La clef est POPP
Le Plugin est Zigbee de Jeedom SAS (Stable)
Voici les logs
[2023-06-26 19:43:09][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2023-06-26 19:43:09][DEBUG] : {"duration":180}
[2023-06-26 19:43:10][DEBUG] : ""
[2023-06-26 19:43:20][DEBUG] : {"device_joined":"a4:c1:38:c0:0b:58:dc:d8"}
[2023-06-26 19:43:21][DEBUG] : {"device_initialized":"a4:c1:38:c0:0b:58:dc:d8"}
[2023-06-26 19:43:22][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":[{"4":{"value":"_TZ3000_gvn91tmx","cluster_name":"Basic"},"5":{"value":"TS011F","cluster_name":"Basic"}}]}}}
[2023-06-26 19:43:23][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":[[{"value":"3","cluster_name":"Basic"},{"value":"77","cluster_name":"Basic"},{"value":"0","cluster_name":"Basic"},{"value":"1","cluster_name":"Basic"}]]}}}
[2023-06-26 19:43:24][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":[{"7":{"value":"PowerSource.Mains_single_phase","cluster_name":"Basic"}}]}}}
[2023-06-26 19:43:25][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":[{"6":{"value":"","cluster_name":"Basic"}}]}}}
[2023-06-26 19:43:25][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"1794":[{"value":"0","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-06-26 19:43:25][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"2820":{"1285":{"value":"229","cluster_name":"Electrical Measurement"},"1288":{"value":"0","cluster_name":"Electrical Measurement"},"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2023-06-26 19:43:27][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"6":{"0":{"value":"Bool.false","cluster_name":"On\/Off"},"16385":{"value":"0","cluster_name":"On\/Off"},"16386":{"value":"0","cluster_name":"On\/Off"},"32769":{"value":"SwitchBackLight.Mode_1","cluster_name":"On\/Off"},"32770":{"value":"PowerOnState.LastState","cluster_name":"On\/Off"},"20480":{"value":"enum8.undefined_0x01","cluster_name":"On\/Off"},"32768":{"value":"Bool.false","cluster_name":"On\/Off"}}}}}}
[2023-06-26 19:43:27][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"57345":{"53264":{"value":"enum8.undefined_0x02","cluster_name":"Tuya External Switch Type Cluster"},"53296":{"value":"ExternalSwitchType.Toggle","cluster_name":"Tuya External Switch Type Cluster"},"53248":{"value":"1","cluster_name":"Tuya External Switch Type Cluster"},"53249":{"value":"bitmap32.0","cluster_name":"Tuya External Switch Type Cluster"},"53250":{"value":"3037879","cluster_name":"Tuya External Switch Type Cluster"},"53251":{"value":"122","cluster_name":"Tuya External Switch Type Cluster"},"53252":{"value":"10160","cluster_name":"Tuya External Switch Type Cluster"},"53253":{"value":"1185","cluster_name":"Tuya External Switch Type Cluster"}}}}}}
[2023-06-26 19:43:33][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2023-06-26 19:43:51][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2023-06-26 19:43:51][DEBUG] : {"with_attributes":2}
[2023-06-26 19:43:53][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2023-06-26 19:43:53][DEBUG] : null
[2023-06-26 19:43:53][DEBUG] : http://127.0.0.1:8089/device/info?ieee=a4%3Ac1%3A38%3Ac0%3A0b%3A58%3Adc%3Ad8 type : GET
[2023-06-26 19:43:53][DEBUG] : {"ieee":"a4:c1:38:c0:0b:58:dc:d8"}
[2023-06-26 19:44:44][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-06-26 19:44:44][DEBUG] : {"ieee":"a4:c1:38:c0:0b:58:dc:d8","endpoint":11,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-06-26 19:44:44][INFO] : [Aucun][TZ3000_gvn91tmx.TS011F a4:c1:38:c0:0b:58:dc:d8] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:c0:0b:58:dc:d8","endpoint":11,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Endpoint not found : 11","code":0}
[2023-06-26 19:45:11][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2023-06-26 19:45:11][DEBUG] : null
[2023-06-26 19:45:21][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-06-26 19:45:21][DEBUG] : {"ieee":"a4:c1:38:c0:0b:58:dc:d8","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-06-26 19:45:21][DEBUG] : [Aucun][TZ3000_gvn91tmx.TS011F a4:c1:38:c0:0b:58:dc:d8] refresh
[2023-06-26 19:45:21][DEBUG] : {"ieee":"a4:c1:38:c0:0b:58:dc:d8","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-06-26 19:45:21][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2023-06-26 19:45:21][DEBUG] : Search attribut for a4:c1:38:c0:0b:58:dc:d8 logicalId : 1::6::0 => Bool.true convert to 1
[2023-06-26 19:45:21][DEBUG] : {"devices":{"a4:c1:38:c0:0b:58:dc:d8":{"1":{"1794":[{"value":"0","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-06-26 19:45:21][DEBUG] : Search attribut for a4:c1:38:c0:0b:58:dc:d8 logicalId : 1::1794::0 => 0 convert to 0
[2023-06-26 19:45:24][DEBUG] : {"devices":{"a4:c1:38:3f:9c:35:31:2c":{"1":{"1794":[{"value":"232","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-06-26 19:45:24][DEBUG] : Search attribut for a4:c1:38:3f:9c:35:31:2c logicalId : 1::1794::0 => 232 convert to 232
[2023-06-26 19:45:24][DEBUG] : {"devices":{"a4:c1:38:3f:9c:35:31:2c":{"1":{"1794":[{"value":"232","cluster_name":"TuyaZBMeteringCluster"}],"2820":{"1285":{"value":"232","cluster_name":"Electrical Measurement"},"1288":{"value":"0","cluster_name":"Electrical Measurement"},"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2023-06-26 19:45:24][DEBUG] : Search attribut for a4:c1:38:3f:9c:35:31:2c logicalId : 1::2820::1285 => 232 convert to 232
[2023-06-26 19:45:24][DEBUG] : Search attribut for a4:c1:38:3f:9c:35:31:2c logicalId : 1::2820::1288 => 0 convert to 0
[2023-06-26 19:45:24][DEBUG] : Search attribut for a4:c1:38:3f:9c:35:31:2c logicalId : 1::2820::1291 => 0 convert to 0
[2023-06-26 19:46:05][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2023-06-26 19:46:05][DEBUG] : {"ieee":"a4:c1:38:c0:0b:58:dc:d8","cmd":[{"endpoint":11,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2023-06-26 19:46:05][ERROR] : Erreur exécution de la commande [Maison David][Prise Halogene Zigbee][Off] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"a4:c1:38:c0:0b:58:dc:d8","cmd":[{"endpoint":11,"cluster":"on_off","command":"off","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[a4:c1:38:c0:0b:58:dc:d8][zdevices.command] Endpoint not found : 11","code":0}
