Depuis quelques jours, j’ai des soucis avec mes capteurs d’ouverture et mon clavier qui ne remontent plus les infos correctement
Pour les capteurs de portes quel que soit l’état c’est « false »
Je ne pourrais pas dire si c’est lié a la maj
L’exemple suivant est ouverture fermeture d’une porte sous tuya
log depuis l’interface z2m
Info 2023-09-27 17:48:07MQTT publish: topic 'zigbee2mqtt/DT ENTREE', payload '{"battery":100,"battery_low":false,"contact":false,"device":{"applicationVersion":70,"dateCode":"","friendlyName":"DT ENTREE","hardwareVersion":1,"ieeeAddr":"0xa4c138101c391e3d","manufacturerID":4417,"manufacturerName":"_TZ3000_oxslv1c9","model":"TS0203","networkAddress":35282,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-09-27T15:48:08.797Z","linkquality":160,"tamper":false,"voltage":2800}'
Info 2023-09-27 17:49:24MQTT publish: topic 'zigbee2mqtt/DT ENTREE', payload '{"battery":100,"battery_low":false,"contact":false,"device":{"applicationVersion":70,"dateCode":"","friendlyName":"DT ENTREE","hardwareVersion":1,"ieeeAddr":"0xa4c138101c391e3d","manufacturerID":4417,"manufacturerName":"_TZ3000_oxslv1c9","model":"TS0203","networkAddress":35282,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-09-27T15:49:25.810Z","linkquality":160,"tamper":false,"voltage":2800}'
Info 2023-09-27 17:49:25MQTT publish: topic 'zigbee2mqtt/DT ENTREE', payload '{"battery":100,"battery_low":false,"contact":false,"device":{"applicationVersion":70,"dateCode":"","friendlyName":"DT ENTREE","hardwareVersion":1,"ieeeAddr":"0xa4c138101c391e3d","manufacturerID":4417,"manufacturerName":"_TZ3000_oxslv1c9","model":"TS0203","networkAddress":35282,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-09-27T15:49:26.011Z","linkquality":160,"tamper":false,"voltage":2800}'
Info 2023-09-27 17:49:29MQTT publish: topic 'zigbee2mqtt/DT ENTREE', payload '{"battery":100,"battery_low":false,"contact":false,"device":{"applicationVersion":70,"dateCode":"","friendlyName":"DT ENTREE","hardwareVersion":1,"ieeeAddr":"0xa4c138101c391e3d","manufacturerID":4417,"manufacturerName":"_TZ3000_oxslv1c9","model":"TS0203","networkAddress":35282,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-09-27T15:49:30.303Z","linkquality":160,"tamper":false,"voltage":2800}'
