J’ai upgradé de V3 > V4 et depuis j’ai des erreurs dans la log cron_execution.
Pouvez-vous SVP m’orienter pour résoudre mon problème ? Merci
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 705, in <module>
run()
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 673, in run
get_volume(device_name=device_name)
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 550, in get_volume
print CCMediaController(device_name=device_name).get_volume()
File "/var/www/html/plugins/gcast/resources/caster/cc_media_controller.py", line 414, in get_volume
self.get_status()
File "/var/www/html/plugins/gcast/resources/caster/cc_media_controller.py", line 333, in get_status
self.connect("receiver-0")
File "/var/www/html/plugins/gcast/resources/caster/cc_media_controller.py", line 200, in connect
self.open_socket()
File "/var/www/html/plugins/gcast/resources/caster/cc_media_controller.py", line 82, in open_socket
self.sock.connect((self.host,8009))
File "/usr/lib/python2.7/ssl.py", line 876, in connect
self._real_connect(addr, False)
File "/usr/lib/python2.7/ssl.py", line 863, in _real_connect
socket.connect(self, addr)
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 111] Connection refused
run()
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 670, in run
is_idle(device_name=device_name)
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 554, in is_idle
print CCMediaController(device_name=device_name).is_idle()
File "/var/www/html/plugins/gcast/resources/caster/cc_media_controller.py", line 363, in is_idle
status = self.get_status()
self.open_socket()
run()
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 667, in run
get_status(device_name=device_name)
File "/var/www/html/plugins/gcast/core/class/../../resources/caster/stream2chromecast.py", line 546, in get_status
print CCMediaController(device_name=device_name).get_status()
self.open_socket()
run()
self.get_status()
self.open_socket()
run()
self.open_socket()
run()
self.open_socket()
