J’ai 3 modules Zwave POPE701202 Popp Mold Detector qui fonctionnaient parfaitement avec openzwave.
En installant une autre jeedom, et remplaçant openzwave par ZwaveJS, les modules POPE ne sont pas intégrés correctement.
J’ai tenté l’inclusion/exclusion/re-inclusion mais sans succès, les 3 modules n’ont aucune commande qui apparait (hormis les 4 par défaut : pinger, soigner, status et tester).
Pourtant, dans le log de debug zwavejs :
[2025-10-27 20:33:50][DEBUG] : [createEqLogic] Création d\'un équipement
"id": 41,
"name": "",
"loc": "",
"values": {
"48-0-General Purpose": {
"id": "41-48-0-General Purpose",
"nodeId": 41,
"toUpdate": false,
"commandClass": 48,
"commandClassName": "Binary Sensor",
"endpoint": 0,
"property": "General Purpose",
"propertyName": "General Purpose",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Sensor state (General Purpose)",
"ccSpecific": { "sensorType": 1 },
"stateless": false,
"commandClassVersion": 2,
"list": false,
"value": false,
"lastUpdate": 1761593589017
"49-0-Air temperature": {
"id": "41-49-0-Air temperature",
"nodeId": 41,
"toUpdate": false,
"commandClass": 49,
"commandClassName": "Multilevel Sensor",
"endpoint": 0,
"property": "Air temperature",
"propertyName": "Air temperature",
"type": "number",
"readable": true,
"writeable": false,
"label": "Air temperature",
"ccSpecific": { "sensorType": 1, "scale": 0 },
"stateless": false,
"commandClassVersion": 8,
"unit": "\u00b0C",
"list": false,
"value": 30.2,
"lastUpdate": 1761593590707
"49-0-Humidity": {
"id": "41-49-0-Humidity",
"nodeId": 41,
"toUpdate": false,
"commandClass": 49,
"endpoint": 0,
"property": "Humidity",
"propertyName": "Humidity",
"type": "number",
"readable": true,
"writeable": false,
"label": "Humidity",
"ccSpecific": { "sensorType": 5, "scale": 0 },
"stateless": false,
"unit": "%",
"list": false,
"value": 40,
"lastUpdate": 1761593590976
"49-0-Dew point": {
"id": "41-49-0-Dew point",
"nodeId": 41,
"toUpdate": false,
"commandClass": 49,
"endpoint": 0,
"property": "Dew point",
"propertyName": "Dew point",
"type": "number",
"readable": true,
"writeable": false,
"label": "Dew point",
"ccSpecific": { "sensorType": 11, "scale": 0 },
"stateless": false,
"unit": "\u00b0C",
"list": false,
"value": 18.2,
"lastUpdate": 1761593591186
"112-0-1": {
"id": "41-112-0-1",
"nodeId": 41,
"toUpdate": false,
"commandClass": 112,
"commandClassName": "Configuration",
"endpoint": 0,
"property": 1,
"propertyName": "Min. Temp. Change",
"type": "number",
"readable": true,
"writeable": true,
"description": "Minimum Temperature change to report",
"label": "Min. Temp. Change",
"default": 20,
"stateless": false,
"commandClassVersion": 1,
"min": 0,
"max": 100,
"list": true,
"allowManualEntry": true,
"states": [{ "text": "Disabled", "value": 0 }],
"value": 20,
"lastUpdate": 1761593586526
"112-0-2": {
"id": "41-112-0-2",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 2,
"propertyName": "Min Humidity Change",
"type": "number",
"readable": true,
"writeable": true,
"label": "Min Humidity Change",
"default": 7,
"stateless": false,
"min": 0,
"max": 20,
"list": true,
"value": 7,
"lastUpdate": 1761593586735
"112-0-4": {
"id": "41-112-0-4",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 4,
"propertyName": "Periodic Reports",
"type": "number",
"readable": true,
"writeable": true,
"label": "Periodic Reports",
"default": 43200,
"stateless": false,
"min": 0,
"max": 65535,
"list": true,
"value": 43200,
"lastUpdate": 1761593586936
"112-0-5": {
"id": "41-112-0-5",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 5,
"propertyName": "Temperature Upper Watermark",
"type": "number",
"readable": true,
"writeable": true,
"label": "Temperature Upper Watermark",
"default": 0,
"stateless": false,
"min": 0,
"max": 1000,
"list": true,
"value": 0,
"lastUpdate": 1761593587156
"112-0-6": {
"id": "41-112-0-6",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 6,
"propertyName": "Temperature Lower Watermark",
"type": "number",
"readable": true,
"writeable": true,
"label": "Temperature Lower Watermark",
"default": 0,
"stateless": false,
"min": -200,
"max": 1000,
"list": false,
"value": 0,
"lastUpdate": 1761593587356
"112-0-7": {
"id": "41-112-0-7",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 7,
"propertyName": "Humidity Upper Watermark",
"type": "number",
"readable": true,
"writeable": true,
"label": "Humidity Upper Watermark",
"default": 0,
"stateless": false,
"min": 0,
"max": 100,
"list": true,
"value": 0,
"lastUpdate": 1761593587554
"112-0-8": {
"id": "41-112-0-8",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 8,
"propertyName": "Humidity Lower Watermark",
"type": "number",
"readable": true,
"writeable": true,
"label": "Humidity Lower Watermark",
"default": 0,
"stateless": false,
"min": 0,
"max": 90,
"list": true,
"value": 0,
"lastUpdate": 1761593587756
"112-0-9": {
"id": "41-112-0-9",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 9,
"propertyName": "Low Temperature Trigger",
"type": "number",
"readable": true,
"writeable": true,
"description": "Low Temperature Trigger BASIC Set Command Value",
"label": "Low Temperature Trigger",
"default": 255,
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 255,
"lastUpdate": 1761593587996
"112-0-10": {
"id": "41-112-0-10",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 10,
"propertyName": "High Temperature Trigger",
"type": "number",
"readable": true,
"writeable": true,
"description": "High Temperature Trigger BASIC Set Command Value",
"label": "High Temperature Trigger",
"default": 0,
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 0,
"lastUpdate": 1761593588196
"112-0-11": {
"id": "41-112-0-11",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 11,
"propertyName": "Low Humidity Trigger",
"type": "number",
"readable": true,
"writeable": true,
"description": "Low Humidity Trigger BASIC Set Command Value",
"label": "Low Humidity Trigger",
"default": 255,
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 255,
"lastUpdate": 1761593588395
"112-0-12": {
"id": "41-112-0-12",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": 12,
"propertyName": "High Humidity Trigger",
"type": "number",
"readable": true,
"writeable": true,
"description": "High Humidity Trigger BASIC Set Command Value",
"label": "High Humidity Trigger",
"default": 0,
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 0,
"lastUpdate": 1761593588595
"113-0-Weather Alarm-Moisture alarm status": {
"id": "41-113-0-Weather Alarm-Moisture alarm status",
"nodeId": 41,
"toUpdate": false,
"commandClass": 113,
"commandClassName": "Notification",
"endpoint": 0,
"property": "Weather Alarm",
"propertyName": "Weather Alarm",
"propertyKey": "Moisture alarm status",
"propertyKeyName": "Moisture alarm status",
"type": "number",
"readable": true,
"writeable": false,
"label": "Moisture alarm status",
"ccSpecific": { "notificationType": 16 },
"stateless": false,
"min": 0,
"max": 255,
"list": true,
"states": [
{ "text": "idle", "value": 0 },
{ "text": "Moisture alarm", "value": 2 }
"value": 0,
"lastUpdate": 1761593589706
"113-0-alarmType": {
"id": "41-113-0-alarmType",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "alarmType",
"propertyName": "alarmType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Alarm Type",
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"lastUpdate": 1761593591200
"113-0-alarmLevel": {
"id": "41-113-0-alarmLevel",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "alarmLevel",
"propertyName": "alarmLevel",
"type": "number",
"readable": true,
"writeable": false,
"label": "Alarm Level",
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"114-0-productId": {
"id": "41-114-0-productId",
"nodeId": 41,
"toUpdate": false,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 20,
"lastUpdate": 1761593573988
"114-0-productType": {
"id": "41-114-0-productType",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 4,
"lastUpdate": 1761593573989
"114-0-manufacturerId": {
"id": "41-114-0-manufacturerId",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "manufacturerId",
"propertyName": "manufacturerId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 340,
"lastUpdate": 1761593573990
"128-0-isLow": {
"id": "41-128-0-isLow",
"nodeId": 41,
"toUpdate": false,
"commandClass": 128,
"commandClassName": "Battery",
"endpoint": 0,
"property": "isLow",
"propertyName": "isLow",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Low battery level",
"stateless": false,
"list": false,
"value": false,
"lastUpdate": 1761593579736
"128-0-level": {
"id": "41-128-0-level",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "level",
"propertyName": "level",
"type": "number",
"readable": true,
"writeable": false,
"label": "Battery level",
"stateless": false,
"min": 0,
"max": 100,
"unit": "%",
"list": false,
"value": 100,
"lastUpdate": 1761593579737
"132-0-wakeUpInterval": {
"id": "41-132-0-wakeUpInterval",
"nodeId": 41,
"toUpdate": false,
"commandClass": 132,
"commandClassName": "Wake Up",
"endpoint": 0,
"property": "wakeUpInterval",
"propertyName": "wakeUpInterval",
"type": "number",
"readable": false,
"writeable": true,
"label": "wakeUpInterval (property)",
"default": 604800,
"stateless": false,
"min": 3600,
"max": 15728400,
"step": 900,
"list": false,
"value": 604800,
"lastUpdate": 1761593578987
"132-0-controllerNodeId": {
"id": "41-132-0-controllerNodeId",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "controllerNodeId",
"propertyName": "controllerNodeId",
"type": "any",
"readable": true,
"writeable": false,
"label": "Node ID of the controller",
"stateless": false,
"list": false,
"value": 1
"134-0-hardwareVersion": {
"id": "41-134-0-hardwareVersion",
"nodeId": 41,
"toUpdate": false,
"commandClass": 134,
"commandClassName": "Version",
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version",
"stateless": false,
"commandClassVersion": 3,
"list": false,
"value": 1,
"lastUpdate": 1761593574398
"134-0-firmwareVersions": {
"id": "41-134-0-firmwareVersions",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateless": false,
"list": false,
"value": ["1.2"],
"lastUpdate": 1761593574399
"134-0-protocolVersion": {
"id": "41-134-0-protocolVersion",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateless": false,
"list": false,
"value": "6.2",
"lastUpdate": 1761593574400
"134-0-libraryType": {
"id": "41-134-0-libraryType",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "libraryType",
"propertyName": "libraryType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"stateless": false,
"list": true,
"states": [
{ "text": "Unknown", "value": 0 },
{ "text": "Static Controller", "value": 1 },
{ "text": "Controller", "value": 2 },
{ "text": "Enhanced Slave", "value": 3 },
{ "text": "Slave", "value": 4 },
{ "text": "Installer", "value": 5 },
{ "text": "Routing Slave", "value": 6 },
{ "text": "Bridge Controller", "value": 7 },
{ "text": "Device under Test", "value": 8 },
{ "text": "N/A", "value": 9 },
{ "text": "AV Remote", "value": 10 },
{ "text": "AV Device", "value": 11 }
"value": 3,
"lastUpdate": 1761593574403
"134-0-applicationBuildNumber": {
"id": "41-134-0-applicationBuildNumber",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "applicationBuildNumber",
"propertyName": "applicationBuildNumber",
"type": "string",
"readable": true,
"writeable": false,
"label": "Application build number",
"stateless": false,
"list": false,
"value": 0,
"lastUpdate": 1761593578581
"134-0-applicationVersion": {
"id": "41-134-0-applicationVersion",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "applicationVersion",
"propertyName": "applicationVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Application version",
"stateless": false,
"list": false,
"value": "1.2.0",
"lastUpdate": 1761593578582
"134-0-zWaveProtocolBuildNumber": {
"id": "41-134-0-zWaveProtocolBuildNumber",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "zWaveProtocolBuildNumber",
"propertyName": "zWaveProtocolBuildNumber",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol build number",
"stateless": false,
"list": false,
"value": 86,
"lastUpdate": 1761593578583
"134-0-zWaveProtocolVersion": {
"id": "41-134-0-zWaveProtocolVersion",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "zWaveProtocolVersion",
"propertyName": "zWaveProtocolVersion",
"type": "string",
"readable": true,
"writeable": false,
"stateless": false,
"list": false,
"value": "6.2.0",
"lastUpdate": 1761593578584
"134-0-hostInterfaceBuildNumber": {
"id": "41-134-0-hostInterfaceBuildNumber",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "hostInterfaceBuildNumber",
"propertyName": "hostInterfaceBuildNumber",
"type": "string",
"readable": true,
"writeable": false,
"label": "Serial API build number",
"stateless": false,
"list": false,
"value": 0,
"lastUpdate": 1761593578585
"134-0-hostInterfaceVersion": {
"id": "41-134-0-hostInterfaceVersion",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "hostInterfaceVersion",
"propertyName": "hostInterfaceVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Serial API version",
"stateless": false,
"list": false,
"value": "unused",
"134-0-applicationFrameworkBuildNumber": {
"id": "41-134-0-applicationFrameworkBuildNumber",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "applicationFrameworkBuildNumber",
"propertyName": "applicationFrameworkBuildNumber",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave application framework API build number",
"stateless": false,
"list": false,
"value": 52445,
"lastUpdate": 1761593578586
"134-0-applicationFrameworkAPIVersion": {
"id": "41-134-0-applicationFrameworkAPIVersion",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "applicationFrameworkAPIVersion",
"propertyName": "applicationFrameworkAPIVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave application framework API version",
"stateless": false,
"list": false,
"value": "4.1.1",
"lastUpdate": 1761593578588
"134-0-sdkVersion": {
"id": "41-134-0-sdkVersion",
"nodeId": 41,
"toUpdate": false,
"endpoint": 0,
"property": "sdkVersion",
"propertyName": "sdkVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "SDK version",
"stateless": false,
"list": false,
"value": "6.81.1",
"lastUpdate": 1761593578589
"groups": [
{ "text": "Lifeline", "endpoint": 0, "value": 1, "maxNodes": 5, "isLifeline": true, "multiChannel": true },
"text": "Temperature High Trigger",
"endpoint": 0,
"value": 2,
"maxNodes": 5,
"isLifeline": false,
"text": "Temperature Low Trigger",
"endpoint": 0,
"value": 3,
"maxNodes": 5,
"text": "Humidity High Trigger",
"endpoint": 0,
"value": 4,
"maxNodes": 5,
"text": "Humidity Low Trigger",
"endpoint": 0,
"value": 5,
"maxNodes": 5,
"neighbors": [],
"ready": true,
"available": true,
"hassDevices": [],
"failed": false,
"inited": true,
"eventsQueue": [
{ "time": "2025-10-27T19:32:53.189Z", "event": "interview started", "args": [] },
{ "time": "2025-10-27T19:32:53.196Z", "event": "wake up", "args": [4] },
{ "time": "2025-10-27T19:32:53.196Z", "event": "interview stage completed", "args": ["ProtocolInfo"] },
{ "time": "2025-10-27T19:32:53.376Z", "event": "interview stage completed", "args": ["NodeInfo"] },
"time": "2025-10-27T19:32:53.989Z",
"event": "value added",
"args": [
"endpoint": 0,
"newValue": 20,
"args": [
"endpoint": 0,
"newValue": 4,
