Bonjour à tous
depuis la mise à jours je n’ai plus de notification sur mon iphone, je sais que dans le changelog il y a un problème de notification avec ios.
je voulais savoir si tu a trouvé une parade .
voici les infos :
0590|[2024-09-10 03:00:03] DEBUG : saveConfiguration details received for id : 37 - conf : {"name":"Demain, #3557#","subtitle":"#value#\u00b0C | #3562#\u00b0C","statusInfo":{"id":"3561","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p12j.png","shadow":false},"statusImages":[],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"id":3562,"name":"M\u00e9t\u00e9o du Jour - Demain - Temp\u00e9rature Maximum","unit":" \u00b0C","index":0},{"id":3557,"name":"M\u00e9t\u00e9o du Jour - Demain - Description","unit":"","index":1}],"id":37}
0591|[2024-09-10 03:00:03] DEBUG : saveConfiguration done
0592|[2024-09-10 03:00:03] DEBUG : Checking if widget 37 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0593|[2024-09-10 03:00:03] DEBUG : 37 NOT found in the current equipment
0594|[2024-09-10 03:00:03] DEBUG : Checking if widget 37 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0595|[2024-09-10 03:00:03] DEBUG : 37 NOT found in the current equipment
0596|[2024-09-10 03:00:03] DEBUG : updateConfig - key "image" found - updating details id [39] - conf : Array
0597|[2024-09-10 03:00:03] DEBUG : saveConfiguration details received for id : 39 - conf : {"name":"#3686# #3633#","subtitle":"#3623# \u00b0C | #3624# \u00b0C","statusInfo":{"id":"3624","type":"info","subType":"numeric","step":"1"},"showGauge":false,"image":{"source":"user","name":"p12j.png","shadow":false},"statusImages":[],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":false,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3633","name":"M\u00e9t\u00e9o du Jour - J+3 - Description","unit":"","index":0},{"type":"cmd","id":"3623","name":"M\u00e9t\u00e9o du Jour - J+3 - Temp\u00e9rature Minimum","unit":"","index":1},{"type":"cmd","id":"3686","name":"apr\u00e8s apr\u00e8s demain","unit":"","index":2}],"id":39}
0598|[2024-09-10 03:00:03] DEBUG : saveConfiguration done
0599|[2024-09-10 03:00:03] DEBUG : Checking if widget 39 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0600|[2024-09-10 03:00:03] DEBUG : 39 NOT found in the current equipment
0601|[2024-09-10 03:00:03] DEBUG : Checking if widget 39 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0602|[2024-09-10 03:00:03] DEBUG : 39 NOT found in the current equipment
0603|[2024-09-10 03:00:04] DEBUG : updateConfig - key "image" found - updating details id [38] - conf : Array
0604|[2024-09-10 03:00:04] DEBUG : saveConfiguration details received for id : 38 - conf : {"name":"#3685# #3564#","subtitle":"#3568# \u00b0C | #3569# \u00b0C","statusInfo":{"id":"3569","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p12j.png","shadow":false},"statusImages":[{"index":0,"image":[],"condition":"#3632#"}],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":false,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3564","name":"M\u00e9t\u00e9o du Jour - Surlendemain - Description","unit":"","index":0},{"type":"cmd","id":"3568","name":"M\u00e9t\u00e9o du Jour - Surlendemain - Temp\u00e9rature Minimum","unit":" \u00b0C","index":1},{"type":"cmd","id":"3685","name":"apr\u00e8s demain","unit":"","index":2},{"type":"cmd","id":"3632","name":"M\u00e9t\u00e9o du Jour - J+3 - Icone","unit":"","index":3}],"id":38}
0605|[2024-09-10 03:00:04] DEBUG : saveConfiguration done
0606|[2024-09-10 03:00:04] DEBUG : Checking if widget 38 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0607|[2024-09-10 03:00:04] DEBUG : 38 NOT found in the current equipment
0608|[2024-09-10 03:00:04] DEBUG : Checking if widget 38 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0609|[2024-09-10 03:00:04] DEBUG : 38 NOT found in the current equipment
0610|[2024-09-10 03:00:04] DEBUG : updateConfig - key "image" found - updating details id [33] - conf : Array
0611|[2024-09-10 03:00:04] DEBUG : saveConfiguration details received for id : 33 - conf : {"name":"En ce moment : #3550#","subtitle":"Ressenti : #3627# \u00b0C\nHumidit\u00e9 : #3622# % - Couverture nuageuse : #3619# %","statusInfo":{"id":"3621","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p3j.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"widget","type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3627","name":"M\u00e9t\u00e9o Actuellement - Temp\u00e9rature Ressentie","unit":"","index":0,"uniqueId":142},{"type":"cmd","id":"3622","name":"M\u00e9t\u00e9o Actuellement - Humidit\u00e9","unit":"","index":1,"uniqueId":328},{"type":"cmd","id":"3619","name":"M\u00e9t\u00e9o Actuellement - Couverture Nuageuse","unit":"","index":2,"uniqueId":864},{"type":"cmd","id":"3550","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Description","unit":"","index":3,"uniqueId":784}],"id":33}
0612|[2024-09-10 03:00:04] DEBUG : saveConfiguration done
0613|[2024-09-10 03:00:04] DEBUG : Checking if widget 33 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0614|[2024-09-10 03:00:04] DEBUG : 33 NOT found in the current equipment
0615|[2024-09-10 03:00:04] DEBUG : Checking if widget 33 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0616|[2024-09-10 03:00:04] DEBUG : 33 NOT found in the current equipment
0617|[2024-09-10 03:00:04] DEBUG : updateConfig - key "image" found - updating details id [35] - conf : Array
0618|[2024-09-10 03:00:04] DEBUG : saveConfiguration details received for id : 35 - conf : {"id":35,"name":"Aujourd'hui, #3550#","subtitle":"#3554# \u00b0C | #3555# \u00b0C\nPluie : #3549# mm - Indice UV : #3556#","statusInfo":{"id":"3555","type":"info","subType":"numeric","step":"1"},"showGauge":false,"image":{"source":"user","name":"p3j.png","shadow":false},"statusImages":[{"index":0,"image":[],"condition":"#3549#"},{"index":1,"image":[],"condition":"#3550#"},{"index":2,"image":[],"condition":"#3556#"},{"index":3,"image":[],"condition":"#3554#"}],"display":"widget","type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3549","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Cumul Pluie","unit":"mm","index":0,"uniqueId":848},{"type":"cmd","id":"3550","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Description","unit":"","index":1,"uniqueId":946},{"type":"cmd","id":"3556","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Indice UV","unit":" UV","index":2,"uniqueId":438},{"type":"cmd","id":"3554","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Temp\u00e9rature Minimum","unit":" \u00b0C","index":3,"uniqueId":240},{"type":"cmd","id":"3555","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Temp\u00e9rature Maximum","unit":" \u00b0C","index":4,"uniqueId":542}]}
0619|[2024-09-10 03:00:04] DEBUG : saveConfiguration done
0620|[2024-09-10 03:00:04] DEBUG : Checking if widget 35 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0621|[2024-09-10 03:00:04] DEBUG : 35 NOT found in the current equipment
0622|[2024-09-10 03:00:04] DEBUG : Checking if widget 35 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0623|[2024-09-10 03:00:04] DEBUG : 35 NOT found in the current equipment
0624|[2024-09-10 03:00:04] DEBUG : updateConfig - key "image" found - updating details id [37] - conf : Array
0625|[2024-09-10 03:00:04] DEBUG : saveConfiguration details received for id : 37 - conf : {"name":"Demain, #3557#","subtitle":"#value#\u00b0C | #3562#\u00b0C","statusInfo":{"id":"3561","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p12j.png","shadow":false},"statusImages":[],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"id":3562,"name":"M\u00e9t\u00e9o du Jour - Demain - Temp\u00e9rature Maximum","unit":" \u00b0C","index":0},{"id":3557,"name":"M\u00e9t\u00e9o du Jour - Demain - Description","unit":"","index":1}],"id":37}
0626|[2024-09-10 03:00:04] DEBUG : saveConfiguration done
0627|[2024-09-10 03:00:04] DEBUG : Checking if widget 37 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0628|[2024-09-10 03:00:04] DEBUG : 37 NOT found in the current equipment
0629|[2024-09-10 03:00:04] DEBUG : Checking if widget 37 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0630|[2024-09-10 03:00:04] DEBUG : 37 NOT found in the current equipment
0631|[2024-09-10 03:00:04] DEBUG : updateConfig - key "image" found - updating details id [39] - conf : Array
0632|[2024-09-10 03:00:04] DEBUG : saveConfiguration details received for id : 39 - conf : {"name":"#3686# #3633#","subtitle":"#3623# \u00b0C | #3624# \u00b0C","statusInfo":{"id":"3624","type":"info","subType":"numeric","step":"1"},"showGauge":false,"image":{"source":"user","name":"p1j.png","shadow":false},"statusImages":[],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":false,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3633","name":"M\u00e9t\u00e9o du Jour - J+3 - Description","unit":"","index":0},{"type":"cmd","id":"3623","name":"M\u00e9t\u00e9o du Jour - J+3 - Temp\u00e9rature Minimum","unit":"","index":1},{"type":"cmd","id":"3686","name":"apr\u00e8s apr\u00e8s demain","unit":"","index":2}],"id":39}
0633|[2024-09-10 03:00:04] DEBUG : saveConfiguration done
0634|[2024-09-10 03:00:04] DEBUG : Checking if widget 39 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0635|[2024-09-10 03:00:04] DEBUG : 39 NOT found in the current equipment
0636|[2024-09-10 03:00:04] DEBUG : Checking if widget 39 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0637|[2024-09-10 03:00:04] DEBUG : 39 NOT found in the current equipment
0638|[2024-09-10 03:00:05] DEBUG : updateConfig - key "image" found - updating details id [38] - conf : Array
0639|[2024-09-10 03:00:05] DEBUG : saveConfiguration details received for id : 38 - conf : {"name":"#3685# #3564#","subtitle":"#3568# \u00b0C | #3569# \u00b0C","statusInfo":{"id":"3569","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p12j.png","shadow":false},"statusImages":[{"index":0,"image":[],"condition":"#3632#"}],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":false,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3564","name":"M\u00e9t\u00e9o du Jour - Surlendemain - Description","unit":"","index":0},{"type":"cmd","id":"3568","name":"M\u00e9t\u00e9o du Jour - Surlendemain - Temp\u00e9rature Minimum","unit":" \u00b0C","index":1},{"type":"cmd","id":"3685","name":"apr\u00e8s demain","unit":"","index":2},{"type":"cmd","id":"3632","name":"M\u00e9t\u00e9o du Jour - J+3 - Icone","unit":"","index":3}],"id":38}
0640|[2024-09-10 03:00:05] DEBUG : saveConfiguration done
0641|[2024-09-10 03:00:05] DEBUG : Checking if widget 38 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0642|[2024-09-10 03:00:05] DEBUG : 38 NOT found in the current equipment
0643|[2024-09-10 03:00:05] DEBUG : Checking if widget 38 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0644|[2024-09-10 03:00:05] DEBUG : 38 NOT found in the current equipment
0645|[2024-09-10 03:00:05] DEBUG : updateConfig - key "image" found - updating details id [33] - conf : Array
0646|[2024-09-10 03:00:05] DEBUG : saveConfiguration details received for id : 33 - conf : {"name":"En ce moment : #3550#","subtitle":"Ressenti : #3627# \u00b0C\nHumidit\u00e9 : #3622# % - Couverture nuageuse : #3619# %","statusInfo":{"id":"3621","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p3j.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"widget","type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3627","name":"M\u00e9t\u00e9o Actuellement - Temp\u00e9rature Ressentie","unit":"","index":0,"uniqueId":142},{"type":"cmd","id":"3622","name":"M\u00e9t\u00e9o Actuellement - Humidit\u00e9","unit":"","index":1,"uniqueId":328},{"type":"cmd","id":"3619","name":"M\u00e9t\u00e9o Actuellement - Couverture Nuageuse","unit":"","index":2,"uniqueId":864},{"type":"cmd","id":"3550","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Description","unit":"","index":3,"uniqueId":784}],"id":33}
0647|[2024-09-10 03:00:05] DEBUG : saveConfiguration done
0648|[2024-09-10 03:00:05] DEBUG : Checking if widget 33 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0649|[2024-09-10 03:00:05] DEBUG : 33 NOT found in the current equipment
0650|[2024-09-10 03:00:05] DEBUG : Checking if widget 33 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0651|[2024-09-10 03:00:05] DEBUG : 33 NOT found in the current equipment
0652|[2024-09-10 03:00:05] DEBUG : updateConfig - key "image" found - updating details id [35] - conf : Array
0653|[2024-09-10 03:00:05] DEBUG : saveConfiguration details received for id : 35 - conf : {"id":35,"name":"Aujourd'hui, #3550#","subtitle":"#3554# \u00b0C | #3555# \u00b0C\nPluie : #3549# mm - Indice UV : #3556#","statusInfo":{"id":"3555","type":"info","subType":"numeric","step":"1"},"showGauge":false,"image":{"source":"user","name":"p3j.png","shadow":false},"statusImages":[{"index":0,"image":[],"condition":"#3549#"},{"index":1,"image":[],"condition":"#3550#"},{"index":2,"image":[],"condition":"#3556#"},{"index":3,"image":[],"condition":"#3554#"}],"display":"widget","type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3549","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Cumul Pluie","unit":"mm","index":0,"uniqueId":848},{"type":"cmd","id":"3550","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Description","unit":"","index":1,"uniqueId":946},{"type":"cmd","id":"3556","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Indice UV","unit":" UV","index":2,"uniqueId":438},{"type":"cmd","id":"3554","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Temp\u00e9rature Minimum","unit":" \u00b0C","index":3,"uniqueId":240},{"type":"cmd","id":"3555","name":"M\u00e9t\u00e9o du Jour - Aujourdhui - Temp\u00e9rature Maximum","unit":" \u00b0C","index":4,"uniqueId":542}]}
0654|[2024-09-10 03:00:05] DEBUG : saveConfiguration done
0655|[2024-09-10 03:00:05] DEBUG : Checking if widget 35 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0656|[2024-09-10 03:00:05] DEBUG : 35 NOT found in the current equipment
0657|[2024-09-10 03:00:05] DEBUG : Checking if widget 35 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0658|[2024-09-10 03:00:05] DEBUG : 35 NOT found in the current equipment
0659|[2024-09-10 03:00:05] DEBUG : updateConfig - key "image" found - updating details id [37] - conf : Array
0660|[2024-09-10 03:00:05] DEBUG : saveConfiguration details received for id : 37 - conf : {"name":"Demain, #3557#","subtitle":"#value#\u00b0C | #3562#\u00b0C","statusInfo":{"id":"3561","type":"info","subType":"numeric","step":"1","unit":" \u00b0C"},"showGauge":false,"image":{"source":"user","name":"p12j.png","shadow":false},"statusImages":[],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":true,"enable":true,"room":2,"moreInfos":[{"id":3562,"name":"M\u00e9t\u00e9o du Jour - Demain - Temp\u00e9rature Maximum","unit":" \u00b0C","index":0},{"id":3557,"name":"M\u00e9t\u00e9o du Jour - Demain - Description","unit":"","index":1}],"id":37}
0661|[2024-09-10 03:00:05] DEBUG : saveConfiguration done
0662|[2024-09-10 03:00:05] DEBUG : Checking if widget 37 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0663|[2024-09-10 03:00:05] DEBUG : 37 NOT found in the current equipment
0664|[2024-09-10 03:00:05] DEBUG : Checking if widget 37 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0665|[2024-09-10 03:00:05] DEBUG : 37 NOT found in the current equipment
0666|[2024-09-10 03:00:05] DEBUG : updateConfig - key "image" found - updating details id [39] - conf : Array
0667|[2024-09-10 03:00:05] DEBUG : saveConfiguration details received for id : 39 - conf : {"name":"#3686# #3633#","subtitle":"#3623# \u00b0C | #3624# \u00b0C","statusInfo":{"id":"3624","type":"info","subType":"numeric","step":"1"},"showGauge":false,"image":{"source":"user","name":"p1j.png","shadow":false},"statusImages":[],"moreWidgets":[],"type":"generic-info-numeric","blockDetail":false,"enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"3633","name":"M\u00e9t\u00e9o du Jour - J+3 - Description","unit":"","index":0},{"type":"cmd","id":"3623","name":"M\u00e9t\u00e9o du Jour - J+3 - Temp\u00e9rature Minimum","unit":"","index":1},{"type":"cmd","id":"3686","name":"apr\u00e8s apr\u00e8s demain","unit":"","index":2}],"id":39}
0668|[2024-09-10 03:00:05] DEBUG : saveConfiguration done
0669|[2024-09-10 03:00:05] DEBUG : Checking if widget 39 exist on equipment "Téléphone Claire" [42b9255f2e6290f2885d51e7e53b9563]
0670|[2024-09-10 03:00:05] DEBUG : 39 NOT found in the current equipment
0671|[2024-09-10 03:00:05] DEBUG : Checking if widget 39 exist on equipment "Téléphone Stephane" [d23a1dfe09ec4edd3d7df904e5314841]
0672|[2024-09-10 03:00:05] DEBUG : 39 NOT found in the current equipment
0673|[2024-09-10 06:00:02] INFO : Send notification to [2948] with data {"type":"DISPLAY_NOTIF","payload":{"cmdId":"2948","title":"Jeedom","message":"Le ballon d'eau chaude \u00e0 chauff\u00e9 cette nuit.","answer":null,"timeout":null,"notificationId":17259408027079,"otherAskCmdId":null,"options":[],"files":[],"id":"defaultNotif","channel":"default","index":0,"time":1725940802,"category":[{"id":"defaultNotif","actions":[]}]}}
0674|[2024-09-10 06:00:03] DEBUG : JSON OUTPUT : "{\"SuccessCount\":1,\"FailureCount\":0,\"Responses\":[{\"Success\":true,\"MessageID\":\"projects\/jeedomconnect\/messages\/1725940802849165\",\"Error\":null}]}\n"
0675|[2024-09-10 06:00:03] DEBUG : -- SuccessCount : 1
0676|[2024-09-10 06:00:03] DEBUG : -- FailureCount : 0
0677|[2024-09-10 06:00:03] DEBUG : -- Responses :
0678|[2024-09-10 06:00:03] DEBUG : {"Success":true,"MessageID":"projects\/jeedomconnect\/messages\/1725940802849165","Error":null}
0679|[2024-09-10 07:47:49] DEBUG : [API] Request Received {"method":"PING","jsonrpc":"2.0","id":1725947269781,"params":{"apiKey":"42b9255f2e6290f2885d51e7e53b9563"}}
0680|[2024-09-10 07:47:49] DEBUG : [API] Send PING -> null
0681|[2024-09-10 07:47:51] DEBUG : [API] Request Received {"method":"CONNECT","params":{"apiKey":"42b9255f2e6290f2885d51e7e53b9563","deviceId":"00B9EF53-9ABC-42EE-B2DD-257AE44F315D","deviceName":"iPhone","userHash":"6qOXG4qLMg**********************","appVersion":"1.8.0","pluginRequire":"1.7.1","token":"cCDlG_OuFUEhosvHltw8CW:APA91bG6BNVqKZikgWIFY--zZgMQNPtyzSW8slFA4nqqSTx3QeSCoVKb5OLY_7B3n2ROFMvNz4HZbI-Mc7MmrNG8oL_d2fM6zPC9gz7jYwuNmmmjxByBSUXOQKUO4Y6E1_ZODnuNNqub","platformOs":"ios","osVersion":"17.6.1","appTypeVersion":"stable","buildVersion":"56"},"jsonrpc":"2.0","id":1725947271141}
0682|[2024-09-10 07:47:51] DEBUG : [API] Send CONNECT -> {"type":"WELCOME","payload":{"pluginVersion":"1.10.1","jeedomName":"Maison","serverId":"278101","eqName":"T\u00e9l\u00e9phone Claire","useWs":"0","polling":"1","userHash":"6qOXG4qLMg**********************","userId":"6","userName":"claire","userProfil":"user","userImgPath":"data\/img\/","configVersion":709,"notifsVersion":0,"scenariosEnabled":false,"webviewEnabled":false,"editEnabled":false,"getLogAllowed":false,"pluginConfig":{"useWs":"0","polling":"1","httpUrl":"https:\/\/home************","internalHttpUrl":"http:\/\/192.168.70.4","wsAddress":"ws:\/\/home.st**************","internalWsAddress":"ws:\/\/192.168.70.4:8090","pluginJeedomVersion":"v1.10.1"},"cmdInfo":[{"id":"3450","value":0,"modified":1724088290,"collectDate":1724088291,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"3447","value":0,"modified":1725720294,"collectDate":1725720295,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"3723","value":0,"modified":1725720297,"collectDate":1725720300,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"3297","value":0,"modified":1725913027,"collectDate":1725913028,"history":{"averageValue":0.5,"minValue":0,"maxValue":1,"tendance":"stable"}},{"id":"3300","value":0,"modified":1725913028,"collectDate":1725937330,"history":{"averageValue":9.1,"minValue":9.1,"maxValue":9.1,"tendance":"stable"}},{"id":"661","value":1,"modified":1722002284,"collectDate":1722002284,"history":{"averageValue":1,"minValue":1,"maxValue":1,"tendance":"stable"}},{"id":"658","value":8,"modified":1673187288,"collectDate":1673187288,"history":{"averageValue":8,"minValue":8,"maxValue":8,"tendance":"stable"}},{"id":"665","value":-999.9,"modified":1671287289,"collectDate":1671287289,"history":{"averageValue":-999.9,"minValue":-999.9,"maxValue":-999.9,"tendance":"stable"}},{"id":"667","value":19,"modified":1692604805,"collectDate":1692604805,"history":{"averageValue":19,"minValue":19,"maxValue":19,"tendance":"stable"}},{"id":"673","value":"Aucun","modified":1703724568,"collectDate":1703724568,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"662","value":"","modified":false,"collectDate":false,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"508","value":0,"modified":1673186981,"collectDate":1673186981,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"505","value":15,"modified":1673186800,"collectDate":1673186800,"history":{"averageValue":15,"minValue":15,"maxValue":15,"tendance":"stable"}},{"id":"3412","value":-999.9,"modified":1671291242,"collectDate":1684251902,"history":{"averageValue":-999.9,"minValue":-999.9,"maxValue":-999.9,"tendance":"stable"}},{"id":"514","value":19,"modified":1692604805,"collectDate":1692604805,"history":{"averageValue":19,"minValue":19,"maxValue":19,"tendance":"stable"}},{"id":"520","value":"Off","modified":1673186981,"collectDate":1684253927,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"523","value":0,"modified":1673186981,"collectDate":1673186981,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"509","value":"","modified":false,"collectDate":false,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"3405","value":0,"modified":1674250571,"collectDate":1684253987,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"486","value":0,"modified":1649832722,"collectDate":1686346512,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"483","value":14,"modified":1668454789,"collectDate":1668454966,"history":{"averageValue":14,"minValue":14,"maxValue":14,"tendance":"stable"}},{"id":"3365","value":19.8,"modified":1684252960,"collectDate":1701825372,"history":{"averageValue":19.8,"minValue":19.8,"maxValue":19.8,"tendance":"stable"}},{"id":"492","value":19,"modified":1692604805,"collectDate":1692604805,"history":{"averageValue":19,"minValue":19,"maxValue":19,"tendance":"stable"}},{"id":"498","value":"Off","modified":1686346514,"collectDate":1686346516,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"502","value":0,"modified":1649832722,"collectDate":1686346512,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"487","value":"","modified":false,"collectDate":false,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"3358","value":0,"modified":1671290018,"collectDate":1701825372,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":null}},{"id":"5397","value":1,"modified":1725908558,"collectDate":1725908559,"history":{"averageValue":1,"minValue":1,"maxValue":1,"tendance":"stable"}},{"id":"3420","value":0,"modified":1725572739,"collectDate":1725572741,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"3229","value":0,"modified":1725838202,"collectDate":1725838202,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"3890","value":0,"modified":1725827764,"collectDate":1725827769,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"3895","value":0,"modified":1725827769,"collectDate":1725946565,"history":{"averageValue":0,"minValue":0,"maxValue":0,"tendance":"stable"}},{"id":"3307","value":0,"modified":1725912820,"collectDate":1725912820,"history":{"averageValue":0.5,"minValue":0,"maxValue":1,"tendance":"stable"}},{"id":"3287","value":1,"modified":1725946779,"collectDate":1725946780,"history":{"averageValue":0.5,"minValue":0,"maxValue":1,"tendance":"stable"}}],"scInfo":[],"objInfo":[{"object_id":"3","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"2","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":370,"cmds":[{"enable":"1","cmd":"#3865#","invert":"0"}]}}]},{"object_id":"4","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"global","keys":[{"security":{"value":null}},{"motion":{"value":null}},{"door":{"value":null}},{"windows":{"value":null}},{"shutter":{"value":null}},{"light":{"value":null}},{"outlet":{"value":null}},{"temperature":{"value":null}},{"humidity":{"value":null}},{"luminosity":{"value":null}},{"power":{"value":370}}]}],"geofenceInfo":{"geofences":[]},"links":[{"id":"doc","index":1,"img":"\/var\/www\/html\/plugins\/JeedomConnect\/data\/img\/doc.webp","title":"Documentation","link":"http:\/\/jared-94.github.io\/JeedomConnectDoc\/fr_FR\/index"},{"id":"changelog","index":2,"img":"\/var\/www\/html\/plugins\/JeedomConnect\/data\/img\/listmodif.webp","title":"Changelog","link":"http:\/\/jared-94.github.io\/JeedomConnectDoc\/fr_FR\/changelog"},{"id":"git","index":3,"img":"\/var\/www\/html\/plugins\/JeedomConnect\/data\/img\/github.webp","title":"Github du projet","link":"https:\/\/github.com\/jared-94\/JeedomConnect\/"},{"id":"donate","index":4,"img":"\/var\/www\/html\/plugins\/JeedomConnect\/data\/img\/donate.webp","title":"Faire un don","link":"https:\/\/tinyurl.com\/JeedomConnect"},{"id":"community","index":5,"img":"\/var\/www\/html\/plugins\/JeedomConnect\/data\/img\/community.webp","title":"Aller sur le forum","link":"https:\/\/community.jeedom.com\/tag\/plugin-jeedomconnect"},{"id":"copyright","index":6,"img":"\/var\/www\/html\/plugins\/JeedomConnect\/data\/img\/copyright.webp","title":"Licence","link":"https:\/\/jared-94.github.io\/JeedomConnectDoc\/fr_FR\/license.html"}],"timezone":"Europe\/Brussels","timelineFolders":{"main":"Principal"}}}
0683|[2024-09-10 07:47:55] DEBUG : [API] Request Received {"method":"PING","jsonrpc":"2.0","id":1725947275164,"params":{"apiKey":"42b9255f2e6290f2885d51e7e53b9563"}}
0684|[2024-09-10 07:47:55] DEBUG : [API] Send PING -> null
