Bonsoir
J’ai ces messages d’erreur suite une MAJ de Core en V4 Stable :
LOG de la MAJ :
[START UPDATE]
****Update from 4.0.42 (2020-03-03 18:03:22)****
Parameters : {"preUpdate":"0","backup::before":"0","plugins":"1","core":"1","force":"0","update::reapply":""}
Send begin of update event | OK
Check update | OK
Check rights | OK
Download url : https://github.com/jeedom/core/archive/V4-stable.zip
Download in progress--2020-03-03 18:03:32-- https://github.com/jeedom/core/archive/V4-stable.zip
Resolving github.com (github.com)
140.82.118.4
Connecting to github.com (github.com)|140.82.118.4|:443 connected.
HTTP request sent, awaiting response 302 Found
Location: https://codeload.github.com/jeedom/core/zip/V4-stable [following]
--2020-03-03 18:03:32-- https://codeload.github.com/jeedom/core/zip/V4-stable
Resolving codeload.github.com (codeload.github.com) 140.82.114.9
Connecting to codeload.github.com (codeload.github.com)|140.82.114.9|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: unspecified [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K
258K
3072K
296K
6144K
. 306K
9216K
258K
12288K
302K
15360K
302K
18432K
258K
21504K
301K
24576K
301K
27648K
. 211K
30720K
291K
33792K
. 301K
36864K
281K
39936K
243K
43008K
300K=2m44s
2020-03-03 18:06:17 (277 KB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [46691284] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task
| OK
Disable all scenario
| OK
Moving files | OK
Remove temporary files | OK
Check jeedom consistency
[START CONSISTENCY]
PHP Notice: Undefined variable: ex in /var/www/html/install/database.php on line 33
PHP Fatal error: Uncaught Error: Call to a member function getMessage() on null in /var/www/html/install/database.php:33
Stack trace:
#0 {main}
thrown in /var/www/html/install/database.php on line 33
[START CHECK AND FIX DB]
Fix : CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC)
Fix : CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC)Check jeedom database
***ERREUR*** [MySQL] Error code : 23000 (1062). Duplicate entry '1189-Sonde entr?e air' for key 'unique' : CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC)
Check filesystem right | OK
[END CONSISTENCY] | OK
Check update | OK
***************Jeedom is up to date in 4.0.43***************
Message d’erreur n°1 :
Message d’erreur n°2 :
Et maintenant sur mon Dashboard j’ai comme message :
http://192.168.1.31/core/php/getResource.php?file=desktop/js/update.js&md5=e478feaeecf10a4294d1343fe9d90275&lang=fr_FR 422 TypeError: Argument 1 of MutationObserver.observe is not an object.
Quelqu’un peut me dire à quoi cela correspond et comment corriger ?
