Logs Erreurs sur Kerui D026
J’ai des erreurs dans les logs qui semblent correspondre à des modules Kerui D026 (capteurs d’ouverture) entre autres.
[2020-01-24 19:29:53][ERROR] : Unknown house command received, '2F'
[2020-01-24 19:29:53][ERROR] : Unknown command received, 'DF' => 	v/???
[2020-01-24 19:49:02][ERROR] : Unknown command received, '54' => 	U_T?P
[2020-01-25 08:06:33][ERROR] : Unknown house command received, 'BF'
[2020-01-25 08:06:33][ERROR] : Unknown command received, 'F9' => 	}???lp
[2020-01-25 10:29:00][ERROR] : Unknown house command received, '2F'
[2020-01-25 10:29:00][ERROR] : Unknown command received, 'DF' => 	?/???
[2020-01-25 11:52:02][ERROR] : Unknown command received, '54' => 	0U_T?`
[2020-01-25 11:52:19][ERROR] : Unknown command received, '54' => 	3U_T?`
[2020-01-25 11:57:44][ERROR] : Unknown house command received, '2F'
[2020-01-25 11:57:44][ERROR] : Unknown command received, 'DF' => 	_/???
[2020-01-25 12:10:18][ERROR] : Unknown command received, '54' => 	?U_T?`
[2020-01-25 12:10:19][ERROR] : Unknown command received, '54' => 	?U_T?`
[2020-01-25 12:10:21][ERROR] : Unknown command received, '54' => 	?U_T?`
[2020-01-25 15:33:14][ERROR] : Unknown house command received, 'DC'
[2020-01-25 15:33:14][ERROR] : Unknown command received, '20' => 	?ܠ ?
[2020-01-25 17:57:41][ERROR] : Unknown house command received, 'FF'
[2020-01-25 17:57:41][ERROR] : Unknown command received, 'AC' => 	??]?`
[2020-01-25 20:32:55][ERROR] : Unknown house command received, '2F'
[2020-01-25 20:32:55][ERROR] : Unknown command received, 'DF' => 	e/???
[2020-01-26 06:13:38][ERROR] : Unknown house command received, '2F'
[2020-01-26 06:13:38][ERROR] : Unknown command received, 'DF' => 	?/???
[2020-01-26 07:45:59][ERROR] : Unknown house command received, '2F'
[2020-01-26 07:45:59][ERROR] : Unknown command received, 'DF' => 	p/???
J’ai échangé avec RFCOM qui me dit que c’est probablement un problème Jeedom car les modules sont bien pris en charge (avec le firmware RFXCOM PRO1 : firmware adapté à mon modèle : RFXtrx433E)
Quelqu’un d’autre est concerné ? j’ai pu identifier ces modules car ils sont utilisés pour ma boite aux lettres et en les actionnant, 2 à 4 erreurs de logs à chaque action.
Merci pour vos retours.
cela semble en lien avec ce sujet:
merci, j’ai posté sur l’autre sujet du coup.
