = jeedom, CN = jeedom-mosquitto
Getting CA Private Key
chmod: cannot access '/var/www/html/plugins/mqtt2/core/class/../../data/mosquitto.conf': No such file or directory
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
+ echo 4
+ sudo apt update
+ echo 5
Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:3 http://ftp.fr.debian.org/debian buster InRelease
+ echo 6
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ echo 'Post installation de l'\''installation/mise à jour des dépendances zwavejs'
Post installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
++ pwd
+ cd zwave-js-ui
+ sudo npm install
npm warn deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm warn deprecated docsify-server-renderer@4.13.1: docsify-server-renderer 4.x and below is no longer supported while we investigate the future of SSR and SSG for Docsify
npm warn deprecated csurf@1.11.0: Please use another csrf package
npm warn deprecated @types/extract-zip@2.0.1: This is a stub types definition. extract-zip provides its own type definitions, so you do not need this installed.
npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
npm warn deprecated @humanwhocodes/config-array@0.11.14: Use @eslint/config-array instead
npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
npm warn deprecated vue@2.7.16: Vue 2 has reached EOL and is no longer actively maintained. See https://v2.vuejs.org/eol/ for more details.
added 1681 packages, and audited 1682 packages in 1m
335 packages are looking for funding
29 vulnerabilities (11 low, 13 moderate, 5 high)
To address issues that do not require attention, run:
npm audit fix
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
+ sudo npm run build
> zwave-js-ui@9.20.0 build
> npm-run-all 'build:*'
> zwave-js-ui@9.20.0 build:server
> tsc
> zwave-js-ui@9.20.0 build:ui
> vite build
vite v5.3.1 building for production...
transforming...
✓ 547 modules transformed.
rendering chunks...
computing gzip size...
dist/registerSW.js 0.14 kB
dist/manifest.webmanifest 0.50 kB
dist/index.html 1.69 kB │ gzip: 0.74 kB
dist/assets/MaterialIcons-Regular-DOtZ65Va.woff2 125.12 kB
dist/assets/MaterialIcons-Regular-BjXOXp5c.eot 143.45 kB
dist/assets/MaterialIcons-Regular-FsbMSDLx.woff 160.58 kB
dist/assets/MaterialIcons-Regular-DEUTIz1o.ttf 347.59 kB
dist/assets/DialogHealthCheck-Droliepd.css 0.04 kB │ gzip: 0.06 kB
dist/assets/DialogGatewayValue-A-SkCATO.css 0.06 kB │ gzip: 0.08 kB
dist/assets/NodeDetails-CBP3OPmg.css 0.06 kB │ gzip: 0.08 kB
dist/assets/FrameDetails-CIQ12EOu.css 0.07 kB │ gzip: 0.09 kB
dist/assets/QrReader-HjYxZaii.css 0.09 kB │ gzip: 0.10 kB
dist/assets/NodePanel-CZwLOHLG.css 0.09 kB │ gzip: 0.10 kB
dist/assets/RichValue-B_0TC6eQ.css 0.13 kB │ gzip: 0.12 kB
dist/assets/CCTreeView-WxmqzfXk.css 0.13 kB │ gzip: 0.12 kB
dist/assets/Settings-DbLZdPoT.css 0.15 kB │ gzip: 0.14 kB
dist/assets/Mesh-DSRRNttk.css 0.27 kB │ gzip: 0.21 kB
dist/assets/ValueId-C5xZLsvS.css 0.31 kB │ gzip: 0.18 kB
dist/assets/ExpandedNode--E63FB__.css 0.39 kB │ gzip: 0.26 kB
dist/assets/DialogAdvanced-B3IdLJdP.css 0.45 kB │ gzip: 0.23 kB
dist/assets/index-D5uuzJlz.css 0.51 kB │ gzip: 0.18 kB
dist/assets/Zniffer-BYjnQyPs.css 0.53 kB │ gzip: 0.24 kB
dist/assets/Store-DS7bGYpj.css 0.79 kB │ gzip: 0.33 kB
dist/assets/Multipane-CEm3CnxI.css 1.57 kB │ gzip: 0.46 kB
dist/assets/BgRssiChart-DbNj0r-M.css 1.65 kB │ gzip: 0.71 kB
dist/assets/Login-1yco1U5P.css 5.43 kB │ gzip: 1.52 kB
dist/assets/ZwaveGraph-Dfn_CqSH.css 220.21 kB │ gzip: 31.03 kB
dist/assets/index-r8JReBOx.css 645.00 kB │ gzip: 86.98 kB
dist/assets/MultipaneResizer-BWRp-8Tf.js 0.23 kB │ gzip: 0.20 kB
dist/assets/InvertedCheckbox-BKe96SLH.js 0.42 kB │ gzip: 0.30 kB
dist/assets/ControllerChart-7GxoToPo.js 0.63 kB │ gzip: 0.39 kB
dist/assets/ColumnFilterBoolean-Dlw5IVbg.js 0.67 kB │ gzip: 0.42 kB
dist/assets/ReinterviewBadge-P-jUEJlg.js 0.78 kB │ gzip: 0.52 kB
dist/assets/BlinkIcon-DP_t2iuE.js 0.85 kB │ gzip: 0.42 kB
dist/assets/ColumnFilterDate-DkQZJt-f.js 1.16 kB │ gzip: 0.56 kB
dist/assets/MissingKeysAlert-Bgdg8v4b.js 1.17 kB │ gzip: 0.56 kB
dist/assets/ColumnFilterString-BIwSCVLZ.js 1.22 kB │ gzip: 0.62 kB
dist/assets/DialogAdvanced-Bhs_8BWn.js 1.30 kB │ gzip: 0.68 kB
dist/assets/CCTreeView-ChRxhkA3.js 1.43 kB │ gzip: 0.77 kB
dist/assets/StatisticsArrows-BI8z0kpo.js 1.44 kB │ gzip: 0.77 kB
dist/assets/ErrorPage-CQyeMUEl.js 1.55 kB │ gzip: 0.79 kB
dist/assets/Multipane-DFLS9oP2.js 1.63 kB │ gzip: 0.82 kB
dist/assets/ColumnFilterNumber-eClVU_w_.js 1.74 kB │ gzip: 0.74 kB
dist/assets/file-input-B4SR49dD.js 1.83 kB │ gzip: 0.86 kB
dist/assets/RichValue-BRQppQoo.js 2.04 kB │ gzip: 0.87 kB
dist/assets/StatisticsCard-DqAruet3.js 2.55 kB │ gzip: 1.00 kB
dist/assets/FrameDetails-F6k0BPq5.js 2.68 kB │ gzip: 1.06 kB
dist/assets/DialogSceneValue-2Y04CTd_.js 3.18 kB │ gzip: 1.23 kB
dist/assets/Mesh-haZu0lAF.js 3.18 kB │ gzip: 1.36 kB
dist/assets/ColumnFilter-DoUVVYSw.js 3.26 kB │ gzip: 1.30 kB
dist/assets/UserCodeTable-Dz40xPSc.js 4.12 kB │ gzip: 1.64 kB
dist/assets/Login-DT9nslnM.js 4.13 kB │ gzip: 1.64 kB
dist/assets/ListInput-DK0gk4Ui.js 4.38 kB │ gzip: 1.41 kB
dist/assets/AssociationGroups-DGsCpLMi.js 4.46 kB │ gzip: 1.65 kB
dist/assets/OTAUpdates-BDNMxnyc.js 5.09 kB │ gzip: 2.09 kB
dist/assets/Scenes-HsjDySf8.js 5.81 kB │ gzip: 1.98 kB
dist/assets/DialogLinkReliability-3FOnnyOC.js 5.89 kB │ gzip: 1.91 kB
dist/assets/DialogAssociation-CvDSlRuw.js 5.94 kB │ gzip: 2.10 kB
dist/assets/prismeditor.esm-DJCfCG3y.js 7.58 kB │ gzip: 2.69 kB
dist/assets/NodeScheduler-qahfvCd7.js 7.86 kB │ gzip: 2.60 kB
dist/assets/HomeAssistant-CmWDVy9b.js 8.23 kB │ gzip: 2.43 kB
dist/assets/DialogGatewayValue-TQV4M_Uw.js 8.38 kB │ gzip: 2.56 kB
dist/assets/ControlPanel-CIT7JoKr.js 9.53 kB │ gzip: 3.53 kB
dist/assets/SmartView-VDBxTG-G.js 9.89 kB │ gzip: 3.30 kB
dist/assets/ValueId-Dzj-_hV-.js 10.45 kB │ gzip: 2.92 kB
dist/assets/Store-CE_bHZL9.js 10.95 kB │ gzip: 3.41 kB
dist/assets/NodeDetails-Dwklj2UX.js 12.18 kB │ gzip: 3.39 kB
dist/assets/DialogHealthCheck-DX70lQ06.js 12.38 kB │ gzip: 3.59 kB
dist/assets/SmartStart-DcNO40LA.js 13.83 kB │ gzip: 3.91 kB
dist/assets/ExpandedNode-Dip24ge3.js 15.15 kB │ gzip: 5.18 kB
dist/assets/Debug-0FVl0EX8.js 16.04 kB │ gzip: 4.18 kB
dist/assets/NodePanel-zK1ErbaX.js 16.11 kB │ gzip: 4.39 kB
dist/assets/Zniffer-DaFxRe8b.js 16.23 kB │ gzip: 5.28 kB
dist/assets/index-CGscpZTT.js 20.82 kB │ gzip: 6.13 kB
dist/assets/QrReader-C-Xpoqpd.js 20.89 kB │ gzip: 7.29 kB
dist/assets/qr-scanner-worker.min-D85Z9gVD.js 43.95 kB │ gzip: 10.46 kB
dist/assets/BgRssiChart-CjfwkkIu.js 54.97 kB │ gzip: 24.29 kB
dist/assets/vuedraggable.umd-BN2_1K0c.js 71.01 kB │ gzip: 24.88 kB
dist/assets/Settings-_GIJ6yNR.js 85.81 kB │ gzip: 19.99 kB
dist/assets/index-Blr6EMNg.js 91.82 kB │ gzip: 46.05 kB
dist/assets/ZwaveGraph-B7ZU-Qa8.js 560.41 kB │ gzip: 166.47 kB
dist/assets/index-arJYOLrt.js 1,237.32 kB │ gzip: 338.96 kB
(!) Some chunks are larger than 500 kB after minification. Consider:
- Using dynamic import() to code-split the application
- Use build.rollupOptions.output.manualChunks to improve chunking: https://rollupjs.org/configuration-options/#output-manualchunks
- Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
✓ built in 35.74s
PWA v0.20.0
Building src/sw.js service worker ("es" format)...
transforming...
✓ 65 modules transformed.
rendering chunks...
dist/sw.mjs 16.17 kB │ gzip: 5.42 kB
✓ built in 559ms
PWA v0.20.0
mode injectManifest
format: es
precache 82 entries (3262.43 KiB)
files generated
dist/sw.js
+ chown -R www-data:www-data CHANGELOG.md LICENSE README.md SECURITY.md api certs dist docker docs esbuild-register.js esbuild.js genereteDocs.ts index.html kubernetes kustomization.yaml node_modules nodemon.json package-lock.json package.json package.sh pkg public server server_config.js snippets src store test tsconfig.eslint.json tsconfig.json vite.config.mjs wallaby.js
+ '[' -e /dev/ttyAMA0 ']'
+ '[' -e /dev/ttymxc0 ']'
++ cut -d: -f2
++ grep Revision /proc/cpuinfo
++ tr -d ' '
+ RPI_BOARD_REVISION=
+ [[ '' == \a\0\2\0\8\2 ]]
+ [[ '' == \a\2\2\0\8\2 ]]
+ [[ '' == \a\0\2\0\d\3 ]]
+ echo 'Everything is successfully installed!'
+ echo 7
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zwavejs
+ echo 8
+ rm /tmp/jeedom_install_in_progress_zwavejs
log zwavejsd
Log brut
> zwave-js-ui@9.20.0 start
> node --preserve-symlinks server/bin/www.js
e[90m2024-12-16 10:20:48.260e[39m e[32mINFOe[39m e[1mAPPe[22m: Version: 9.20.0.bf3bdc3
e[90m2024-12-16 10:20:48.267e[39m e[32mINFOe[39m e[1mAPPe[22m: Application path:/var/www/html/plugins/zwavejs/resources/zwave-js-ui
______ __ __ _ _____ _ _ _____
|___ / \ \ / / | |/ ____| | | | |_ _|
/ /____\ \ /\ / /_ ___ _____ | | (___ | | | | | |
/ /______\ \/ \/ / _' \ \ / / _ \ _ | |\___ \ | | | | | |
/ /__ \ /\ / (_| |\ V / __/ | |__| |____) | | |__| |_| |_
/_____| \/ \/ \__,_| \_/ \___| \____/|_____/ \____/|_____|
e[90m2024-12-16 10:20:48.303e[39m e[33mWARNe[39m e[1mSTOREe[22m: scenes.json not found
e[90m2024-12-16 10:20:48.305e[39m e[33mWARNe[39m e[1mSTOREe[22m: nodes.json not found
e[90m2024-12-16 10:20:48.306e[39m e[33mWARNe[39m e[1mSTOREe[22m: users.json not found
e[90m2024-12-16 11:02:35.349e[39m e[32mINFOe[39m e[1mAPPe[22m: Version: 9.20.0.bf3bdc3
e[90m2024-12-16 11:02:35.358e[39m e[32mINFOe[39m e[1mAPPe[22m: Application path:/var/www/html/plugins/zwavejs/resources/zwave-js-ui
e[90m2024-12-16 11:02:35.387e[39m e[33mWARNe[39m e[1mSTOREe[22m: scenes.json not found
