Nuki Smart Lock 3.0 Pro sous Jeedom
J’ai dû désactiver l’objet Nuki créé dans MQTT manager car il me fait planter mqtt2 toutes les 10 minutes très exactement.
Voici un extrait du log :
[2023-04-04 09:15:02][INFO] : Démarrage du démon MQTT Manager : sudo  /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.0.200:1883 --username jeedom --password password_Jeedom_ici --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey apiKeyici --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
[2023-04-04 09:15:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"homeassistant":{"lock":{"nuki_Nuki_ID_ici_lock":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e ","uniq_id":"Nuki_ID_ici_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_jam":"254","val_tpl":"{% if value in (\"5\",\"6\",\"7\") %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_Nuki_ID_ici_lock_battery_critical":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery critical","uniq_id":"Nuki_ID_ici_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_Nuki_ID_ici_battery_charging":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery charging","uniq_id":"Nuki_ID_ici_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_Nuki_ID_ici_battery_percent":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery","uniq_id":"Nuki_ID_ici_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_Nuki_ID_ici_unlatch_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Unlatch","uniq_id":"Nuki_ID_ici_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3"}},"nuki_Nuki_ID_ici_lockngo_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go","uniq_id":"Nuki_ID_ici_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4"}},"nuki_Nuki_ID_ici_lock_n_go_unlatch":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go with unlatch","uniq_id":"Nuki_ID_ici_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5"}}}}}
[2023-04-04 09:15:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"nuki":{"Nuki_ID_ici":{"connected":true,"deviceType":4,"name":"Porte d'entr\u00e9e ","firmware":"3.5.12","serverConnected":true,"state":3,"mode":2,"doorsensorState":0,"batteryCritical":false,"batteryChargeState":29,"batteryCharging":false,"keypadBatteryCritical":false,"doorsensorBatteryCritical":false,"timestamp":"2023-04-04T05:19:24Z"}}}
[2023-04-04 09:15:03][DEBUG] : [Sécurité][Nuki][Batterie critique]  mise à jour de  la valeur avec  :
[2023-04-04 09:15:03][DEBUG] : [Sécurité][Nuki][Charge Batterie]  mise à jour de  la valeur avec  : 29
[2023-04-04 09:15:03][DEBUG] : [Sécurité][Nuki][Etat]  mise à jour de  la valeur avec  : 3
[2023-04-04 09:25:02][INFO] : Démarrage du démon MQTT Manager : sudo  /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.0.200:1883 --username jeedom --password password_Jeedom_ici --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey apiKeyici --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
[2023-04-04 09:25:02][DEBUG] : Message reçu sans prise en charge par un plugin : {"homeassistant":{"lock":{"nuki_Nuki_ID_ici_lock":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e ","uniq_id":"Nuki_ID_ici_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_jam":"254","val_tpl":"{% if value in (\"5\",\"6\",\"7\") %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_Nuki_ID_ici_lock_battery_critical":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery critical","uniq_id":"Nuki_ID_ici_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_Nuki_ID_ici_battery_charging":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery charging","uniq_id":"Nuki_ID_ici_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_Nuki_ID_ici_battery_percent":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery","uniq_id":"Nuki_ID_ici_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_Nuki_ID_ici_unlatch_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Unlatch","uniq_id":"Nuki_ID_ici_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3"}},"nuki_Nuki_ID_ici_lockngo_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go","uniq_id":"Nuki_ID_ici_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4"}},"nuki_Nuki_ID_ici_lock_n_go_unlatch":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go with unlatch","uniq_id":"Nuki_ID_ici_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5"}}}}}
[2023-04-04 09:25:02][DEBUG] : Message reçu sans prise en charge par un plugin : {"nuki":{"Nuki_ID_ici":{"connected":true,"deviceType":4,"name":"Porte d'entr\u00e9e ","firmware":"3.5.12","serverConnected":true,"state":3,"mode":2,"doorsensorState":0,"batteryCritical":false,"batteryChargeState":29,"batteryCharging":false,"keypadBatteryCritical":false,"doorsensorBatteryCritical":false,"timestamp":"2023-04-04T05:19:24Z"}}}
[2023-04-04 09:25:02][DEBUG] : [Sécurité][Nuki][Batterie critique]  mise à jour de  la valeur avec  :
[2023-04-04 09:25:02][DEBUG] : [Sécurité][Nuki][Charge Batterie]  mise à jour de  la valeur avec  : 29
[2023-04-04 09:25:02][DEBUG] : [Sécurité][Nuki][Etat]  mise à jour de  la valeur avec  : 3
[2023-04-04 09:30:02][INFO] : Démarrage du démon MQTT Manager : sudo  /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.0.200:1883 --username jeedom --password password_Jeedom_ici --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey apiKeyici --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
[2023-04-04 09:30:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"homeassistant":{"lock":{"nuki_Nuki_ID_ici_lock":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e ","uniq_id":"Nuki_ID_ici_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_jam":"254","val_tpl":"{% if value in (\"5\",\"6\",\"7\") %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_Nuki_ID_ici_lock_battery_critical":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery critical","uniq_id":"Nuki_ID_ici_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_Nuki_ID_ici_battery_charging":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery charging","uniq_id":"Nuki_ID_ici_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_Nuki_ID_ici_battery_percent":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery","uniq_id":"Nuki_ID_ici_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_Nuki_ID_ici_unlatch_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Unlatch","uniq_id":"Nuki_ID_ici_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3"}},"nuki_Nuki_ID_ici_lockngo_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go","uniq_id":"Nuki_ID_ici_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4"}},"nuki_Nuki_ID_ici_lock_n_go_unlatch":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go with unlatch","uniq_id":"Nuki_ID_ici_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5"}}}}}
[2023-04-04 09:30:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"nuki":{"Nuki_ID_ici":{"connected":true,"deviceType":4,"name":"Porte d'entr\u00e9e ","firmware":"3.5.12","serverConnected":true,"state":3,"mode":2,"doorsensorState":0,"batteryCritical":false,"batteryChargeState":29,"batteryCharging":false,"keypadBatteryCritical":false,"doorsensorBatteryCritical":false,"timestamp":"2023-04-04T05:19:24Z"}}}
[2023-04-04 09:30:03][DEBUG] : [Sécurité][Nuki][Batterie critique]  mise à jour de  la valeur avec  :
[2023-04-04 09:30:03][DEBUG] : [Sécurité][Nuki][Charge Batterie]  mise à jour de  la valeur avec  : 29
[2023-04-04 09:30:03][DEBUG] : [Sécurité][Nuki][Etat]  mise à jour de  la valeur avec  : 3
[2023-04-04 09:40:02][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2023-04-04 09:40:02
[2023-04-04 09:40:02][INFO] : Démarrage du démon MQTT Manager : sudo  /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.0.200:1883 --username jeedom --password password_Jeedom_ici --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey apiKeyici --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
[2023-04-04 09:40:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"homeassistant":{"lock":{"nuki_Nuki_ID_ici_lock":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e ","uniq_id":"Nuki_ID_ici_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_jam":"254","val_tpl":"{% if value in (\"5\",\"6\",\"7\") %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_Nuki_ID_ici_lock_battery_critical":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery critical","uniq_id":"Nuki_ID_ici_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_Nuki_ID_ici_battery_charging":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery charging","uniq_id":"Nuki_ID_ici_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_Nuki_ID_ici_battery_percent":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery","uniq_id":"Nuki_ID_ici_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_Nuki_ID_ici_unlatch_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Unlatch","uniq_id":"Nuki_ID_ici_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3"}},"nuki_Nuki_ID_ici_lockngo_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go","uniq_id":"Nuki_ID_ici_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4"}},"nuki_Nuki_ID_ici_lock_n_go_unlatch":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go with unlatch","uniq_id":"Nuki_ID_ici_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5"}}}}}
[2023-04-04 09:40:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"nuki":{"Nuki_ID_ici":{"connected":true,"deviceType":4,"name":"Porte d'entr\u00e9e ","firmware":"3.5.12","serverConnected":true,"state":3,"mode":2,"doorsensorState":0,"batteryCritical":false,"batteryChargeState":29,"batteryCharging":false,"keypadBatteryCritical":false,"doorsensorBatteryCritical":false,"timestamp":"2023-04-04T05:19:24Z"}}}
[2023-04-04 09:40:03][DEBUG] : [Sécurité][Nuki][Batterie critique]  mise à jour de  la valeur avec  :
[2023-04-04 09:40:03][DEBUG] : [Sécurité][Nuki][Charge Batterie]  mise à jour de  la valeur avec  : 29
[2023-04-04 09:40:03][DEBUG] : [Sécurité][Nuki][Etat]  mise à jour de  la valeur avec  : 3
[2023-04-04 09:50:02][INFO] : Démarrage du démon MQTT Manager : sudo  /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.0.200:1883 --username jeedom --password password_Jeedom_ici --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey apiKeyici --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
[2023-04-04 09:50:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"homeassistant":{"lock":{"nuki_Nuki_ID_ici_lock":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e ","uniq_id":"Nuki_ID_ici_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_jam":"254","val_tpl":"{% if value in (\"5\",\"6\",\"7\") %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_Nuki_ID_ici_lock_battery_critical":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery critical","uniq_id":"Nuki_ID_ici_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_Nuki_ID_ici_battery_charging":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery charging","uniq_id":"Nuki_ID_ici_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_Nuki_ID_ici_battery_percent":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery","uniq_id":"Nuki_ID_ici_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_Nuki_ID_ici_unlatch_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Unlatch","uniq_id":"Nuki_ID_ici_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3"}},"nuki_Nuki_ID_ici_lockngo_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go","uniq_id":"Nuki_ID_ici_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4"}},"nuki_Nuki_ID_ici_lock_n_go_unlatch":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go with unlatch","uniq_id":"Nuki_ID_ici_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5"}}}}}
[2023-04-04 09:50:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"nuki":{"Nuki_ID_ici":{"connected":true,"deviceType":4,"name":"Porte d'entr\u00e9e ","firmware":"3.5.12","serverConnected":true,"state":3,"mode":2,"doorsensorState":0,"batteryCritical":false,"batteryChargeState":29,"batteryCharging":false,"keypadBatteryCritical":false,"doorsensorBatteryCritical":false,"timestamp":"2023-04-04T05:19:24Z"}}}
[2023-04-04 09:50:03][DEBUG] : [Sécurité][Nuki][Batterie critique]  mise à jour de  la valeur avec  :
[2023-04-04 09:50:03][DEBUG] : [Sécurité][Nuki][Charge Batterie]  mise à jour de  la valeur avec  : 29
[2023-04-04 09:50:03][DEBUG] : [Sécurité][Nuki][Etat]  mise à jour de  la valeur avec  : 3
[2023-04-04 10:00:02][INFO] : Démarrage du démon MQTT Manager : sudo  /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.0.200:1883 --username jeedom --password password_Jeedom_ici --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey apiKeyici --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
[2023-04-04 10:00:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"homeassistant":{"lock":{"nuki_Nuki_ID_ici_lock":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e ","uniq_id":"Nuki_ID_ici_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_jam":"254","val_tpl":"{% if value in (\"5\",\"6\",\"7\") %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_Nuki_ID_ici_lock_battery_critical":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery critical","uniq_id":"Nuki_ID_ici_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_Nuki_ID_ici_battery_charging":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery charging","uniq_id":"Nuki_ID_ici_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_Nuki_ID_ici_battery_percent":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Battery","uniq_id":"Nuki_ID_ici_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_Nuki_ID_ici_unlatch_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Unlatch","uniq_id":"Nuki_ID_ici_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3"}},"nuki_Nuki_ID_ici_lockngo_button":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go","uniq_id":"Nuki_ID_ici_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4"}},"nuki_Nuki_ID_ici_lock_n_go_unlatch":{"config":{"~":"nuki\/Nuki_ID_ici","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[Nuki_ID_ici]","mf":"Nuki","name":"Porte d'entr\u00e9e ","mdl":"Smart Lock 3.0 Pro"},"name":"Porte d'entr\u00e9e  Lock 'n' Go with unlatch","uniq_id":"Nuki_ID_ici_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5"}}}}}
[2023-04-04 10:00:03][DEBUG] : Message reçu sans prise en charge par un plugin : {"nuki":{"Nuki_ID_ici":{"connected":true,"deviceType":4,"name":"Porte d'entr\u00e9e ","firmware":"3.5.12","serverConnected":true,"state":3,"mode":2,"doorsensorState":0,"batteryCritical":false,"batteryChargeState":29,"batteryCharging":false,"keypadBatteryCritical":false,"doorsensorBatteryCritical":false,"timestamp":"2023-04-04T05:19:24Z"}}}
[2023-04-04 10:00:03][DEBUG] : [Sécurité][Nuki][Batterie critique]  mise à jour de  la valeur avec  :
[2023-04-04 10:00:03][DEBUG] : [Sécurité][Nuki][Charge Batterie]  mise à jour de  la valeur avec  : 29
[2023-04-04 10:00:03][DEBUG] : [Sécurité][Nuki][Etat]  mise à jour de  la valeur avec  : 3
