Nouveau service webhooks sur Netatmo connect
J’ai reçu ce mail de Legrand pour Netatmo connect.
J’utilise le plugin officiel Netatmo stable v2026-10-21 01:06:06 et le plugin Netatmo OpenData (netatmoPublicData) - stable 2026-09-10 01:25:58.
Au terme de leur migration y aura t-il un impact et que faut-il anticiper pour assurer la continuité du service.
New Webhooks Are Now Available
Netatmo Connect API Update
Hello Developers,
We are pleased to announce the availability of our new webhook service on Netatmo Connect.
These webhooks provide a faster, more efficient, and scalable way to receive device events without relying on frequent polling requests.
Important API Update
Starting March 1st, 2027, we plan to reduce API rate limits for polling-based integrations.
We encourage you to start migrating to webhooks for supported products to prepare for this change.
What’s New?
✓ Faster event delivery
✓ Support for a broader range of products and gateways
✓ Reduced reliance on polling
✓ Consistent configuration across all new webhooks
These webhooks are associated with supported gateways and can be used across multiple product families connected to those gateways.
How to Get Started
To start receiving device events, follow our webhook documentation to configure your integration.
Get Started
Supported products and gateways, configuration guides, migration recommendations, and implementation examples.
Deployment Timeline
November 4th, 2026 — Migration Period Begins
A migration period will begin, allowing you to update your existing integrations and adopt webhooks.
Existing integrations will continue to work as they do today during this period.
March 1st, 2027 — Planned Rate Limit Changes
The new rate limits for polling-based integrations are planned to take effect.
We strongly encourage you to migrate existing integrations to webhooks and adopt this approach for future integrations with supported products.
Additional details about upcoming rate limit changes will be communicated before they take effect.
Need Help?
If you have any questions regarding migration, implementation, or best practices, please contact us:
contact-api@netatmo.com
Best regards,
The Netatmo API Team
Ces modifications porteront sur les webhooks (pushs automatique qui arrivent depuis les serveurs Netatmo).
Le mail stipule des améliorations de ces services (fluidité,…) mais en revanche ils prévoient une baisse des quotas api ( moins d’interrogations possibles). Pour un usage classique peu d’impacts probable.
Pour l’instant ça ne semble pas encore actifs.
