Je suis sous Jeedom V3.3.5 Buster sur NUC dédié Jeedom. Jmqtt à jour , V2022-01-31.
Depuis hiers, après l"inclusion d’un nouvel objet (esp8266 ) qui fonctionne parfaitement seulement j’ai une alarme réccurente:
[2022-02-02 20:05:01][ERROR] : on_mqtt_message raised an Exception : Le nom de la commande ne peut pas être vide :jMQTTCmd Object ( [_preSaveInformations:jMQTTCmd:private] => [id:protected] => [logicalId:protected] => [generic_type:protected] => [eqType:protected] => jMQTT [name:protected] => [order:protected] => [type:protected] => info [subType:protected] => string [eqLogic_id:protected] => 4092 [isHistorized:protected] => 0 [unite:protected] => [configuration:protected] => Array ( [topic] => 99-ESP_Easy/ ) [template:protected] => [display:protected] => [value:protected] => [isVisible:protected] => 1 [alert:protected] => [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => jMQTT Object ( [_preSaveInformations:jMQTT:private] => [_preRemoveInformations:jMQTT:private] => [_broker:jMQTT:private] => [_statusCmd:jMQTT:private] => [_log:jMQTT:private] => [id:protected] => 4092 [name:protected] => 99-ESP_Easy [logicalId:protected] => 99-ESP_Easy/# [generic_type:protected] => [object_id:protected] => 20 [eqType_name:protected] => jMQTT [eqReal_id:protected] => [isVisible:protected] => 0 [isEnable:protected] => 1 [configuration:protected] => Array ( [brkId] => 2841 [createtime] => 2022-02-02 20:04:21 [type] => eqpt [auto_add_cmd] => 1 [Qos] => 0 [updatetime] => 2022-02-02 20:05:01 ) [timeout:protected] => [category:protected] => {"heating":"0","security":"0","energy":"0","light":"0","automatism":"0","multimedia":"0","default":"0"} [display:protected] => {"showObjectNameOnview":1,"showObjectNameOndview":1,"showObjectNameOnmview":1,"height":"auto","width":"auto","layout::dashboard::table::parameters":{"center":1,"styletd":"padding:3px;"},"layout::mobile::table::parameters":{"center":1,"styletd":"padding:3px;"},"layout::dashboard::table::cmd::28618::line":1,"layout::dashboard::table::cmd::28618::column":1,"layout::dashboard::table::cmd::28617::line":1,"layout::dashboard::table::cmd::28617::column":1,"layout::dashboard::table::cmd::28619::line":1,"layout::dashboard::table::cmd::28619::column":1,"layout::dashboard::table::cmd::28620::line":1,"layout::dashboard::table::cmd::28620::column":1,"layout::dashboard::table::cmd::28622::line":1,"layout::dashboard::table::cmd::28622::column":1,"layout::dashboard::table::cmd::28621::line":1,"layout::dashboard::table::cmd::28621::column":1,"layout::mobile::table::cmd::28618::line":1,"layout::mobile::table::cmd::28618::column":1,"layout::mobile::table::cmd::28617::line":1,"layout::mobile::table::cmd::28617::column":1,"layout::mobile::table::cmd::28619::line":1,"layout::mobile::table::cmd::28619::column":1,"layout::mobile::table::cmd::28620::line":1,"layout::mobile::table::cmd::28620::column":1,"layout::mobile::table::cmd::28622::line":1,"layout::mobile::table::cmd::28622::column":1,"layout::mobile::table::cmd::28621::line":1,"layout::mobile::table::cmd::28621::column":1} [order:protected] => 9999 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => ) [_needRefreshWidget:protected] => [_needRefreshAlert
:protected] => [_changed:protected] => 1 )
Hors je n’ai aucune commande sans nom (inclusion automatique)
, Que faire ? tout fonctionne parfaitement juste cette alarme qui remplie le log et les messages
