Bonjour @tomitomas , et merci de ton retour rapide, comme ci-dessous ?
Modèle: Dreame Robot Vacuum-Mop F9
[2024-07-26 16:32:47][DEBUG] : ============================ DISCOVER ============================
[2024-07-26 16:32:49][DEBUG] : ["[{\"did\": \"415408243\", \"token\": \"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\", \"longitude\": \"0.0\", \"latitude\": \"0.0\", \"name\": \"Dreame Robot Vacuum-Mop F9\", \"pid\": \"0\", \"localip\": \"192.168.10.32\", \"mac\": \"7C:25:DA:5B:37:68\", \"ssid\": \"NOM\", \"bssid\": \"4A:A5:6E:5E:CF:E5\", \"parent_id\": \"\", \"parent_model\": \"\", \"show_mode\": 1, \"model\": \"dreame.vacuum.p2008\", \"adminFlag\": 1, \"shareFlag\": 0, \"permitLevel\": 16, \"isOnline\": false, \"desc\": \"Device offline \", \"extra\": {\"isSetPincode\": 0, \"pincodeType\": 0, \"fw_version\": \"3.5.8_1050\", \"needVerifyCode\": 0, \"isPasswordEncrypt\": 0}, \"uid\": 6196934457, \"pd_id\": 68230, \"password\": \"\", \"p2p_id\": \"\", \"rssi\": -52, \"family_id\": 0, \"reset_flag\": 0}]"]
[2024-07-26 16:32:49][DEBUG] : [{"did":"415408243","token":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx","longitude":"0.0","latitude":"0.0","name":"Dreame Robot Vacuum-Mop F9","pid":"0","localip":"192.168.10.32","mac":"7C:25:DA:5B:37:68","ssid":"NOM","bssid":"4A:A5:6E:5E:CF:E5","parent_id":"","parent_model":"","show_mode":1,"model":"dreame.vacuum.p2008","adminFlag":1,"shareFlag":0,"permitLevel":16,"isOnline":false,"desc":"Device offline ","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_1050","needVerifyCode":0,"isPasswordEncrypt":0},"uid":6196934457,"pd_id":68230,"password":"","p2p_id":"","rssi":-52,"family_id":0,"reset_flag":0}]
[2024-07-26 16:32:49][DEBUG] : Nouvel Equipement, ajout en cours.
[2024-07-26 16:32:49][DEBUG] : ============================ CREATING CMD ============================
[2024-07-26 16:32:49][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/genericmiot.json
[2024-07-26 16:32:49][DEBUG] : CMD BY genericmiot => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty genericmiot --ip 192.168.10.32 --token xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_922.txt
[2024-07-26 16:32:56][DEBUG] : CMD result null
[2024-07-26 16:32:56][WARNING] : ERROR:miio.click_common:Exception: Unable to discover the device 192.168.10.32
[2024-07-26 16:33:03][DEBUG] : ============================ UPDATING CMD ============================
[2024-07-26 16:33:03][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/genericmiot.json
[2024-07-26 16:33:03][DEBUG] : CMD BY genericmiot => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty genericmiot --ip 192.168.10.32 --token xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_922.txt
[2024-07-26 16:33:10][DEBUG] : CMD result null
[2024-07-26 16:33:10][WARNING] : ERROR:miio.click_common:Exception: Unable to discover the device 192.168.10.32```
