Module inopérant après un certain temps
Après avoir changé ma clef Zigbee par une clef sonoof ember-e
refait toutes les inclusions sur le plugin Z2M qui fonctionne de manière remarquable
j’ai un problème sur un seul module qui semble perdre la connexion au bout de 2 à 3 heures, mais qui est toujours inscrit sur Z2M
tout a l’air correct au niveau jeedom
module en question loratap tuya Zigbee 6 gangs remote
    "date_code": "",
    "definition": {
        "description": "Wireless switch with 6 buttons",
        "exposes": [
                "access": 1,
                "category": "diagnostic",
                "description": "Remaining battery in %, can take up to 24 hours before reported",
                "label": "Battery",
                "name": "battery",
                "property": "battery",
                "type": "numeric",
                "unit": "%",
                "value_max": 100,
                "value_min": 0
                "access": 1,
                "description": "Triggered action (e.g. a button click)",
                "label": "Action",
                "name": "action",
                "property": "action",
                "type": "enum",
                "values": [
                    "1_single",
                    "1_double",
                    "1_hold",
                    "2_single",
                    "2_double",
                    "2_hold",
                    "3_single",
                    "3_double",
                    "3_hold",
                    "4_single",
                    "4_double",
                    "4_hold",
                    "5_single",
                    "5_double",
                    "5_hold",
                    "6_single",
                    "6_double",
                    "6_hold"
                "access": 1,
                "description": "Link quality (signal strength)",
                "label": "Linkquality",
                "name": "linkquality",
                "property": "linkquality",
                "type": "numeric",
                "unit": "lqi",
                "value_max": 255,
                "value_min": 0
        "model": "TS0046",
        "options": [],
        "supports_ota": false,
        "vendor": "Tuya"
    "disabled": false,
    "endpoints": {
        "1": {
            "bindings": [],
            "clusters": {
                "input": [
                    "genPowerCfg",
                    "genOnOff",
                    "57344",
                    "genBasic"
                "output": [
                    "genOta",
                    "genTime"
            "configured_reportings": [],
            "scenes": []
        "2": {
            "bindings": [],
            "clusters": {
                "input": [
                    "genOnOff",
                    "genPowerCfg",
                    "genOnOff"
                "output": []
            "scenes": []
        "3": {
            "bindings": [],
            "clusters": {
                "input": [
                    "genOnOff",
                    "genPowerCfg",
                    "genOnOff"
                "output": []
            "scenes": []
        "4": {
            "bindings": [],
            "clusters": {
                "input": [
                    "genOnOff",
                    "genPowerCfg",
                    "genOnOff"
                "output": []
            "scenes": []
    "friendly_name": "switch music",
    "ieee_address": "0xa4c138f00a0c411a",
    "interview_completed": true,
    "interviewing": false,
    "manufacturer": "_TZ3000_iszegwpd",
    "model_id": "TS0046",
    "network_address": 31389,
    "power_source": "Battery",
    "supported": true,
    "type": "EndDevice"
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : oui
Plugin : JeeZigbee
Version : 2024-12-17 01:01:46 (stable)
Statut Démon : Stoppé - (2025-01-22 10:32:54)
ma question et la suivante, avez-vous eu ce problème
merci pour votre aide
Le daemon de Jeezigbee est stoppé depuis le 22 janvier ??
Non, je viens juste de refaire une inclusion ce matin
ça ne répond pas à la question :
Pourquoi le statut du daemon de Jeezigbee est indiqué comme stoppé dans votre premier message ?
Pouvez-vous montrer la page de configuration de Jeezigbee ?
Pourquoi avez vous mis 3 minutes dans « Heartbeat » et coché la case « Redémarrer démon » ?
Peut-être pour que le démon essaye de redémarrer trois fois en qu’à d’erreur à moins que je n’aie pas compris la signification de la fonction.
L’espace utilisé par le plugin me semble énorme !
Sur 3 box installées je n’ai jamais plus de 250 MB
45 modules sur le plugin :grin:
pour l’instant le Switch tient la connexion depuis ce matin :upside_down_face:
Voilà le module m’a quitté. :joy:
le seul qui me pose un problème
Si tu n’as pas eu de changement d’environnement pour les ondes ou ta box, tu peux tester:
  • un routeur plus proche
  • changer de pile
  • le remplacer
merci pour ton message
non pas changement
un routeur plus proche non le premier routeur est à 3 mètre
la pile de mémoire est à 86 %
il me reste plus qu’à essayer de le changer acheté sur AliExpress ça va être compliqué :joy:
je m’en sers pour la musique avec des liens HTTP direct sur jeedom
je pense avoir un bon réseau
je vais quand même déplacer le Switch a 1 m de la clef sonoff
Même si je pense que cela aura aucun effet :blush:
Teste avec une pile neuve. La valeur affichée est souvent peu réaliste.
Ok, je vais faire ça aussi après avoir testé la pile au multimètre
Voilà pile changée qui était à 2,97 V pour une valeur de 3 V
remplacé par une pile de 3V mesurer à 3,27 V
j’espère que tu as raison :grin:
Bon apparemment le changement de pile ne donne pas le résultat espéré
j’ai repris mon Switch tuya 4 fonctions qui fonctionnent très bien avec le plugin
je n’ai pas trouvé d’autre module avec 6 Switch intégré
je vais patienter en espérant une mise à jour du module
bonjour
je suis incapable de vous dire pourquoi cela fonctionne j’ai simplement transférer la gestion de zigbee2mqtt dans JMQTT
depuis 24 heure plus de problème avec le switch
