J’ai un soucis qui est apparu apres un reboot propre de jeedom (redemarrage dans l’interface de jeedom)
Quand j’envois ouverture d’un volet (directement depuis le volet crée dans KLF) puis un stop.
L’ordre est executé 3x puis se termine par un plantage du KLF « not responding »
Voici le log en debug Merci pour votre aide
[2022-04-02 12:37:08][DEBUG] : Send http://localhost:9123/devices
[2022-04-02 12:37:08][DEBUG] : Result {"result": "ok", "devices": [{"id": 0, "name": "RDC_SALON_DROITE", "type": "RollerShutter"}, {"id": 1, "name": "RDC_SALON_CENTRE", "type": "RollerShutter", "position": 11}, {"id": 2, "name": "RDJ_Gauche", "type": "RollerShutter"}, {"id": 3, "name": "1ER_Escalier", "type": "RollerShutter"}, {"id": 5, "name": "RDJ_Porte", "type": "RollerShutter"}, {"id": 6, "name": "RDC_SAM_DROITE", "type": "RollerShutter", "position": 0}, {"id": 7, "name": "RDC_SAM_GAUCHE", "type": "RollerShutter", "position": 0}, {"id": 8, "name": "1ER_PARENTS", "type": "RollerShutter"}, {"id": 9, "name": "1ER_ENFANT", "type": "RollerShutter"}, {"id": 10, "name": "RDC_CUISINE", "type": "RollerShutter"}, {"id": 11, "name": "1ER_SDJ", "type": "RollerShutter"}, {"id": 12, "name": "1ER_SDB", "type": "RollerShutter"}, {"id": 13, "name": "RDC_SALON_GAUCHE", "type": "RollerShutter"}, {"id": 14, "name": "RDC_BIBLIOTHEQUE", "type": "RollerShutter"}, {"id": 15, "name": "RDC_SAM_CENTRE", "type": "RollerShutter"}]}
[2022-04-02 12:37:08][DEBUG] : Update RDC_SALON_DROITE at %
[2022-04-02 12:37:08][DEBUG] : Update RDC_SALON_CENTRE at 11%
[2022-04-02 12:37:08][DEBUG] : Update RDJ_Gauche at %
[2022-04-02 12:37:08][DEBUG] : Update 1ER_ESCALIER at %
[2022-04-02 12:37:08][DEBUG] : Update RDJ_Porte at %
[2022-04-02 12:37:08][DEBUG] : Update RDC_SAM_DROITE at 0%
[2022-04-02 12:37:08][DEBUG] : Update RDC_SAM_GAUCHE at 0%
[2022-04-02 12:37:08][DEBUG] : Update 1ER_PARENTS at %
[2022-04-02 12:37:08][DEBUG] : Update 1ER_ENFANT at %
[2022-04-02 12:37:08][DEBUG] : Update RDC_CUISINE at %
[2022-04-02 12:37:08][DEBUG] : Update 1ER_SDJ at %
[2022-04-02 12:37:08][DEBUG] : Update 1ER_SDB at %
[2022-04-02 12:37:08][DEBUG] : Update RDC_SALON_GAUCHE at %
[2022-04-02 12:37:08][DEBUG] : Update RDC_BIBLIOTHEQUE at %
[2022-04-02 12:37:08][DEBUG] : Update RDC_SAM_CENTRE at %
[2022-04-02 12:37:18][DEBUG] : Action /set/5/0
[2022-04-02 12:37:18][DEBUG] : Send http://localhost:9123/set/5/0
[2022-04-02 12:37:23][DEBUG] : Action /stop/5
[2022-04-02 12:37:23][DEBUG] : Send http://localhost:9123/stop/5
[2022-04-02 12:37:43][DEBUG] : Result
[2022-04-02 12:37:48][DEBUG] : Result
[2022-04-02 12:38:07][DEBUG] : Send http://localhost:9123/devices
[2022-04-02 12:38:07][DEBUG] : Result {"result": "ok", "devices": [{"id": 0, "name": "RDC_SALON_DROITE", "type": "RollerShutter"}, {"id": 1, "name": "RDC_SALON_CENTRE", "type": "RollerShutter", "position": 11}, {"id": 2, "name": "RDJ_Gauche", "type": "RollerShutter"}, {"id": 3, "name": "1ER_Escalier", "type": "RollerShutter"}, {"id": 5, "name": "RDJ_Porte", "type": "RollerShutter"}, {"id": 6, "name": "RDC_SAM_DROITE", "type": "RollerShutter", "position": 0}, {"id": 7, "name": "RDC_SAM_GAUCHE", "type": "RollerShutter", "position": 0}, {"id": 8, "name": "1ER_PARENTS", "type": "RollerShutter"}, {"id": 9, "name": "1ER_ENFANT", "type": "RollerShutter"}, {"id": 10, "name": "RDC_CUISINE", "type": "RollerShutter"}, {"id": 11, "name": "1ER_SDJ", "type": "RollerShutter"}, {"id": 12, "name": "1ER_SDB", "type": "RollerShutter"}, {"id": 13, "name": "RDC_SALON_GAUCHE", "type": "RollerShutter"}, {"id": 14, "name": "RDC_BIBLIOTHEQUE", "type": "RollerShutter"}, {"id": 15, "name": "RDC_SAM_CENTRE", "type": "RollerShutter"}]}
[2022-04-02 12:38:07][DEBUG] : Update RDC_SALON_DROITE at %
[2022-04-02 12:38:07][DEBUG] : Update RDC_SALON_CENTRE at 11%
[2022-04-02 12:38:07][DEBUG] : Update RDJ_Gauche at %
[2022-04-02 12:38:07][DEBUG] : Update 1ER_ESCALIER at %
[2022-04-02 12:38:07][DEBUG] : Update RDJ_Porte at %
[2022-04-02 12:38:07][DEBUG] : Update RDC_SAM_DROITE at 0%
[2022-04-02 12:38:07][DEBUG] : Update RDC_SAM_GAUCHE at 0%
[2022-04-02 12:38:07][DEBUG] : Update 1ER_PARENTS at %
[2022-04-02 12:38:07][DEBUG] : Update 1ER_ENFANT at %
[2022-04-02 12:38:07][DEBUG] : Update RDC_CUISINE at %
[2022-04-02 12:38:07][DEBUG] : Update 1ER_SDJ at %
[2022-04-02 12:38:07][DEBUG] : Update 1ER_SDB at %
[2022-04-02 12:38:07][DEBUG] : Update RDC_SALON_GAUCHE at %
[2022-04-02 12:38:07][DEBUG] : Update RDC_BIBLIOTHEQUE at %
[2022-04-02 12:38:07][DEBUG] : Update RDC_SAM_CENTRE at %
[2022-04-02 12:38:23][INFO] : Arrêt du service klf200
[2022-04-02 12:38:25][INFO] : Lancement démon klf200 : /usr/bin/python3 /var/www/html/plugins/klf200/resources/klf200d.py 192.168.0.89 kcLn8pXTaT
[2022-04-02 12:38:25][ERROR] : KLF200 has been restarted after found not responding
[2022-04-02 12:38:28][INFO] : Arrêt du service klf200
[2022-04-02 12:38:28][INFO] : Lancement démon klf200 : /usr/bin/python3 /var/www/html/plugins/klf200/resources/klf200d.py 192.168.0.89 kcLn8pXTaT
[2022-04-02 12:38:28][ERROR] : KLF200 has been restarted after found not responding
[2022-04-02 12:38:28][DEBUG] : Send http://localhost:9123/position/5
File "/var/www/html/plugins/klf200/resources/klf200d.py", line 269, in <module>
LOOP.run_until_complete(init_pyvlx_connection(LOOP))
File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
return future.result()
File "/var/www/html/plugins/klf200/resources/klf200d.py", line 22, in init_pyvlx_connection
await pyvlx.load_nodes()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/pyvlx.py", line 78, in load_nodes
await self.nodes.load(node_id)
File "/usr/local/lib/python3.7/dist-packages/pyvlx/nodes.py", line 69, in load
await self._load_all_nodes()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/nodes.py", line 85, in _load_all_nodes
await get_all_nodes_information.do_api_call()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/api/api_event.py", line 21, in do_api_call
await self.send_frame()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/api/api_event.py", line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File "/usr/local/lib/python3.7/dist-packages/pyvlx/pyvlx.py", line 66, in send_frame
await self.connect()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/pyvlx.py", line 43, in connect
await self.connection.connect()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/connection.py", line 90, in connect
ssl=self.create_ssl_context(),
File "/usr/lib/python3.7/asyncio/base_events.py", line 959, in create_connection
raise exceptions[0]
File "/usr/lib/python3.7/asyncio/base_events.py", line 946, in create_connection
await self.sock_connect(sock, address)
File "/usr/lib/python3.7/asyncio/selector_events.py", line 464, in sock_connect
return await fut
File "/usr/lib/python3.7/asyncio/selector_events.py", line 494, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.0.89', 51200)
[2022-04-02 12:38:29][DEBUG] : Result
[2022-04-02 12:39:08][DEBUG] : Send http://localhost:9123/devices
[2022-04-02 12:39:09][INFO] : Arrêt du service klf200
[2022-04-02 12:39:09][INFO] : Lancement démon klf200 : /usr/bin/python3 /var/www/html/plugins/klf200/resources/klf200d.py 192.168.0.89 kcLn8pXTaT
[2022-04-02 12:39:09][ERROR] : KLF200 has been restarted after found not responding
[2022-04-02 12:39:09][DEBUG] : Update RDJ_Porte at %
[2022-04-02 12:39:09][DEBUG] : Result
[2022-04-02 12:39:49][INFO] : Arrêt du service klf200
======== Running on http://0.0.0.0:9123 ========
(Press CTRL+C to quit)
Task was destroyed but it is pending!
task: <Task pending coro=<Heartbeat.loop() running at /usr/local/lib/python3.7/dist-packages/pyvlx/heartbeat.py:46> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0x7f0f5d8b36a8>()]>>
[2022-04-02 12:39:50][INFO] : Lancement démon klf200 : /usr/bin/python3 /var/www/html/plugins/klf200/resources/klf200d.py 192.168.0.89 kcLn8pXTaT
[2022-04-02 12:39:50][ERROR] : KLF200 has been restarted after found not responding
[2022-04-02 12:40:09][DEBUG] : Send http://localhost:9123/devices
[2022-04-02 12:40:09][DEBUG] : Result {"result": "ok", "devices": [{"id": 0, "name": "RDC_SALON_DROITE", "type": "RollerShutter", "position": 0}, {"id": 1, "name": "RDC_SALON_CENTRE", "type": "RollerShutter", "position": 11}, {"id": 2, "name": "RDJ_Gauche", "type": "RollerShutter", "position": 100}, {"id": 3, "name": "1ER_Escalier", "type": "RollerShutter", "position": 100}, {"id": 5, "name": "RDJ_Porte", "type": "RollerShutter", "position": 47}, {"id": 6, "name": "RDC_SAM_DROITE", "type": "RollerShutter", "position": 0}, {"id": 7, "name": "RDC_SAM_GAUCHE", "type": "RollerShutter", "position": 0}, {"id": 8, "name": "1ER_PARENTS", "type": "RollerShutter", "position": 0}, {"id": 9, "name": "1ER_ENFANT", "type": "RollerShutter", "position": 30}, {"id": 10, "name": "RDC_CUISINE", "type": "RollerShutter", "position": 20}, {"id": 11, "name": "1ER_SDJ", "type": "RollerShutter", "position": 0}, {"id": 12, "name": "1ER_SDB", "type": "RollerShutter", "position": 0}, {"id": 13, "name": "RDC_SALON_GAUCHE", "type": "RollerShutter", "position": 0}, {"id": 14, "name": "RDC_BIBLIOTHEQUE", "type": "RollerShutter", "position": 0}, {"id": 15, "name": "RDC_SAM_CENTRE", "type": "RollerShutter", "position": 0}]}
[2022-04-02 12:40:09][DEBUG] : Update RDC_SALON_DROITE at 0%
[2022-04-02 12:40:09][DEBUG] : Update RDC_SALON_CENTRE at 11%
[2022-04-02 12:40:09][DEBUG] : Update RDJ_Gauche at 100%
[2022-04-02 12:40:09][DEBUG] : Update 1ER_ESCALIER at 100%
[2022-04-02 12:40:09][DEBUG] : Update RDJ_Porte at 47%
[2022-04-02 12:40:09][DEBUG] : Update RDC_SAM_DROITE at 0%
[2022-04-02 12:40:09][DEBUG] : Update RDC_SAM_GAUCHE at 0%
[2022-04-02 12:40:09][DEBUG] : Update 1ER_PARENTS at 0%
[2022-04-02 12:40:09][DEBUG] : Update 1ER_ENFANT at 30%
[2022-04-02 12:40:09][DEBUG] : Update RDC_CUISINE at 20%
[2022-04-02 12:40:09][DEBUG] : Update 1ER_SDJ at 0%
[2022-04-02 12:40:09][DEBUG] : Update 1ER_SDB at 0%
[2022-04-02 12:40:09][DEBUG] : Update RDC_SALON_GAUCHE at 0%
[2022-04-02 12:40:09][DEBUG] : Update RDC_BIBLIOTHEQUE at 0%
[2022-04-02 12:40:09][DEBUG] : Update RDC_SAM_CENTRE at 0%
EDIT: je teste sur un volet un sleep de 1 sec apres un ordre
EDIT2: ca ne change rien
