cron_execution (4.7 Ko)
event (431 o)
http.error
openalpr_update (17.9 Ko)
Rechercher
-- OpenCL: YES (no extra features)
-- Include path: /root/opencv/3rdparty/include/opencl/1.2
-- Link libraries: Dynamic load
-- Python (for build): /usr/bin/python2.7
-- Java:
-- ant: NO
-- JNI: NO
-- Java wrappers: NO
-- Java tests: NO
-- Install to: /usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: /root/opencv/build
[ 0%] Built target opencv_highgui_plugins
[ 1%] Built target libopenjp2
[ 1%] Built target opencv_videoio_plugins
[ 1%] Built target ittnotify
[ 2%] Built target ippiw
[ 6%] Built target opencv_core
[ 9%] Built target opencv_imgproc
[ 12%] Built target IlmImf
[ 12%] Built target opencv_imgcodecs
[ 12%] Built target opencv_videoio
[ 12%] Built target opencv_highgui
[ 13%] Built target opencv_ts
[ 15%] Built target opencv_test_core
[ 16%] Built target opencv_perf_core
[ 17%] Built target opencv_flann
[ 18%] Built target opencv_test_flann
[ 19%] Built target opencv_perf_imgproc
[ 21%] Built target opencv_test_imgproc
[ 21%] Built target opencv_intensity_transform
[ 21%] Built target opencv_test_intensity_transform
[ 21%] Built target example_intensity_transform_intensity_transform
[ 22%] Built target opencv_ml
[ 23%] Built target opencv_test_ml
[ 23%] Built target opencv_phase_unwrapping
[ 23%] Built target opencv_test_phase_unwrapping
[ 23%] Built target example_phase_unwrapping_unwrap
[ 24%] Built target opencv_photo
[ 25%] Built target opencv_test_photo
[ 26%] Built target opencv_perf_photo
[ 26%] Built target opencv_plot
[ 26%] Built target example_plot_plot_demo
[ 26%] Built target opencv_quality
[ 26%] Built target example_quality_brisque_eval_tid2008
[ 26%] Built target opencv_test_quality
[ 26%] Built target example_quality_brisque_trainer_livedb
[ 26%] Built target opencv_reg
[ 26%] Built target opencv_test_reg
[ 26%] Built target opencv_perf_reg
[ 26%] Built target example_reg_map_test
[ 26%] Built target opencv_surface_matching
[ 26%] Built target example_surface_matching_ppf_load_match
[ 26%] Built target example_surface_matching_ppf_normal_computation
[ 26%] Built target opencv_xphoto
[ 26%] Built target example_xphoto_color_balance
[ 26%] Built target example_xphoto_bm3d_image_denoising
[ 26%] Built target opencv_perf_xphoto
[ 26%] Built target example_xphoto_oil
[ 27%] Built target opencv_test_xphoto
[ 27%] Built target example_xphoto_dct_image_denoising
[ 27%] Built target example_xphoto_inpainting
[ 29%] Built target libprotobuf
[ 33%] Built target opencv_dnn
[ 34%] Built target opencv_perf_dnn
[ 34%] Built target opencv_test_dnn
[ 34%] Built target opencv_dnn_superres
[ 35%] Built target example_dnn_superres_dnn_superres
[ 35%] Built target opencv_perf_dnn_superres
[ 35%] Built target opencv_test_dnn_superres
[ 35%] Built target example_dnn_superres_dnn_superres_benchmark_time
[ 35%] Built target example_dnn_superres_dnn_superres_multioutput
[ 35%] Built target example_dnn_superres_dnn_superres_video
[ 35%] Built target example_dnn_superres_dnn_superres_benchmark_quality
[ 36%] Built target opencv_features2d
[ 36%] Built target opencv_perf_features2d
[ 36%] Built target opencv_test_features2d
[ 36%] Built target opencv_freetype
[ 36%] Built target opencv_fuzzy
[ 36%] Built target opencv_test_fuzzy
[ 36%] Built target example_fuzzy_fuzzy_filtering
[ 36%] Built target example_fuzzy_fuzzy_inpainting
[ 36%] Built target opencv_hfs
[ 36%] Built target example_hfs_example
[ 37%] Built target opencv_img_hash
[ 37%] Built target opencv_test_img_hash
[ 38%] Built target example_img_hash_hash_samples
[ 38%] Built target opencv_perf_imgcodecs
[ 38%] Built target opencv_test_imgcodecs
[ 38%] Built target opencv_line_descriptor
[ 38%] Built target example_line_descriptor_compute_descriptors
[ 38%] Built target example_line_descriptor_radius_matching
[ 38%] Built target opencv_perf_line_descriptor
[ 38%] Built target opencv_test_line_descriptor
[ 38%] Built target example_line_descriptor_lines_extraction
[ 38%] Built target example_line_descriptor_lsd_lines_extraction
[ 38%] Built target example_line_descriptor_matching
[ 38%] Built target example_line_descriptor_knn_matching
[ 39%] Built target opencv_saliency
[ 39%] Built target opencv_test_saliency
[ 40%] Built target example_saliency_computeSaliency
[ 40%] Built target opencv_text
[ 40%] Built target example_text_cropped_word_recognition
[ 40%] Built target example_text_textdetection
[ 40%] Built target example_text_character_recognition
[ 40%] Built target example_text_end_to_end_recognition
[ 40%] Built target example_text_text_recognition_cnn
[ 40%] Built target example_text_textdetection_swt
[ 40%] Built target opencv_test_text
[ 40%] Built target example_text_textbox_demo
[ 40%] Built target example_text_segmented_word_recognition
[ 40%] Built target example_text_webcam_demo
[ 40%] Built target example_text_dictnet_demo
[ 41%] Built target opencv_test_videoio
[ 41%] Built target opencv_perf_videoio
[ 42%] Built target opencv_wechat_qrcode
[ 42%] Built target opencv_test_wechat_qrcode
[ 42%] Built target example_wechat_qrcode_qrcode_example
[ 42%] Built target opencv_barcode
[ 43%] Built target opencv_test_barcode
[ 43%] Built target example_barcode_barcode
[ 44%] Built target opencv_calib3d
[ 44%] Built target opencv_perf_calib3d
[ 45%] Built target opencv_test_calib3d
[ 46%] Built target opencv_datasets
[ 46%] Built target example_datasets_is_weizmann
[ 46%] Built target example_datasets_gr_skig
[ 46%] Built target example_datasets_ir_robot
[ 46%] Built target example_datasets_msm_middlebury
[ 46%] Built target example_datasets_fr_lfw_benchmark
[ 47%] Built target example_datasets_fr_adience
[ 47%] Built target example_datasets_ar_sports
[ 47%] Built target example_datasets_hpe_parse
[ 47%] Built target example_datasets_slam_kitti
[ 47%] Built target example_datasets_track_vot
[ 47%] Built target example_datasets_pd_inria
[ 47%] Built target example_datasets_ar_hmdb_benchmark
[ 47%] Built target example_datasets_msm_epfl
[ 47%] Built target example_datasets_or_imagenet
[ 47%] Built target example_datasets_gr_chalearn
[ 48%] Built target example_datasets_or_mnist
[ 48%] Built target example_datasets_sr_general100
[ 48%] Built target example_datasets_or_pascal
[ 48%] Built target example_datasets_ir_affine
[ 48%] Built target example_datasets_tr_icdar
[ 48%] Built target example_datasets_or_sun
[ 48%] Built target example_datasets_is_bsds
[ 48%] Built target example_datasets_sr_bsds
[ 48%] Built target example_datasets_sr_div2k
[ 48%] Built target example_datasets_tr_chars
[ 48%] Built target example_datasets_ar_hmdb
[ 48%] Built target example_datasets_tr_chars_benchmark
[ 48%] Built target example_datasets_fr_lfw
[ 48%] Built target example_datasets_tr_icdar_benchmark
[ 48%] Built target example_datasets_pd_caltech
[ 48%] Built target example_datasets_tr_svt
[ 48%] Built target example_datasets_hpe_humaneva
[ 48%] Built target example_datasets_slam_tumindoor
[ 49%] Built target example_datasets_tr_svt_benchmark
[ 50%] Built target opencv_test_highgui
[ 50%] Built target opencv_mcc
[ 50%] Built target opencv_test_mcc
[ 50%] Built target example_mcc_color_correction_model
[ 50%] Built target example_mcc_chart_detection
[ 50%] Built target example_mcc_chart_detection_with_network
[ 51%] Built target quirc
[ 51%] Built target opencv_objdetect
[ 51%] Built target opencv_test_objdetect
[ 51%] Built target opencv_perf_objdetect
[ 51%] Built target opencv_rapid
[ 51%] Built target opencv_test_rapid
[ 52%] Built target opencv_rgbd
[ 52%] Built target example_rgbd_kinfu_demo
[ 52%] Built target example_rgbd_colored_kinfu_demo
[ 52%] Built target opencv_perf_rgbd
[ 53%] Built target opencv_test_rgbd
[ 53%] Built target example_rgbd_large_kinfu_demo
[ 53%] Built target example_rgbd_linemod
[ 53%] Built target example_rgbd_dynafu_demo
[ 53%] Built target example_rgbd_odometry_evaluation
[ 53%] Built target opencv_shape
[ 53%] Built target opencv_test_shape
[ 53%] Built target example_shape_shape_example
[ 53%] Built target opencv_structured_light
[ 54%] Built target opencv_test_structured_light
[ 54%] Built target example_structured_light_cap_pattern
[ 54%] Built target example_structured_light_projectorcalibration
[ 54%] Built target example_structured_light_capsinpattern
[ 54%] Built target example_structured_light_pointcloud
[ 55%] Built target opencv_video
[ 56%] Built target opencv_perf_video
[ 56%] Built target opencv_test_video
[ 56%] Built target opencv_videostab
[ 56%] Built target opencv_test_videostab
[ 57%] Built target example_videostab_videostab
[ 59%] Built target opencv_xfeatures2d
[ 59%] Built target example_xfeatures2d_shape_transformation
[ 59%] Built target example_xfeatures2d_gms_matcher
[ 59%] Built target example_xfeatures2d_video_homography
[ 59%] Built target opencv_perf_xfeatures2d
[ 59%] Built target opencv_test_xfeatures2d
[ 59%] Built target example_xfeatures2d_surf_matcher
[ 59%] Built target example_xfeatures2d_pct_signatures
[ 59%] Built target example_xfeatures2d_bagofwords_classification
[ 59%] Built target example_xfeatures2d_pct_webcam
[ 60%] Built target opencv_ximgproc
[ 60%] Built target example_ximgproc_structured_edge_detection
[ 60%] Built target example_ximgproc_selectivesearchsegmentation_demo
[ 60%] Built target example_ximgproc_seeds
[ 60%] Built target example_ximgproc_run_length_morphology_demo
[ 60%] Built target example_ximgproc_peilin
[ 60%] Built target example_ximgproc_paillou_demo
[ 60%] Built target example_ximgproc_edgeboxes_demo
[ 60%] Built target example_ximgproc_color_match_template
[ 60%] Built target example_ximgproc_live_demo
[ 60%] Built target example_ximgproc_brightedgesexample
[ 61%] Built target example_ximgproc_thinning
[ 62%] Built target opencv_perf_ximgproc
[ 62%] Built target example_ximgproc_slic
[ 62%] Built target example_ximgproc_deriche_demo
[ 62%] Built target example_ximgproc_colorize
[ 62%] Built target example_ximgproc_niblack_thresholding
[ 62%] Built target example_ximgproc_disparity_filtering
[ 63%] Built target example_ximgproc_edgepreserving_filter_demo
[ 63%] Built target example_ximgproc_fast_hough_transform
[ 63%] Built target example_ximgproc_fld_lines
[ 63%] Linking CXX executable ../../bin/opencv_test_ximgproc
/usr/bin/ld: CMakeFiles/opencv_test_ximgproc.dir/test/test_l0_smooth.cpp.o: file not recognized: file truncated
collect2: error: ld returned 1 exit status
make[2]: *** [modules/ximgproc/CMakeFiles/opencv_test_ximgproc.dir/build.make:503: bin/opencv_test_ximgproc] Error 1
make[1]: *** [CMakeFiles/Makefile2:13969: modules/ximgproc/CMakeFiles/opencv_test_ximgproc.dir/all] Error 2
make: *** [Makefile:163: all] Error 2
* Compile openalpr: *
Cloning into 'openalpr'...
-- The C compiler identification is GNU 8.3.0
-- The CXX compiler identification is GNU 8.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Tesseract
CMake Error at CMakeLists.txt:101 (FIND_PACKAGE):
By not providing "FindOpenCV.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "OpenCV", but
CMake did not find one.
Could not find a package configuration file provided by "OpenCV" with any
of the following names:
OpenCVConfig.cmake
opencv-config.cmake
Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
"OpenCV_DIR" to a directory containing one of the above files. If "OpenCV"
provides a separate development package or SDK, be sure it has been
installed.
-- Configuring incomplete, errors occurred!
See also "/usr/local/src/openalpr/openalpr/src/build/CMakeFiles/CMakeOutput.log".
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
* Fin de l'installation *
Reading package lists…
Building dependency tree…
Reading state information…
autoconf is already the newest version (2.69-11).
automake is already the newest version (1:1.16.1-4).
libtool is already the newest version (2.4.6-9).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pkg-config is already the newest version (0.29-6).
Package libpng12-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‹ libpng12-dev › has no installation candidate
libjpeg62-turbo-dev is already the newest version (1:1.5.2-2+deb10u1).
libwebp-dev is already the newest version (0.6.1-2+deb10u1).
libtiff-dev is already the newest version (4.1.0+git191117-2~deb10u2).
zlib1g-dev is already the newest version (1:1.2.11.dfsg-1).
git is already the newest version (1:2.20.1-2+deb10u3).
cmake is already the newest version (3.13.4-1).
liblog4cplus-dev is already the newest version (1.1.2-3.2).
libcurl4-openssl-dev is already the newest version (7.64.0-4+deb10u2).
uuid-dev is already the newest version (2.33.1-0.1).
build-essential is already the newest version (12.6).
Package libjpeg8-dev is not available, but is referred to by another package.
However the following packages replace it:
libjpeg62-turbo-dev
E: Package ‹ libjpeg8-dev › has no installation candidate
E: Unable to locate package libjasper-dev
libgtk2.0-dev is already the newest version (2.24.32-3).
libavcodec-dev is already the newest version (7:4.1.6-1~deb10u1).
libavformat-dev is already the newest version (7:4.1.6-1~deb10u1).
libswscale-dev is already the newest version (7:4.1.6-1~deb10u1).
libv4l-dev is already the newest version (1.16.3-3).
libavcodec-extra is already the newest version (7:4.1.6-1~deb10u1).
libatlas-base-dev is already the newest version (3.10.3-8).
gfortran is already the newest version (4:8.3.0-1).
python2.7-dev is already the newest version (2.7.16-2+deb10u1).
libtesseract-dev is already the newest version (4.0.0-2).
libleptonica-dev is already the newest version (1.76.0-1).
beanstalkd is already the newest version (1.10-4).
Bonjour Mika, as tu un retour des camera ip les plus adaptées pour cetteconfig?
la mienne fonctionne terriblement bien sauf que j’ai pas d’IR donc la nuit c’est pas top.
