Hélas, ce n’est pas très rassurant ce que tu me racontes @loustic03.
@SWR, j’ai regardé les logs, je trouve trop d’erreurs à mon gout mais pour autant rien ne colle en terme de timing :
openzwaved : j’ai bien des erreurs mais rien aux heures où j’ai rencontré le pb
2020-08-30 20:34:29.600 Always, OpenZwave Version 1.4.0 Starting Up
2020-08-30 22:29:33.684 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-30 22:29:37.688 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-30 22:29:41.692 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-30 22:29:45.822 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-31 18:38:10.155 Error, Node022, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-02 19:35:31.532 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-06 20:58:48.794 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-06 22:59:12.901 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-07 00:59:44.092 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-07 05:00:39.258 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-07 19:23:55.493 Error, Node016, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-08 15:08:36.973 Error, Node014, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-08 19:10:32.860 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-09 19:12:30.282 Error, Node014, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-11 03:21:22.040 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-12 19:09:30.655 Error, Node014, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-13 07:33:55.424 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-13 11:35:03.112 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-13 19:36:52.896 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-16 15:48:37.184 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-17 03:49:56.657 Error, Node013, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-09-17 03:50:00.649 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-17 03:50:04.653 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-17 17:51:57.466 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-17 21:52:20.533 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-18 07:53:40.100 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-18 15:54:47.945 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-18 18:59:29.797 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-19 05:56:15.511 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-20 18:36:30.978 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-21 22:54:43.326 Error, Node016, ERROR: Dropping command, expected response not received after 1 attempt(s)
openzwave : le dernier log date du 31/08/2020 avec cette erreur
[2020-08-31 09:04:26][ERROR] : Critical error on send_changes_async threads can only be started once
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-287315, stopped daemon 1926231152)>>
File "/usr/lib/python2.7/threading.py", line 774, in __bootstrap
self.__bootstrap_inner()
File "/usr/lib/python2.7/threading.py", line 789, in __bootstrap_inner
del _limbo[self]
KeyError: <_Timer(Thread-287315, stopped daemon 1926231152)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-544155, stopped daemon 1896871024)>>
del _limbo[self]
KeyError: <_Timer(Thread-544155, stopped daemon 1896871024)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-562750, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-562750, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-732556, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-732556, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-1154772, stopped daemon 1926231152)>>
del _limbo[self]
KeyError: <_Timer(Thread-1154772, stopped daemon 1926231152)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-1187051, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-1187051, stopped daemon 1866462320)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-2506571, stopped daemon 1849685104)>>
del _limbo[self]
KeyError: <_Timer(Thread-2506571, stopped daemon 1849685104)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-2749210, stopped daemon 1849685104)>>
del _limbo[self]
KeyError: <_Timer(Thread-2749210, stopped daemon 1849685104)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-3440470, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-3440470, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-3527295, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-3527295, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-4627908, stopped daemon 1876948080)>>
del _limbo[self]
KeyError: <_Timer(Thread-4627908, stopped daemon 1876948080)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-5130643, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-5130643, stopped daemon 1866462320)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-5220994, stopped daemon 1876948080)>>
del _limbo[self]
KeyError: <_Timer(Thread-5220994, stopped daemon 1876948080)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-6000725, stopped daemon 1849685104)>>
del _limbo[self]
KeyError: <_Timer(Thread-6000725, stopped daemon 1849685104)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-6429161, stopped daemon 1858073712)>>
del _limbo[self]
KeyError: <_Timer(Thread-6429161, stopped daemon 1858073712)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-6556730, stopped daemon 1858073712)>>
del _limbo[self]
KeyError: <_Timer(Thread-6556730, stopped daemon 1858073712)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-6686013, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-6686013, stopped daemon 1866462320)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-8074802, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-8074802, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-8322530, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-8322530, stopped daemon 1866462320)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-8763118, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-8763118, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-9055668, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-9055668, stopped daemon 1866462320)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-9670869, stopped daemon 1849685104)>>
del _limbo[self]
KeyError: <_Timer(Thread-9670869, stopped daemon 1849685104)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-10069133, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-10069133, stopped daemon 1866462320)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-11586495, stopped daemon 1896871024)>>
del _limbo[self]
KeyError: <_Timer(Thread-11586495, stopped daemon 1896871024)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-11604895, stopped daemon 1849685104)>>
del _limbo[self]
KeyError: <_Timer(Thread-11604895, stopped daemon 1849685104)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-11996948, stopped daemon 1841296496)>>
del _limbo[self]
KeyError: <_Timer(Thread-11996948, stopped daemon 1841296496)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-12144468, stopped daemon 1858073712)>>
del _limbo[self]
KeyError: <_Timer(Thread-12144468, stopped daemon 1858073712)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-12190768, stopped daemon 1876948080)>>
del _limbo[self]
KeyError: <_Timer(Thread-12190768, stopped daemon 1876948080)>
[2020-09-18 07:50:25][ERROR] : Critical error on send_changes_async threads can only be started once
[2020-09-18 19:58:34][ERROR] : Critical error on send_changes_async threads can only be started once
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-13061841, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-13061841, stopped daemon 1886385264)>
[2020-09-18 21:08:13][ERROR] : Critical error on send_changes_async threads can only be started once
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-13146648, stopped daemon 1841296496)>>
del _limbo[self]
KeyError: <_Timer(Thread-13146648, stopped daemon 1841296496)>
[2020-09-19 05:13:02][ERROR] : Critical error on send_changes_async threads can only be started once
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-14242793, stopped daemon 1841296496)>>
del _limbo[self]
KeyError: <_Timer(Thread-14242793, stopped daemon 1841296496)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-14635815, stopped daemon 1876948080)>>
del _limbo[self]
KeyError: <_Timer(Thread-14635815, stopped daemon 1876948080)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-14751639, stopped daemon 1824519280)>>
del _limbo[self]
KeyError: <_Timer(Thread-14751639, stopped daemon 1824519280)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-15036528, stopped daemon 1824519280)>>
del _limbo[self]
KeyError: <_Timer(Thread-15036528, stopped daemon 1824519280)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-15201070, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-15201070, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-15839826, stopped daemon 1886385264)>>
del _limbo[self]
KeyError: <_Timer(Thread-15839826, stopped daemon 1886385264)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-16695462, stopped daemon 1896871024)>>
del _limbo[self]
KeyError: <_Timer(Thread-16695462, stopped daemon 1896871024)>
Unhandled exception in thread started by <bound method _Timer.__bootstrap of <_Timer(Thread-16701953, stopped daemon 1866462320)>>
del _limbo[self]
KeyError: <_Timer(Thread-16701953, stopped daemon 1866462320)>
