Hello
Je viens de remettre à jour le post de tete avec un peu plus d’explications et étant limité en taille de post, voici les images pour les états non géré par la version actuelle du plugin :
- IdleInLawn.svg
<svg id="IdleInLawn" version="1.1" viewBox="0 0 790 300" height="300" width="790" xmlns:svg="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.w3.org/2000/svg">
<defs>
<path id="Mower" fill="#006249" d="M 38.2,99.9 C 37.9,99.3 40.8,93.9 44.8,87.8 51.5,77.6 52.4,76.6 56.1,75.9 c 3.2,-0.6 6.3,-3.1 17.1,-13.8 18.8,-18.7 36.8,-30.1 60.1,-37.9 11.6,-4 32.4,-7.6 41.5,-7.2 2.1,0 0.3,0.5 -4,1 -10.8,1.2 -23,3.8 -32.4,6.8 -12,3.8 -32,14.2 -42,21.8 -16,12 -33.5,32.3 -43.2,49.9 -1.5,2.9 -2.3,3.2 -6.5,3.2 -2.5,0 -5.4,0.2 -6.2,0.6 -0.8,0.3 -1.8,0.1 -2.1,-0.3 z M 334.4,170.6 c -1,-1 -1.7,-5.3 -2.2,-13.4 C 327.8,88.6 279.3,33.5 211.3,19.9 l -9.4,-1.8 6.2,0 c 8.9,-0.1 40.2,2.6 51.4,4.6 28.8,5 68.9,12.7 84.5,16.3 25.4,5.8 29.4,7.3 74.5,28.4 41.2,19.3 56.3,27.3 66,35 10.2,8.1 12.3,11.1 18.2,25.1 l 4.3,10.4 0,16.7 0,16.7 -85.7,0.2 c -73.2,0.2 -86,0 -87.2,-1.2 z m 456,139 c 1.5,0 1.5,-3.7 1.6,-22.5 l 0,-21 c -50.9,-1.3 -90.6,-1.3 -141.6,-1.7 l -119.4,0.7 c -0.3,-0.3 1,-2.8 3.1,-5.4 7.6,-9.8 11.6,-21.5 12.7,-36.4 l 0.7,-9.4 11.5,-0.5 c 9.9,-0.4 12.3,-0.9 17.1,-3.5 6.9,-3.6 15.3,-11.9 16.3,-16 0.4,-2.1 2.1,-4 5.3,-6 11.8,-7.5 11.7,-11 -1.1,-37 l -9.3,-18.7 -6.6,-4.3 c -4,-2.6 -8,-6.4 -10.1,-9.4 C 565.2,110.1 554.6,99.1 547.4,94 539,87.9 532.3,84.9 506.4,75.7 494.5,71.4 477.2,64.1 466.5,58.8 425.6,38.7 384,25.2 329.1,14.2 282.6,4.9 252.7,1.9 206,1.8 150.2,1.7 122.2,6.1 94.2,19.1 71.9,29.5 63.2,37.3 54.4,55.1 51.4,61.4 46.3,70.1 43.3,74.5 40.2,78.9 34.8,87.2 31.2,92.9 24.7,103.2 24.7,103.5 25.3,109.2 c 0.7,7.1 4.8,23.1 9.1,35.3 7,20.2 23.6,49.8 29.5,52.5 2.1,1 3.3,2.9 5,8 6.4,19.2 20.7,40.3 36.3,53.2 3.6,3 6.3,5.9 5.8,6.4 -0.4,0.4 -25.1,0.9 -54.8,1 l -58.4,0.4 0,20.9 c 0,19.3 0,20.9 1.6,22.1 2.6,1.9 788.3,2 790.9,0.1 z M 256.7,265 c -0.3,-0.3 2,-2.9 5.3,-5.5 12.4,-10.4 24.2,-25.1 31.5,-39.7 l 3.2,-6.5 57.4,0.2 57.4,0.2 -0.3,4.2 c -0.3,5.5 2.1,19.6 4.9,26.8 1.2,3.2 4.3,8.9 6.8,12.7 2.5,3.7 4.3,7.2 4,7.5 -0.7,0.7 -169.8,0.7 -170.7,0 z M 134.6,261 C 90.7,238.9 67.8,187.7 80,139.2 84.9,120 94.1,103.9 108.3,89.6 c 14.2,-14.2 30,-23.3 49.7,-28.4 8.6,-2.2 12.4,-2.6 25.4,-2.7 10.2,0 17.6,0.5 22.6,1.6 33.5,7.6 59.8,28 74.5,57.9 8.9,18.1 10.2,24.5 10.3,47.7 0,18.2 -0.1,20 -2.9,28.8 -5.9,19.2 -13.5,32.4 -26.7,46 -8,8.3 -18.4,16 -28.5,21.4 l -5.8,3 -41.5,0.3 -41.5,0.3 z"/>
<path id="Wheel" fill="#006249" d="m 180.87,181.13 c -10.75,-3.84 -14.36,-17.18 -7.06,-25.89 5.33,-6.35 13.49,-7.84 20.71,-3.84 5.49,3.06 8.31,8.16 8.24,14.51 -0.15,11.61 -10.98,19.14 -21.81,15.22 z m 23.07,72.51 c 4.47,-0.86 8.71,-2.11 9.57,-2.74 2.04,-1.64 1.8,-6.82 -1.25,-28.8 -1.41,-10.35 -2.74,-20.09 -2.82,-21.5 -0.47,-5.88 3.21,-2.98 18.52,14.12 9.57,10.75 16.24,17.34 17.42,17.34 2.04,0 9.73,-7.92 14.83,-15.38 7.61,-10.98 15.46,-31.55 13.02,-33.9 -0.54,-0.54 -10.43,-2.9 -22.05,-5.33 -26.29,-5.41 -24.64,-4.94 -24.64,-8 0,-2.04 0.54,-2.58 2.9,-2.58 1.56,0 12.08,-4 23.38,-8.79 18.2,-7.76 20.48,-9.02 20.79,-11.3 0.47,-3.68 -5.25,-18.83 -10.35,-27.39 -4.31,-7.29 -16.08,-20.79 -18.05,-20.79 -1.72,0 -36.25,26.21 -38.37,29.03 -2.04,2.82 -5.49,2.51 -5.49,-0.54 0,-0.94 3.13,-11.22 6.98,-22.83 3.84,-11.61 6.74,-21.81 6.35,-22.76 -1.02,-2.74 -14.44,-5.25 -28.09,-5.25 -13.65,0 -26.76,2.43 -28.17,5.33 -0.62,1.17 1.41,8.79 6.43,23.78 6.9,20.87 7.22,22.05 5.33,23.38 -1.64,1.25 -2.19,1.09 -4,-1.09 -1.96,-2.35 -28.88,-23.23 -35.39,-27.39 -3.76,-2.43 -5.65,-1.33 -12.79,7.53 -9.1,11.3 -14.67,21.89 -18.05,34.06 -1.02,3.76 -1.02,5.33 -0.15,6.51 1.41,1.96 37.51,17.42 42.69,18.36 4.55,0.78 5.88,4.94 1.88,5.88 -1.33,0.31 -11.61,2.51 -22.91,4.78 -13.26,2.74 -20.87,4.78 -21.73,5.88 -1.56,2.04 0.39,9.33 5.49,20.24 6.2,13.26 18.99,29.11 22.91,28.25 0.94,-0.23 8.39,-7.92 16.63,-17.1 8.24,-9.18 15.46,-16.87 16.01,-17.03 0.54,-0.15 1.72,0.07 2.51,0.62 1.17,0.78 1.25,1.49 0.23,3.92 -1.56,3.84 -6.59,44.97 -5.8,47.08 0.54,1.49 7.53,4 14.04,5.1 6.35,1.09 24.64,0.62 32.09,-0.78 z"/>
<path id="ZA" fill-opacity="1" d="M 0,275 H 790 V 150 H 515 v 70 H 285 l -45,50 H 125 L 84,220 H 0 Z"/>
<path id="Grass" fill="#006249" d="m 511.4,267.5 -0.4,-1.9 c -0.2,-1 -1.6,-10.5 -3.1,-21 -3.1,-22.5 -3.0,-22 -4.2,-22 -1.1,0 -1.4,1.6 -2.2,12 -0.6,7.8 -1.6,19.1 -2.4,28.2 l -0.4,4.8 -2.8,0.1 c -1.5,0 -3.1,-0 -3.3,-0.3 -0.2,-0.2 -2.6,-20.6 -5.1,-45.2 -2.5,-24.5 -4.8,-45.2 -5.2,-45.9 -0.3,-0.7 -0.9,-1 -1.2,-0.7 -0.2,0.2 -1.3,11.9 -2.1,25.8 -2.6,41.1 -2.9,45.5 -3.6,55.8 -0.3,5.3 -0.8,9.9 -0.9,10.2 -0.4,0.6 -2.6,0.6 -3.1,-0 -0.1,-0.3 -1.2,-7.2 -2.2,-15.4 -1.0,-8.1 -2.2,-16.8 -2.5,-19.3 -0.3,-2.5 -0.8,-6.3 -1.0,-8.5 -0.2,-2.2 -0.7,-4.5 -1.2,-5.1 -0.7,-1 -0.8,-1 -1.5,0.4 -0.3,0.8 -0.9,5.2 -1.3,9.7 -2.3,27.6 -2.9,33.7 -3.4,33.7 -0.2,0 -0.5,-0.6 -0.5,-1.4 0,-0.8 -0.5,-6.4 -1.3,-12.5 -0.7,-6 -1.8,-16.1 -2.5,-22.4 -3.7,-33 -4.4,-38.4 -5,-39 -1.1,-1.1 -1.8,1.3 -2.2,7.2 -2,29.5 -5.1,71.8 -5.3,72.5 -0.1,0.4 23.6,0.5 71.4,0.4 z"/>
<g id="Warning" transform="translate(600,0)" >
<path fill="#006249" d="M 175.8,160 H 16.2 L 96,15.7 Z m -146,-8 H 162.2 L 96,32.3 Z" />
<path fill="#f00" d="m 103.1,136.9 c 0,3.9 -3.2,7.1 -7.1,7.1 -4,0 -7.1,-3.1 -7.1,-7.1 0,-4 3.1,-7.1 7.1,-7.1 3.9,0 7.1,3.2 7.1,7.1 z M 90.9,88.9 V 64 h 10.2 v 24.9 l -2.7,30.7 h -4.9 z" />
</g>
<g id="Map" transform="translate(600,0)" >
<path fill="#f00" d="m 116.6,99.7 3.4,5.8 3.4,-5.8 c 0.1,-0.2 13.7,-23.2 16.6,-28.3 2.5,-4 3.9,-9.6 3.9,-15.4 0,-13.2 -10.8,-24 -24,-24 C 106.7,32 96,42.8 96,56 c 0,5.8 1.4,11.4 3.9,15.4 3,5.1 16.5,28.1 16.7,28.3 z M 120,40 c 8.8,0 16,7.2 16,16 0,4.3 -1,8.5 -2.7,11.2 l -0.1,0.1 c -2,3.4 -8.9,15.2 -13.2,22.5 -4.3,-7.3 -11.2,-19.1 -13.2,-22.5 l -0.1,-0.1 C 105,64.5 104,60.3 104,56 c 0,-8.8 7.2,-16 16,-16 z" />
<path fill="#f00" d="m 120,56 m -8,0 a 8,8 0 1 1 16,0 8,8 0 1 1 -16,0" />
<path fill="#006249" d="m 147,38.8 c 1.4,2.3 2.6,4.7 3.5,7.3 l 17.6,-4.5 v 95.6 l -44,13.3 v -35.9 h -8 v 35.9 l -40,-13.3 V 41.5 L 89.7,46 c 0.8,-2.6 2,-5 3.5,-7.3 l -21,-7 L 16,49.1 v 112.4 l 56,-17.3 48,16 56,-17.3 V 30.5 Z M 68,137.1 24,150.4 V 54.9 L 68,41.6 Z" />
</g>
<clipPath id="Grass1">
<use xlink:href="#Grass" transform="translate(-450,0)"/>
<use xlink:href="#Grass" transform="translate(-150,0)"/>
<use xlink:href="#Grass" transform="translate(150,0)"/>
<use xlink:href="#Grass" transform="translate(300,0)"/>
<use xlink:href="#Grass" transform="translate(450,0)"/>
</clipPath>
</defs>
<g id="IdleInLawn.svg" style="display:inline">
<use xlink:href="#ZA" clip-path="url(#Grass1)" fill="#006249"/>
<use xlink:href="#Warning">
<animate id="WarningAppear" attributeType="XML" attributeName="fill-opacity" values="0;1" begin="0s;MapDisappear.end" dur="1s" fill="freeze"/>
<animate id="WarningDisappear" attributeType="XML" attributeName="fill-opacity" values="1;0" begin="WarningAppear.end" dur="1s" fill="freeze"/>
</use>
<use xlink:href="#Map" fill-opacity="0">
<animate id="MapAppear" attributeType="XML" attributeName="fill-opacity" values="0;1" begin="WarningDisappear.end" dur="1s" fill="freeze"/>
<animate id="MapDisappear" attributeType="XML" attributeName="fill-opacity" values="1;0" begin="MapAppear.end" dur="1s" fill="freeze"/>
</use>
<use xlink:href="#Mower"/>
<use xlink:href="#Wheel"/>
</g>
</svg>
- Incident.svg
<svg id="Incident" version="1.1" viewBox="0 0 790 300" height="300" width="790" xmlns:svg="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.w3.org/2000/svg">
<defs>
<g id="Bell" transform="translate(600,0)" >
<path fill="#f00" d="M172.7,152L144,118.5V68c0,-26.5 -21.5,-48 -48,-48S48,41.5 48,68v50.5L19.3,152h53c1.9,11.3 11.8,20 23.7,20s21.7,-8.7 23.7,-20H172.7zM56,121.5V68c0,-22.1 17.9,-40 40,-40s40,17.9 40,40v53.5l19.3,22.5H36.7L56,121.5zM96,164c-7.4,0 -13.7,-5.1 -15.5,-12h30.9C109.7,158.9 103.4,164 96,164z"/>
</g>
</clipPath>
</defs>
<g id="Incident.svg" style="display:inline">
<use xlink:href="#Bell">
<animateTransform id="BellRing1" attributeName="transform" attributeType="XML" type="rotate" from="-5 696 96" to="5 696 96" dur="0.1s" begin="0s;BellRing2.end"/>
<animateTransform id="BellRing2" attributeName="transform" attributeType="XML" type="rotate" from="5 696 96" to="-5 696 96" dur="0.1s" begin="BellRing1.end"/>
</use>
</g>
</svg>
- LeaveDockStation.svg
<svg id="LeaveDockStation" version="1.1" viewBox="0 0 790 300" height="300" width="790" xmlns:svg="http://www.w3.org/2000/svg" xmlns="http://www.w3.org/2000/svg">
<g id="LeaveDockStation" style="display:inline">
<path id="Dock" fill="#3E3E3E" d="m 613,120 c 0,13 0,26 0,40 h -23 c 0,9 0,19 0,29 h 23 v 81 h 83 V 120 Z">
<animate id="appear" attributeType="XML" attributeName="fill-opacity" values="0;1" begin="0s;disappear.end" dur="0.5s"/>
<animateTransform id="disappear" attributeType="XML" attributeName="transform" type="translate" from="0" to="250" begin="appear.end" dur="3s"/>
</path>
<path id="Wheel" fill="#006249" d="m 180.87,181.13 c -10.75,-3.84 -14.36,-17.18 -7.06,-25.89 5.33,-6.35 13.49,-7.84 20.71,-3.84 5.49,3.06 8.31,8.16 8.24,14.51 -0.15,11.61 -10.98,19.14 -21.81,15.22 z m 23.07,72.51 c 4.47,-0.86 8.71,-2.11 9.57,-2.74 2.04,-1.64 1.8,-6.82 -1.25,-28.8 -1.41,-10.35 -2.74,-20.09 -2.82,-21.5 -0.47,-5.88 3.21,-2.98 18.52,14.12 9.57,10.75 16.24,17.34 17.42,17.34 2.04,0 9.73,-7.92 14.83,-15.38 7.61,-10.98 15.46,-31.55 13.02,-33.9 -0.54,-0.54 -10.43,-2.9 -22.05,-5.33 -26.29,-5.41 -24.64,-4.94 -24.64,-8 0,-2.04 0.54,-2.58 2.9,-2.58 1.56,0 12.08,-4 23.38,-8.79 18.2,-7.76 20.48,-9.02 20.79,-11.3 0.47,-3.68 -5.25,-18.83 -10.35,-27.39 -4.31,-7.29 -16.08,-20.79 -18.05,-20.79 -1.72,0 -36.25,26.21 -38.37,29.03 -2.04,2.82 -5.49,2.51 -5.49,-0.54 0,-0.94 3.13,-11.22 6.98,-22.83 3.84,-11.61 6.74,-21.81 6.35,-22.76 -1.02,-2.74 -14.44,-5.25 -28.09,-5.25 -13.65,0 -26.76,2.43 -28.17,5.33 -0.62,1.17 1.41,8.79 6.43,23.78 6.9,20.87 7.22,22.05 5.33,23.38 -1.64,1.25 -2.19,1.09 -4,-1.09 -1.96,-2.35 -28.88,-23.23 -35.39,-27.39 -3.76,-2.43 -5.65,-1.33 -12.79,7.53 -9.1,11.3 -14.67,21.89 -18.05,34.06 -1.02,3.76 -1.02,5.33 -0.15,6.51 1.41,1.96 37.51,17.42 42.69,18.36 4.55,0.78 5.88,4.94 1.88,5.88 -1.33,0.31 -11.61,2.51 -22.91,4.78 -13.26,2.74 -20.87,4.78 -21.73,5.88 -1.56,2.04 0.39,9.33 5.49,20.24 6.2,13.26 18.99,29.11 22.91,28.25 0.94,-0.23 8.39,-7.92 16.63,-17.1 8.24,-9.18 15.46,-16.87 16.01,-17.03 0.54,-0.15 1.72,0.07 2.51,0.62 1.17,0.78 1.25,1.49 0.23,3.92 -1.56,3.84 -6.59,44.97 -5.8,47.08 0.54,1.49 7.53,4 14.04,5.1 6.35,1.09 24.64,0.62 32.09,-0.78 z">
<animateTransform attributeName="transform" attributeType="XML" type="rotate" repeatCount="indefinite" from="360 186 165" to="0 186 165" dur="6.72s"/>
</path>
</g>
</svg>
Et voici le contenu de mon fichier cmd.info.numeric.BoschIndegoStateV4.html
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-template="line" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
<div class="content-xs">
<span class="cmdName #hide_name#">#name_display# </span> <strong class="stateTxt"></strong>(<strong class="state"></strong>)
<span class="stateImg"></span>
<br>
<span class="stateDate"></span>
</div>
<script>
jeedom.cmd.update['#id#'] = function(_options) {
var cmd = $('.cmd[data-cmd_id=#id#]')
var Stxt = "?";
var imgPath = "plugins/BoschIndego/core/template/dashboard/cmd.info.numeric.BoschIndegoStateV4/";
var Simg = "";
cmd.attr('title','Date de valeur : '+_options.valueDate+'<br/>Date de collecte : '+_options.collectDate);
cmd.find('.state').empty().append(_options.display_value);
cmd.find('.stateDate').empty().append(_options.valueDate);
var Svalue = parseInt(_options.display_value);
if(Svalue == 0) Stxt = 'Lecture état.';
else if(Svalue == 257 || Svalue == 260)
{ Simg = '<img src="'+imgPath+'OnDockStationCharging.svg" width="140" height="100"/>';
if(Svalue == 257) Stxt = 'En charge.';
else if(Svalue == 260) Stxt = "Sur station. En charge.";
else if(Svalue >= 258 && Svalue <= 263)
{ Simg = '<img src="'+imgPath+'OnDockStation.svg" width="140" height="100"/>';
Stxt = "Sur station.";
if(Svalue == 259) Stxt += "Mise à jour logiciel.";
else if(Svalue == 262) Stxt += "Chargement carte.";
else if(Svalue == 263) Stxt += "Enregistrement carte.";
else if(Svalue == 266)
{ Stxt = "Quitte la station.";
Simg = '<img src="'+imgPath+'LeaveDockStation.svg" width="140" height="100"/>';
else if(Svalue == 513 || Svalue == 518)
{ Stxt = "Tonte.";
Simg = '<img src="'+imgPath+'Mowing.svg" width="140" height="100"/>';
if(Svalue == 518) Stxt = 'Coupe des bordures.';
else if(Svalue >= 514 && Svalue <= 517)
{ Simg = '<img src="'+imgPath+'IdleInLawn.svg" width="140" height="100"/>';
if(Svalue == 514) Stxt = 'Recherche position.';
else if(Svalue == 515) Stxt = 'Chargement carte.';
else if(Svalue == 516) Stxt = 'Reconnaissance de la pelouse.';
else if(Svalue == 517) Stxt = 'Pause.';
else if(Svalue == 519)
{ Stxt = "Incident.";
Simg = '<img src="'+imgPath+'Incident.svg" width="140" height="100"/>';
else if(Svalue >= 769 && Svalue <= 776)
{ Simg = '<img src="'+imgPath+'ToDockStation.svg" width="140" height="100"/>';
Stxt = "Retour à la station. ";
if(Svalue == 771) Stxt += "Batterie faible.";
else if(Svalue == 772) Stxt += "Créneau horaire de tonte terminé.";
else if(Svalue == 773) Stxt += "Température batterie.";
else if(Svalue == 775) Stxt += "Tonte terminée.";
else if(Svalue == 776) Stxt += "Recherche position.";
cmd.find('.stateImg').empty().append(Simg);
cmd.find('.stateTxt').empty().append(' Indego : '+Stxt);
jeedom.cmd.update['#id#']({display_value:'#state#',valueDate:'#valueDate#',collectDate:'#collectDate#',alertLevel:'#alertLevel#'});
</script>
</div>
