bonjour,
Mon demon mqtt de démarre plus avec l’erreur, je viens d’activer le SSL pour pouvoir joindre mon jeedom de l’exterieur, et j’ai l’impression que le mqtt essaye le http et ça coince…
Callback error.Please check your network configuration page…
AxiosError: Request failed with status code 400
at settle (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:2026:12)
at IncomingMessage.handleStreamEnd (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:3142:11)
at IncomingMessage.emit (node:events:531:35)
at endReadableNT (node:internal/streams/readable:1696:12)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
at Axios.request (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:4252:41)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
- Réponse de l’URL:
http://127.0.0.1/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=YIX5RkbgwDl55jteG7oWTjNGLGLPYEfehQ5uJwxeoJ6D2wOzq3dqonBSR9CaGXLj
- Code de statut:
400
- Message de statut:
Bad Request
merci pour votre aide !
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : non
Plugin : MQTT Manager
Version : 2024-11-26 01:20:08 (stable)
Statut Démon : Stoppé - (2024-11-28 23:15:02)
