Message dans http.error suite à la mise à jour du plugin RFXCom
Jeedom 3.3.53
Raspberry Pi OS Buster à jour de tout
Je viens de mettre à jour le plugin RFXCom.
à 11h45
J’ai été dans les sondes et prises (pour les vignettes, en selectionnant x11 pour avoir l’image des prises)
Au moment de quitter l’interface de Jeedom, je regarde dans les logs et je vois cela dans la log http.error :
job 9 at Sun Nov 29 11:46:00 2020
[Sun Nov 29 12:12:31.890717 2020] [autoindex:error] [pid 4608] [client 192.168.0.12:58056] AH01276: Cannot serve directory /var/www/html/plugins/rfxcom/core/config/devices/: No matching DirectoryIndex (index.php) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.0.50:8050/index.php?v=d&m=rfxcom&p=rfxcom&id=1155&saveSuccessFull=1
[Sun Nov 29 12:12:32.906722 2020] [autoindex:error] [pid 4608] [client 192.168.0.12:58056] AH01276: Cannot serve directory /var/www/html/plugins/rfxcom/core/config/devices/: No matching DirectoryIndex (index.php) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.0.50:8050/index.php?v=d&m=rfxcom&p=rfxcom&id=1155&saveSuccessFull=1
[Sun Nov 29 12:33:36.260398 2020] [autoindex:error] [pid 26025] [client 192.168.0.12:58268] AH01276: Cannot serve directory /var/www/html/plugins/rfxcom/core/config/devices/: No matching DirectoryIndex (index.php) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.0.50:8050/index.php?v=d&p=rfxcom&m=rfxcom&id=204&saveSuccessFull=1
[Sun Nov 29 12:33:39.066250 2020] [autoindex:error] [pid 26025] [client 192.168.0.12:58268] AH01276: Cannot serve directory /var/www/html/plugins/rfxcom/core/config/devices/: No matching DirectoryIndex (index.php) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.0.50:8050/index.php?v=d&p=rfxcom&m=rfxcom&id=204&saveSuccessFull=1
[Sun Nov 29 12:33:40.057720 2020] [autoindex:error] [pid 26025] [client 192.168.0.12:58268] AH01276: Cannot serve directory /var/www/html/plugins/rfxcom/core/config/devices/: No matching DirectoryIndex (index.php) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.0.50:8050/index.php?v=d&p=rfxcom&m=rfxcom&id=204&saveSuccessFull=1
Les ID présentes ici, sont soit des prises soit des sondes.
C’est normal ou pas d’avoir cela ?
