Message erreur : Could not retrieve or read configuration
J’ai depuis hier des messages d’erreurs sur le plugin, cela vient d’un site de test ou autre ? Voici les logs :
- Could not retrieve or read configuration (ConfigurationError)","level":"error"}
0016|[2026-09-13 07:00:04] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 07:00:04.617] [error] Configuration - Cannot retrieve configuration document (503)
0017|[2026-09-13 07:00:04] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 07:00:04.621] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
0018|[2026-09-13 07:00:04] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 07:00:04.621] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
0019|[2026-09-13 07:00:04] ERROR  [Divers][RedFibre] : Error shell_exec() : {"type":"log","timestamp":"2026-09-13T05:00:04Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
0020|[2026-09-13 12:00:03] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 12:00:03.814] [error] Configuration - Cannot retrieve configuration document (503)
0021|[2026-09-13 12:00:03] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 12:00:03.818] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
0022|[2026-09-13 12:00:03] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 12:00:03.818] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
0023|[2026-09-13 12:00:03] ERROR  [Divers][RedFibre] : Error shell_exec() : {"type":"log","timestamp":"2026-09-13T10:00:03Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
0024|[2026-09-13 15:34:06] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 15:34:06.046] [error] Configuration - Cannot retrieve configuration document (503)
0025|[2026-09-13 15:34:06] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 15:34:06.050] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
0026|[2026-09-13 15:34:06] ERROR  [Divers][RedFibre] : Error shell_exec() : [2026-09-13 15:34:06.050] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
0027|[2026-09-13 15:34:06] ERROR  [Divers][RedFibre] : Error shell_exec() : {"type":"log","timestamp":"2026-09-13T13:34:06Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error
Informations Jeedom
Core : 4.6.1 (master)
DNS Jeedom : non
Plugin : Speedtest by Ookla
Version : 2024-12-07 18:11:49 (stable)
Santé
🟢 Matériel : diy
🟢 Système à jour : OK
🟢 Cron actif : OK
🟢 Scénario actif : OK
🟢 Démarré : OK 2026-09-12 10:59:03
🟢 Date système (dernière heure enregistrée) : OK 2026-09-13 15:36:14 (2026-09-13 15:14:02)
🟢 Droits sudo : OK
🟢 Version Jeedom : 4.6.1
🟢 Version OS : debian 12.15
🟢 Version PHP : 8.2.33
🟢 Nombre de processus Apache : 15
🟢 Version OS : Linux Debian12 6.1.0-53-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.187-1 (2026-09-07) x86_64 GNU/Linux  [12.15]
🟢 Version database : 10.11.18-MariaDB-0+deb12u1
🟢 Espace disque libre : 45 %
🟢 Connexion active/max/autorisée : 17/36/151
🟢 Taille base de données : 121.68 MB
🟢 Espace disque libre tmp : 89 %
🟢 Mémoire disponible : 69 % (Total 5925 Mo)
🟢 Mémoire suffisante : 0
🟢 Erreur I/O : 0
🟢 Swap disponible : 100 % (Total 975 Mo)
🟢 Swappiness : 10 %
🟢 Charge : 0.81 - 0.85 - 0.8
🟢 Node : v22.23.2
🟢 Python 3 : Python 3.11.2
🟢 Persistance du cache : OK
🟢 Apache private tmp : OK
J’ai également le même souci.
j’ai le même soucis… j’ai essayer les différents points sans succès.
Après un redémarrage, c’est revenu à la normale chez moi.
L’IA google m’indique que ça peut provenir de tables réseau qui ne se sont pas mises à jour.
Pour info, j’avais mis à jour les dépendances entre temps.
