Je rencontre un souci avec la dernière mise à jour du plug in Arlo de ces derniers jours. L’installation ne se fait pas comme si il ne trouvait pas le paquet à installer.
Pourtant la connexion au market se fait correctement, je peux rechercher ou installer d’autres plug-in.
ci dessous la log :
[START UPDATE] ****Update from 4.4.17 (2024-09-19 17:49:39)**** Parameters : {"preUpdate":"0","backup::before":"1","core":"1","force":"0","plugins":"1","update::reapply":""} Send begin of update event | OK Check update | OK Check rights | OK [START BACKUP] ***************Start of Jeedom backup at 2024-09-19 17:49:47*************** Send begin backup event | OK Checking files rights | OK Checking database jeedom.event note : The storage engine for the table doesn't support check | OK Backing up database | OK Cache persistence: | OK Creating archive | OK Cleaning old backup | OK Limiting backup size to 500 Mb Delete: /var/www/html/core/php///backup/backup-Jeedom-4.4.17-2024-09-17-11h27.tar.gz | OK Backup name: /var/www/html/core/php///backup/backup-Jeedom-4.4.17-2024-09-19-17h49.tar.gz Checking files rights | OK Send end backup event | OK Backup operation duration: 73s ***************Jeedom backup end*************** [END BACKUP SUCCESS] Download url : https://github.com/jeedom/core/archive/master.zip Download in progress--2024-09-19 15:51:00-- https://github.com/jeedom/core/archive/master.zip Resolving github.com (github.com) 140.82.121.4 Connecting to github.com (github.com)|140.82.121.4|:443 connected. HTTP request sent, awaiting response 302 Found Location: https://codeload.github.com/jeedom/core/zip/refs/heads/master [following] --2024-09-19 15:51:00-- https://codeload.github.com/jeedom/core/zip/refs/heads/master Resolving codeload.github.com (codeload.github.com) 140.82.121.9 Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443 connected. HTTP request sent, awaiting response 200 | OK Length: 88166013 (84M) [application/zip] Saving to: '/tmp/jeedom/install/jeedom_update.zip' 0K 3% 11.5M 7s 3072K 7% 15.6M 6s 6144K 10% 16.7M 5s 9216K 14% 8.19M 6s 12288K 17% 5.46M 7s 15360K 21% 4.20M 8s 18432K 24% 14.1M 7s 21504K 28% 15.1M 7s 24576K 32% 16.8M 6s 27648K 35% 17.4M 5s 30720K 39% 17.5M 5s 33792K 42% 17.6M 4s 36864K 46% 16.6M 4s 39936K . 49% 16.7M 4s 43008K 53% 17.7M 3s 46080K 57% 17.7M 3s 49152K 60% 17.7M 3s 52224K 64% 17.6M 2s 55296K 67% 17.6M 2s 58368K 71% 17.7M 2s 61440K 74% 17.7M 2s 64512K 78% 17.7M 1s 67584K 82% 17.5M 1s 70656K 85% 17.7M 1s 73728K 89% 16.8M 1s 76800K 92% 16.4M 0s 79872K 96% 16.9M 0s 82944K 99% 14.1M 0s 86016K . 100% 17.7M=6.2s 2024-09-19 15:51:07 (13.6 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [88166013/88166013] | OK Cleaning folders | OK Create temporary folder | OK Unzip in progress | OK Clean temporary files (tmp) | OK Disable all task | OK Disable all scenario | OK Update modification date of unzip file | OK Moving files Ignore file /tmp/jeedom_unzip/core-master///docs/de_DE/noteVersion.md because size is 0 Ignore file /tmp/jeedom_unzip/core-master///docs/en_US/noteVersion.md because size is 0 Ignore file /tmp/jeedom_unzip/core-master///docs/es_ES/noteVersion.md because size is 0 Ignore file /tmp/jeedom_unzip/core-master///docs/fr_FR/noteVersion.md because size is 0 Ignore file /tmp/jeedom_unzip/core-master///docs/pt_PT/noteVersion.md because size is 0 | OK Remove temporary files | OK Remove useless files Cleaning 3rdparty Cleaning desktop Cleaning mobile Cleaning core Cleaning docs Cleaning install Cleaning script find: '/var/www/html/install//script/*': No such file or directory | OK Update jeedom information date | OK Check jeedom consistency [START CONSISTENCY] [START CHECK AND FIX DB] [END CHECK AND FIX DB] Check jeedom package | OK Check jeedom database | OK Check crons Check filesystem right | OK Check jeedom object | OK Check jeedom cmd | OK Set cache hour | OK Check composer | OK Check nodejs E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable' E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable' E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates' Vérification si la source deb-multimedia existe (bug lors du apt-get update si c'est le cas) deb-multimedia existe ! mais on l'a déjà désactivé Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB] Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB] Get:3 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB] Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:5 https://oph.mdrjr.net/meveric all InRelease Hit:6 https://oph.mdrjr.net/meveric buster InRelease Reading package lists Reading package lists Building dependency tree Reading state information apt-utils is already the newest version (1.8.2.3). build-essential is already the newest version (12.6). lsb-release is already the newest version (10.2019051400). git is already the newest version (1:2.20.1-2+deb10u8). 0 upgraded, 0 newly installed, 0 to remove and 238 not upgraded. Codename: buster == ATTENTION Debian 10 Buster n'est officiellement plus supportée depuis le 30 juin 2024, merci de mettre à jour votre distribution !!! | OK [END CONSISTENCY] | OK Check update | OK ***************Jeedom is up to date in 4.4.17*************** ***************Update plugins*************** [2024-09-19 17:52:39][ALERT] : Début de la mise à jour de : arlo [2024-09-19 17:52:39][ALERT] : Téléchargement du plugin (source : market) [2024-09-19 17:52:40][ALERT] : Téléchargement de arlo [2024-09-19 17:52:40][ALERT] : URL https://market.jeedom.com/core/php/downloadFile.php?id=3708&version=stable&jeedomversion=4.4.17&osversion=10.4&hwkey=4f0501d48acf47ea60e943fe342d9b4471048567f6ae63f4c05a5c4277b383c&username=pascalbout&password=b7aa5fc2e379375f0362b382a5647b85b9b287d1&password_type=sha1 --2024-09-19 15:52:40-- https://market.jeedom.com/core/php/downloadFile.php?id=3708&version=stable&jeedomversion=4.4.17&osversion=10.4&hwkey=4f0501d48acf47ea60e943fe342d9b4471048567f6ae63f4c05a5c4277b383c&username=pascalbout&password=b7aa5fc2e379375f0362b382a5647b85b9b287d1&password_type=sha1 Resolving market.jeedom.com (market.jeedom.com) 51.91.143.68 Connecting to market.jeedom.com (market.jeedom.com)|51.91.143.68|:443 connected. HTTP request sent, awaiting response 200 | OK Length: 84 [text/html] Saving to: '/tmp/jeedom/market/arlo.zip' 0K 100% 1.48M=0s 2024-09-19 15:52:40 (1.48 MB/s) - '/tmp/jeedom/market/arlo.zip' saved [84/84] [2024-09-19 17:52:40][ALERT] : | OK [2024-09-19 17:52:40][ALERT] : Echec lors du téléchargement du plugin (taille inférieure à 100 octets), veuillez réessayer plus tard. Cela peut être dû à une absence de connexion au market (effectuez un test de connexion depuis la configuration générale), lié à un manque d'espace disque, une version minimale requise ou un souci sur le plugin ou son achat, etc ***************Update plugin successfully*************** Check update | OK Enable scenario : | OK Enable task : | OK Check Network Conf : | OK Launch cron dependancy plugins | OK Send end of update event | OK Update duration : 181s [END UPDATE SUCCESS]
Cela ne parait être un manque d’espace disque :
Merci pour votre aide.
