Bonjour, j’ai une Blitzwolf BW-SHP13 connecté via un dongle USB ELAPS, tout fonctionne bien sauf la puissance qui reste toujours à 0.
C’est peut être normal, j’ai réactivé le daemon, mon plugin est à jour d’hier soir, j’ai ré-inclu la prise .
Voici la copie d’écran des commandes, d la configuration du noeud et du json.
"ieee": "84:2e:14:ff:fe:3b:83:0f",
"nwk": 15894,
"status": 2,
"lqi": "161",
"rssi": "-56",
"last_seen": "1613141721.9488928",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZ3000_g5xawfcq",
"model": "TS0121",
"output_clusters": [
"id": 10,
"name": "Time",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 65
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_g5xawfcq"
"id": 5,
"name": "model",
"value": "TS0121"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"name": "off_wait_time",
"value": 0
"id": 32770,
"name": "power_on_state",
"value": 2
"id": 1794,
"name": "Metering",
"attributes": [
"id": 0,
"name": "current_summ_delivered",
"value": 5522
"id": 2820,
"name": "Electrical Measurement",
"attributes": [
"id": 1291,
"name": "active_power",
"value": 0
"signature": {
"model": "TS0121",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
4,
5,
6,
1794,
2820
10,
25
"class": "zhaquirks.tuya.plug"
