J ai migre a Atlas en provenance de la Smart.
Impossible de faire les dependances sur GoogleCast
J ai un message d erreur error: invalid command ‹ bdist_wheel ›
merci pour votre aide
Voici le log
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 10 (buster)
-- Updating repo...
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
Hit:6 http://mirrors.xtom.de/armbian buster InRelease
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 103 not upgraded.
-- Installed version of Python :
Python 3.7.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python-requests is already the newest version (2.21.0-1).
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-1).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-9).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.1.9-0+deb10u1).
-- Upgrade setuptools with command pip3 if not up to date
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.7/dist-packages (65.3.0)
-- Installed version of pip :
pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
-- Installation of python library 'requests' with command pip3
Requirement already satisfied: requests>=2.21.0 in /usr/lib/python3/dist-packages (2.21.0)
-- Installation of python library 'protobuf' with command pip3
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/dist-packages (4.21.5)
-- Installation of python library 'zeroconf' with command pip3
Requirement already satisfied: zeroconf>=0.25.1 in /usr/local/lib/python3.7/dist-packages (0.39.0)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.7/dist-packages (from zeroconf>=0.25.1) (0.2.0)
Requirement already satisfied: async-timeout>=4.0.1 in /usr/local/lib/python3.7/dist-packages (from zeroconf>=0.25.1) (4.0.2)
Requirement already satisfied: typing-extensions>=3.6.5; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from async-timeout>=4.0.1->zeroconf>=0.25.1) (4.3.0)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3
Failed building wheel for bs4
Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (8.1.3)
Collecting bs4
Using cached https://files.pythonhosted.org/packages/10/ed/7e8b97591f6f456174139ec089c769f89a94a1a4025fe967691de971f314/bs4-0.0.1.tar.gz
Requirement already satisfied: six in /usr/lib/python3/dist-packages (1.12.0)
Requirement already satisfied: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from click) (4.12.0)
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.7/dist-packages (from bs4) (4.11.1)
Requirement already satisfied: typing-extensions>=3.6.4; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click) (4.3.0)
Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click) (3.8.1)
Requirement already satisfied: soupsieve>1.2 in /usr/local/lib/python3.7/dist-packages (from beautifulsoup4->bs4) (2.3.2.post1)
Building wheels for collected packages: bs4
Running setup.py bdist_wheel for bs4: started
Running setup.py bdist_wheel for bs4: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-0pkg7c3d/bs4/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-iv5_00b7 --python-tag cp37:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Running setup.py clean for bs4
Failed to build bs4
Installing collected packages: bs4
Running setup.py install for bs4: started
Running setup.py install for bs4: finished with status 'done'
Successfully installed bs4
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3
Requirement already satisfied: tqdm in /usr/local/lib/python3.7/dist-packages (4.64.0)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/dist-packages (1.4.0)
Requirement already satisfied: casttube in /usr/local/lib/python3.7/dist-packages (0.2.1)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from casttube) (2.21.0)
-- Installation of dependencies is done !
