Non, désolé, ce n’est pas aussi simple.
Avec la création d’un certificat chez NO-IP ou tout autre CA(Certification Authority), tu vas disposer de deux fichiers 1) un certificat signé par le CA qui valide ton host.nomdedomaine.crt et d’un fichier key que tu as généré lors de la comande openssl.
Maintenant, il va te falloir installer et activer ces fichiers pour le server web de Jeedom, c’est à dire Apache.
Voici la procédure mais ma langue technique est l’anglais. La suite est donc en Anglais
Connect to Jeedom via ssh and change to directory /etc/apache2.
All command refer to it.
Certificates file are my own wildard: star_xyz.xxxx This means star_xyz.key star_xyz.crt
Copy certificates
Create a directory for certificate and key, make it available to root only and copy file on it.
Directory for certificates is sslcert
mkdir sslcert
chown root:root sslcert
chmod 755 sslcert
File were copied in jeedom home directory via any tool. Move them to /etc/apache2/sslcert
mv /home/jeedom/star* sslcert
chown root:root sslcert/star*
Configuration
vhost config file are located in sites-available
For the used one, a link is present in sites-enabled
For jeedom, the default site is used. His file is 000-default.conf
Copy this to sites-enabled as 000-default-ssl.conf
cp sites-available/000-default.conf sites-available/000-default-ssl.conf
Edit this file, to obtain the following. The lines with a plus are concerned (Plus sign is only there for comment)
<VirtualHost *:443>
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
ErrorLog /var/www/html/log/http.error
+ SLEngine on
+ SSLCertificateFile /etc/apache2/sslcert/star_xyz.crt
+ SSLCertificateKeyFile /etc/apache2/sslcert/star_xyz.key
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Create symbolic link in sites-enabled for 000-default-ssl.conf
cd sites-enabled
ln -s /etc/apache2/sites-available/000-default-ssl.conf 000-default-ssl.conf
cd /etc/apache2
Activate modules in Apache
Activated modules have one or more link in mods-enabled to files in mods-available
Create symbolic link in mods-enabled for ssl.load, ssl-conf, socache_shmcb.load
cd mods-enabled
ln -s ../mods-available/ssl.conf ssl.conf
ln -s ../mods-available/ssl.load ssl.load
ln -s ../mods-available/socache_shmcb.load socache_shmcb.load
cd /etc/apache2
Verify and restart Apache
Verify config with
apachectl configtest`
If correct, Stop/start Apache. Otherwise correct and retest.
apachectl stop
apachectl start
Voila, j’espère que ceci te montre ou tu désires t’engager.
Bonne chance.
