Hello everyone,
I’m experiencing an issue with my Jeedom system after performing several updates and I’m hoping someone can help.
Recently, Jeedom prompted me to update the following components:
- Jeedom core to version 4.5.3
- Docker Management (docker2)
- MQTT Manager (mqtt2)
- Z-Wave JS (zwavejs)
After completing all these updates, I noticed that I can no longer access Jeedom from my mobile phone when using mobile data (4G/5G). The connection only works when my phone is connected to the local WiFi network.
Before these updates, remote access via mobile data worked perfectly, so I suspect that one of the updates changed something related to network access, routing, or security settings.
I have been reading through the forum and trying to identify the cause, but so far I haven’t found a solution.
Has anyone experienced a similar issue or knows where I should look to fix this?
Thank you very much in advance.
Best regards.
PS: my local IP has changed, how can I reconfigure it? Could that be the cause?
Información Jeedom Atlas
Core : 4.5.3 (master)
DNS Jeedom Atlas : Sí
Plugin : Z-Wave JS
Versión : 2026-04-01 01:03:16 (stable)
Estado del demonio : Comenzó - (2026-04-23 18:50:04)
Santé
🟢 Material : Atlas
🟢 Sistema actualizado : Bueno
🟢 Cron activo : Bueno
🟢 Escenario activo : Bueno
🟢 Iniciado : Bueno 2026-02-02 15:46:02
🟢 Fecha del sistema (última hora registrada) : Bueno 2026-04-25 10:37:44 (2026-04-25 09:49:01)
🟢 Derechos Sudo : Bueno
🟢 Versión Jeedom : 4.5.3
🟢 Versión SO : debian 11.8
🟢 Versión PHP : 7.4.33
🟢 Número de procesos de Apache : 12
🟢 Versión SO : Linux JeedomAtlas 5.15.93-rockchip64 #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 aarch64 GNU/Linux [11.8]
🟢 Versión Base de datos : 10.5.21-MariaDB-0+deb11u1
🟢 Espacio disco libre : 80 %
🟢 Conexión activa/máxima/permitida : 11/19/151
🟢 Tamaño de la base de datos : 29.9 MB
🟢 Espacio libre en disco tmp : 99 %
🟢 Memoria disponible : 76 % (Total 3864 Mo)
🟢 Memoria suficiente : 0
🟢 Error de E / S : 0
🟢 Intercambio disponible : 100 % (Total 1932 Mo)
🟢 Intercambio : 100 %
🟢 Carga : 0.05 - 0.16 - 0.1
🟢 Configuración de la red interna : Bueno
🟢 Configuración de la red externa : Bueno
🟢 Nodo : v22.22.0
🟢 Pitón : Python 2.7.18
🟢 Pitón 3 : Python 3.9.2
🟢 Persistencia de la caché : Bueno
🟢 Apache privado tmp : Bueno
