Pas de remontée des Device
je viens de faire une nouvelle installation Jeedom sur un debian 12.
j’ai installé le plugin wifilight beta et configuré l’acces id pour Tuya. je n’ai aucun appareil qui remonte quand je fais l’inclusion, pourtant dans le fichier log_inc il trouve bien des appareils et la plateforme tuya utilisée pour certains appareils.
Voici les log.
merci de votre aide.
[2026-01-07 12:08:17][DEBUG] Tuya cloud
[2026-01-07 12:08:17][DEBUG] try:openapi.tuyaeu.com
[2026-01-07 12:08:17][DEBUG] session token:9fb10b40863388859e03da832b9984a3
[2026-01-07 12:08:17][DEBUG] >> Search devices in local network by broadcast
[2026-01-07 12:08:19][DEBUG] Device found @192.168.129.16 len mess:172
[2026-01-07 12:08:19][DEBUG]  try 3.3 or 3.4
[2026-01-07 12:08:20][DEBUG]  cmd:13 - {"ip":"192.168.129.16","gwId":"bfa4ae31293451ce67vicz","active":2,"ablilty":0,"encrypt":true,"productKey":"keyfa7hya4gfa7g9","version":"3.3"}     ip|192.168.129.16 gwId|bfa4ae31293451ce67vicz active|2 ablilty|0 encrypt|1 productKey|keyfa7hya4gfa7g9 version|3.3 ip|192.168.129.16 gwId|bfa4ae31293451ce67vicz active|2 ablilty|0 encrypt|1 productKey|keyfa7hya4gfa7g9 version|3.3  - Read Json OK
[2026-01-07 12:08:20][DEBUG]  info:{"ip":"192.168.129.16","gwId":"bfa4ae31293451ce67vicz","active":2,"ablilty":0,"encrypt":true,"productKey":"keyfa7hya4gfa7g9","version":"3.3"}
[2026-01-07 12:08:20][DEBUG]  version found:3.3
[2026-01-07 12:08:21][DEBUG]  wait 7 s
[2026-01-07 12:08:21][DEBUG] Device found @192.168.129.7 len mess:172
[2026-01-07 12:08:21][DEBUG]  try 3.3 or 3.4
[2026-01-07 12:08:23][DEBUG]  cmd:13 - {"ip":"192.168.129.7","gwId":"bf10dce7fcc6fc6f7cydz8","active":2,"ablilty":0,"encrypt":true,"productKey":"key3pw4guvnat9ad","version":"3.3"}     ip|192.168.129.7 gwId|bf10dce7fcc6fc6f7cydz8 active|2 ablilty|0 encrypt|1 productKey|key3pw4guvnat9ad version|3.3 ip|192.168.129.7 gwId|bf10dce7fcc6fc6f7cydz8 active|2 ablilty|0 encrypt|1 productKey|key3pw4guvnat9ad version|3.3  - Read Json OK
[2026-01-07 12:08:23][DEBUG]  info:{"ip":"192.168.129.7","gwId":"bf10dce7fcc6fc6f7cydz8","active":2,"ablilty":0,"encrypt":true,"productKey":"key3pw4guvnat9ad","version":"3.3"}
[2026-01-07 12:08:23][DEBUG]  version found:3.3
[2026-01-07 12:08:23][DEBUG]  wait 4 s
[2026-01-07 12:08:23][DEBUG] Device found @192.168.129.21 len mess:172
[2026-01-07 12:08:23][DEBUG]  try 3.3 or 3.4
[2026-01-07 12:08:23][DEBUG]  cmd:13 - {"ip":"192.168.129.21","gwId":"bf601f0adb2bd976d8gxhh","active":2,"ablilty":0,"encrypt":true,"productKey":"key3nrmwvtsdc7ty","version":"3.3"}     ip|192.168.129.21 gwId|bf601f0adb2bd976d8gxhh active|2 ablilty|0 encrypt|1 productKey|key3nrmwvtsdc7ty version|3.3 ip|192.168.129.21 gwId|bf601f0adb2bd976d8gxhh active|2 ablilty|0 encrypt|1 productKey|key3nrmwvtsdc7ty version|3.3  - Read Json OK
[2026-01-07 12:08:23][DEBUG]  info:{"ip":"192.168.129.21","gwId":"bf601f0adb2bd976d8gxhh","active":2,"ablilty":0,"encrypt":true,"productKey":"key3nrmwvtsdc7ty","version":"3.3"}
[2026-01-07 12:08:26][DEBUG]  wait 1 s
[2026-01-07 12:08:27][DEBUG] Devices found on local network:{"addresses":["192.168.129.16","192.168.129.7","192.168.129.21"],"version":["3.3","3.3","3.3"],"id":["bfa4ae31293451ce67vicz","bf10dce7fcc6fc6f7cydz8","bf601f0adb2bd976d8gxhh"]}
Donner le _inc complet, s’il ne l’est pas
il est complet
Jeedom 4.5 ?
Regarder dans les logs http.error et logs cron_execution s’il n’y a pas une trace d’erreur wifilightV2.
recharger la beta
effacer _inc
refaire inclusion
me donner _inc
Oui Jeedom 4.5
j’ai bien une erreur dans http.error :
Created directory: /var/lib/snmp/cert_indexes
[Wed Jan 07 09:30:34.045295 2026] [mpm_prefork:notice] [pid 23454:tid 23454] AH00163: Apache/2.4.65 (Debian) configured -- resuming normal operations
[Wed Jan 07 09:30:34.045504 2026] [core:notice] [pid 23454:tid 23454] AH00094: Command line: '/usr/sbin/apache2'
[Wed Jan 07 09:35:43.288175 2026] [mpm_prefork:notice] [pid 23454:tid 23454] AH00170: caught SIGWINCH, shutting down gracefully
[Wed Jan 07 09:36:54.319526 2026] [mpm_prefork:notice] [pid 697:tid 697] AH00163: Apache/2.4.65 (Debian) configured -- resuming normal operations
[Wed Jan 07 09:36:54.339063 2026] [core:notice] [pid 697:tid 697] AH00094: Command line: '/usr/sbin/apache2'
sh: 1: cd: can't cd to /opt/zigbee2mqtt
warning: commands will be executed using /bin/sh
job 2 at Wed Jan  7 09:52:00 2026
[Wed Jan 07 09:56:16.715558 2026] [mpm_prefork:notice] [pid 697:tid 697] AH00170: caught SIGWINCH, shutting down gracefully
[Wed Jan 07 09:56:18.174431 2026] [mpm_prefork:notice] [pid 6337:tid 6337] AH00163: Apache/2.4.65 (Debian) configured -- resuming normal operations
[Wed Jan 07 09:56:18.174612 2026] [core:notice] [pid 6337:tid 6337] AH00094: Command line: '/usr/sbin/apache2'
kill: (10226): No such process
[Wed Jan 07 10:22:10.052730 2026] [php:error] [pid 6345:tid 6345] [client 192.168.129.2:51499] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2
job 3 at Wed Jan  7 10:25:00 2026
kill: (13214): No such process
[Wed Jan 07 10:28:48.848667 2026] [php:error] [pid 6341:tid 6341] [client 192.168.129.2:54912] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&p=wifilightV2&m=wifilightV2&id=wifilightV2
kill: (13286): No such process
[Wed Jan 07 10:34:52.707997 2026] [php:error] [pid 6367:tid 6367] [client 192.168.129.2:63943] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&p=wifilightV2&m=wifilightV2&id=undefined
[Wed Jan 07 10:50:16.290610 2026] [php:error] [pid 14226:tid 14226] [client 192.168.129.2:49332] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&p=wifilightV2&m=wifilightV2
[Wed Jan 07 11:02:26.558321 2026] [php:error] [pid 16133:tid 16133] [client 192.168.129.2:51947] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&p=wifilightV2&m=wifilightV2&id=wifilightV2
[Wed Jan 07 11:02:35.364944 2026] [php:error] [pid 6342:tid 6342] [client 192.168.129.2:63209] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&p=wifilightV2&m=wifilightV2&id=wifilightV2
kill: (18912): No such process
job 4 at Wed Jan  7 11:06:00 2026
[Wed Jan 07 11:10:42.130039 2026] [php:error] [pid 6351:tid 6351] [client 192.168.129.2:59059] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2272\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2272): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2272, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 11:18:06.831614 2026] [php:error] [pid 6368:tid 6368] [client 192.168.129.2:65531] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 11:38:59.232964 2026] [php:error] [pid 6367:tid 6367] [client 192.168.129.2:65038] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 11:39:05.249497 2026] [php:error] [pid 18851:tid 18851] [client 192.168.129.2:58432] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 11:49:59.266476 2026] [php:error] [pid 23638:tid 23638] [client 192.168.129.2:62811] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 11:50:02.724646 2026] [php:error] [pid 16133:tid 16133] [client 192.168.129.2:56764] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 12:08:27.580147 2026] [php:error] [pid 6351:tid 6351] [client 192.168.129.2:51375] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
job 5 at Wed Jan  7 12:51:00 2026
kill: (38897): No such process
[Wed Jan 07 12:55:56.944166 2026] [php:error] [pid 16133:tid 16133] [client 192.168.129.2:59627] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 14:24:53.632774 2026] [php:error] [pid 6368:tid 6368] [client 192.168.129.2:52296] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 14:25:33.947667 2026] [php:error] [pid 33767:tid 33767] [client 192.168.129.2:52599] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 14:25:36.415622 2026] [php:error] [pid 23638:tid 23638] [client 192.168.129.2:63802] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 14:26:47.561736 2026] [php:error] [pid 33767:tid 33767] [client 192.168.129.2:62458] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
[Wed Jan 07 14:26:47.639518 2026] [php:error] [pid 9594:tid 9594] [client 192.168.129.2:57249] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2281\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2281): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2281, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2&id=wifilightV2
kill: (39022): No such process
[Wed Jan 07 14:42:39.464531 2026] [php:error] [pid 33767:tid 33767] [client 192.168.129.2:53041] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2284\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2284): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2284, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2
voici le nouveau log_inc
[2026-01-07 14:42:28][DEBUG] Tuya cloud
[2026-01-07 14:42:28][DEBUG] try:openapi.tuyaeu.com
[2026-01-07 14:42:29][DEBUG] session token:288ce25e7b7b5562b161848309ac3090
[2026-01-07 14:42:29][DEBUG] >> Search devices in local network by broadcast
[2026-01-07 14:42:31][DEBUG] Device found @192.168.129.7 len mess:172
[2026-01-07 14:42:31][DEBUG]  try 3.3 or 3.4
[2026-01-07 14:42:31][DEBUG]  cmd:13 - {"ip":"192.168.129.7","gwId":"bf10dce7fcc6fc6f7cydz8","active":2,"ablilty":0,"encrypt":true,"productKey":"key3pw4guvnat9ad","version":"3.3"}     ip|192.168.129.7 gwId|bf10dce7fcc6fc6f7cydz8 active|2 ablilty|0 encrypt|1 productKey|key3pw4guvnat9ad version|3.3 ip|192.168.129.7 gwId|bf10dce7fcc6fc6f7cydz8 active|2 ablilty|0 encrypt|1 productKey|key3pw4guvnat9ad version|3.3  - Read Json OK
[2026-01-07 14:42:31][DEBUG]  info:{"ip":"192.168.129.7","gwId":"bf10dce7fcc6fc6f7cydz8","active":2,"ablilty":0,"encrypt":true,"productKey":"key3pw4guvnat9ad","version":"3.3"}
[2026-01-07 14:42:31][DEBUG]  version found:3.3
[2026-01-07 14:42:31][DEBUG] Device found @192.168.129.21 len mess:172
[2026-01-07 14:42:31][DEBUG]  cmd:13 - {"ip":"192.168.129.21","gwId":"bf601f0adb2bd976d8gxhh","active":2,"ablilty":0,"encrypt":true,"productKey":"key3nrmwvtsdc7ty","version":"3.3"}     ip|192.168.129.21 gwId|bf601f0adb2bd976d8gxhh active|2 ablilty|0 encrypt|1 productKey|key3nrmwvtsdc7ty version|3.3 ip|192.168.129.21 gwId|bf601f0adb2bd976d8gxhh active|2 ablilty|0 encrypt|1 productKey|key3nrmwvtsdc7ty version|3.3  - Read Json OK
[2026-01-07 14:42:31][DEBUG]  info:{"ip":"192.168.129.21","gwId":"bf601f0adb2bd976d8gxhh","active":2,"ablilty":0,"encrypt":true,"productKey":"key3nrmwvtsdc7ty","version":"3.3"}
[2026-01-07 14:42:32][DEBUG]  wait 7 s
[2026-01-07 14:42:32][DEBUG] Device found @192.168.129.16 len mess:172
[2026-01-07 14:42:32][DEBUG]  try 3.3 or 3.4
[2026-01-07 14:42:32][DEBUG]  cmd:13 - {"ip":"192.168.129.16","gwId":"bfa4ae31293451ce67vicz","active":2,"ablilty":0,"encrypt":true,"productKey":"keyfa7hya4gfa7g9","version":"3.3"}     ip|192.168.129.16 gwId|bfa4ae31293451ce67vicz active|2 ablilty|0 encrypt|1 productKey|keyfa7hya4gfa7g9 version|3.3 ip|192.168.129.16 gwId|bfa4ae31293451ce67vicz active|2 ablilty|0 encrypt|1 productKey|keyfa7hya4gfa7g9 version|3.3  - Read Json OK
[2026-01-07 14:42:32][DEBUG]  info:{"ip":"192.168.129.16","gwId":"bfa4ae31293451ce67vicz","active":2,"ablilty":0,"encrypt":true,"productKey":"keyfa7hya4gfa7g9","version":"3.3"}
[2026-01-07 14:42:32][DEBUG]  version found:3.3
[2026-01-07 14:42:35][DEBUG]  wait 4 s
[2026-01-07 14:42:38][DEBUG]  wait 1 s
[2026-01-07 14:42:39][DEBUG] Devices found on local network:{"addresses":["192.168.129.7","192.168.129.21","192.168.129.16"],"version":["3.3","3.3","3.3"],"id":["bf10dce7fcc6fc6f7cydz8","bf601f0adb2bd976d8gxhh","bfa4ae31293451ce67vicz"]}
[2026-01-07 14:42:39][DEBUG] start Tuya cloud request
Merci de votre aide
me donner le n° de ligne d’erreur avec la nouvelle beta
apparemment 2284
[Wed Jan 07 14:57:02.537261 2026] [php:error] [pid 6351:tid 6351] [client 192.168.129.2:60020] PHP Fatal error:  Uncaught TypeError: end(): Argument #1 ($array) must be of type array, null given in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php:2284\nStack trace:\n#0 /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php(2284): end()\n#1 /var/www/html/plugins/wifilightV2/core/ajax/wifilightV2.ajax.php(43): wifilightV2::IncludeTuya()\n#2 {main}\n  thrown in /var/www/html/plugins/wifilightV2/core/class/wifilightV2.class.php on line 2284, referer: http://192.168.129.226/index.php?v=d&m=wifilightV2&p=wifilightV2
reprendre beta
faire inclusion
me donner le _inc
Désolé,
reprendre beta de 15h25
Voici;
[2026-01-07 15:35:34][DEBUG] Tuya cloud
[2026-01-07 15:35:34][DEBUG] try:openapi.tuyaeu.com
[2026-01-07 15:35:39][DEBUG] session token:0acddbf26e5e73dd5c0babc79d917614
[2026-01-07 15:35:39][DEBUG] >> Search devices in local network by broadcast
[2026-01-07 15:35:39][DEBUG] Device found @192.168.129.7 len mess:172
[2026-01-07 15:35:39][DEBUG]  try 3.3 or 3.4
[2026-01-07 15:35:39][DEBUG]  cmd:13 - {"ip":"192.168.129.7","gwId":"bf10dce7fcc6fc6f7cydz8","active":2,"ablilty":0,"encrypt":true,"productKey":"key3pw4guvnat9ad","version":"3.3"}     ip|192.168.129.7 gwId|bf10dce7fcc6fc6f7cydz8 active|2 ablilty|0 encrypt|1 productKey|key3pw4guvnat9ad version|3.3 ip|192.168.129.7 gwId|bf10dce7fcc6fc6f7cydz8 active|2 ablilty|0 encrypt|1 productKey|key3pw4guvnat9ad version|3.3  - Read Json OK
[2026-01-07 15:35:39][DEBUG]  info:{"ip":"192.168.129.7","gwId":"bf10dce7fcc6fc6f7cydz8","active":2,"ablilty":0,"encrypt":true,"productKey":"key3pw4guvnat9ad","version":"3.3"}
[2026-01-07 15:35:39][DEBUG]  version found:3.3
[2026-01-07 15:35:41][DEBUG] Device found @192.168.129.16 len mess:172
[2026-01-07 15:35:41][DEBUG]  try 3.3 or 3.4
[2026-01-07 15:35:42][DEBUG]  cmd:13 - {"ip":"192.168.129.16","gwId":"bfa4ae31293451ce67vicz","active":2,"ablilty":0,"encrypt":true,"productKey":"keyfa7hya4gfa7g9","version":"3.3"}     ip|192.168.129.16 gwId|bfa4ae31293451ce67vicz active|2 ablilty|0 encrypt|1 productKey|keyfa7hya4gfa7g9 version|3.3 ip|192.168.129.16 gwId|bfa4ae31293451ce67vicz active|2 ablilty|0 encrypt|1 productKey|keyfa7hya4gfa7g9 version|3.3  - Read Json OK
[2026-01-07 15:35:42][DEBUG]  info:{"ip":"192.168.129.16","gwId":"bfa4ae31293451ce67vicz","active":2,"ablilty":0,"encrypt":true,"productKey":"keyfa7hya4gfa7g9","version":"3.3"}
[2026-01-07 15:35:42][DEBUG]  version found:3.3
[2026-01-07 15:35:42][DEBUG]  wait 7 s
[2026-01-07 15:35:44][DEBUG] Device found @192.168.129.21 len mess:172
[2026-01-07 15:35:44][DEBUG]  try 3.3 or 3.4
[2026-01-07 15:35:45][DEBUG]  cmd:13 - {"ip":"192.168.129.21","gwId":"bf601f0adb2bd976d8gxhh","active":2,"ablilty":0,"encrypt":true,"productKey":"key3nrmwvtsdc7ty","version":"3.3"}     ip|192.168.129.21 gwId|bf601f0adb2bd976d8gxhh active|2 ablilty|0 encrypt|1 productKey|key3nrmwvtsdc7ty version|3.3 ip|192.168.129.21 gwId|bf601f0adb2bd976d8gxhh active|2 ablilty|0 encrypt|1 productKey|key3nrmwvtsdc7ty version|3.3  - Read Json OK
[2026-01-07 15:35:45][DEBUG]  info:{"ip":"192.168.129.21","gwId":"bf601f0adb2bd976d8gxhh","active":2,"ablilty":0,"encrypt":true,"productKey":"key3nrmwvtsdc7ty","version":"3.3"}
[2026-01-07 15:35:45][DEBUG]  version found:3.3
[2026-01-07 15:35:45][DEBUG]  wait 4 s
[2026-01-07 15:35:48][DEBUG]  wait 1 s
[2026-01-07 15:35:49][DEBUG] Devices found on local network:{"addresses":["192.168.129.7","192.168.129.16","192.168.129.21"],"version":["3.3","3.3","3.3"],"id":["bf10dce7fcc6fc6f7cydz8","bfa4ae31293451ce67vicz","bf601f0adb2bd976d8gxhh"]}
[2026-01-07 15:35:49][DEBUG] start Tuya cloud request
Je suis absent jusque 21h, voir demain.
Déjà merci de votre aide.
Je peux déjà dire que c’est une erreur d’accès au cloud Tuya, il n’y a pas d’équipements récupérés par le plugin. L’amélioration consistera à afficher pourquoi et sans erreur http.
ok, ca fonctionne via mon ancien Jeedom. Merci voulez que je teste ce soir l’inclusion sur l’ancien jeedom?
non sur la config actuellement Ko
