Quelques logs zigbee2mqtt :
error 2024-09-09 21:40:28z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:40:28z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
info 2024-09-09 21:40:48z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise chevet Ludo', payload '{"consumer_connected":true,"consumption":1.2416536808013916,"current":0,"device":{"applicationVersion":22,"dateCode":"09-10-2019","friendlyName":"Prise chevet Ludo","hardwareVersion":1,"ieeeAddr":"0x04cf8cdf3c79df2c","manufacturerID":4447,"manufacturerName":"LUMI","model":"SP-EUC01","networkAddress":4596,"powerSource":"Mains (single phase)","stackVersion":2,"type":"Router","zclVersion":3},"device_temperature":19,"energy":1.24,"linkquality":72,"power":0,"power_outage_count":48,"state":"OFF","voltage":230}'
error 2024-09-09 21:41:12z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:41:48z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Guirlande Ch. Monica', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":77,"dateCode":"","friendlyName":"Guirlande Ch. Monica","hardwareVersion":1,"ieeeAddr":"0xa4c1380a68d4f647","manufacturerID":4417,"manufacturerName":"_TZ3000_gjnozsaz","model":"TS011F_plug_1","networkAddress":32468,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0.01,"indicator_mode":"off/on","linkquality":87,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":238}'
error 2024-09-09 21:41:50z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:41:59z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Guirlande Ch. Monica', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":77,"dateCode":"","friendlyName":"Guirlande Ch. Monica","hardwareVersion":1,"ieeeAddr":"0xa4c1380a68d4f647","manufacturerID":4417,"manufacturerName":"_TZ3000_gjnozsaz","model":"TS011F_plug_1","networkAddress":32468,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0.01,"indicator_mode":"off/on","linkquality":87,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":238}'
error 2024-09-09 21:42:04z2m: No converter available for 'get' 'identify' ()
error 2024-09-09 21:42:11z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:42:26z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:42:26z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:42:28z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:42:29z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":123,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":230}'
error 2024-09-09 21:42:58z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 41169 - 1 - 37 - 6 - 11 after 10000ms)'
info 2024-09-09 21:43:11z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lampe meuble cheminée', payload '{"consumer_connected":true,"consumption":120.73715209960938,"current":0,"device":{"applicationVersion":22,"dateCode":"09-10-2019","friendlyName":"Lampe meuble cheminée","hardwareVersion":1,"ieeeAddr":"0x04cf8cdf3c8238bf","manufacturerID":4447,"manufacturerName":"LUMI","model":"SP-EUC01","networkAddress":31384,"powerSource":"Mains (single phase)","stackVersion":2,"type":"Router","zclVersion":3},"device_temperature":22,"energy":120.74,"linkquality":76,"power":0,"power_outage_count":41,"state":"OFF","voltage":233}'
error 2024-09-09 21:43:11z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:44:04z2m: No converter available for 'get' 'identify' ()
error 2024-09-09 21:44:11z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:44:26z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:44:26z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:44:28z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:44:45z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise escalier salon', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":77,"dateCode":"","friendlyName":"Prise escalier salon","hardwareVersion":1,"ieeeAddr":"0xa4c138145286ded9","manufacturerID":4417,"manufacturerName":"_TZ3000_gjnozsaz","model":"TS011F_plug_1","networkAddress":29799,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":1.93,"indicator_mode":"off/on","linkquality":76,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":237}'
info 2024-09-09 21:44:45z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise escalier salon', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":77,"dateCode":"","friendlyName":"Prise escalier salon","hardwareVersion":1,"ieeeAddr":"0xa4c138145286ded9","manufacturerID":4417,"manufacturerName":"_TZ3000_gjnozsaz","model":"TS011F_plug_1","networkAddress":29799,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":1.93,"indicator_mode":"off/on","linkquality":72,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":237}'
error 2024-09-09 21:44:58z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:45:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":61,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":230}'
info 2024-09-09 21:45:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":58,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":230}'
info 2024-09-09 21:45:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":54,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":230}'
info 2024-09-09 21:45:38z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/T°C Ch. Monica', payload '{"battery":57,"device":{"applicationVersion":3,"dateCode":"20161129","friendlyName":"T°C Ch. Monica","hardwareVersion":30,"ieeeAddr":"0x00158d00036b2ec9","manufacturerID":4151,"manufacturerName":"LUMI","model":"WSDCGQ11LM","networkAddress":28620,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"humidity":68.41,"linkquality":116,"power_outage_count":17063,"pressure":931.6,"temperature":19.56,"voltage":2935}'
info 2024-09-09 21:45:44z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":76,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
info 2024-09-09 21:46:03z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":47,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
info 2024-09-09 21:46:03z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":43,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
info 2024-09-09 21:46:04z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":40,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
error 2024-09-09 21:46:04z2m: No converter available for 'get' 'identify' ()
info 2024-09-09 21:46:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Hue tube', payload '{"brightness":254,"color":{"x":0.5732,"y":0.4072},"color_mode":"xy","color_temp":500,"color_temp_startup":500,"device":{"applicationVersion":2,"dateCode":"20210407","friendlyName":"Hue tube","hardwareVersion":0,"ieeeAddr":"0x001788010be54530","manufacturerID":4107,"manufacturerName":"Philips","model":"915005988101","networkAddress":32659,"powerSource":"Mains (single phase)","softwareBuildID":"1.86.6","stackVersion":1,"type":"Router","zclVersion":2},"linkquality":116,"power_on_behavior":"off","state":"OFF","update":{"installed_version":16779268,"latest_version":16783108,"state":"available"}}'
info 2024-09-09 21:46:13z2m: Update available for 'Hue tube'
error 2024-09-09 21:46:26z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:46:26z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:47:11z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:48:05z2m: No converter available for 'get' 'identify' ()
error 2024-09-09 21:48:12z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:48:27z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:48:27z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:48:29z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:48:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Hue Sign SPA', payload '{"brightness":254,"color":{"x":0.6185,"y":0.3688},"color_mode":"xy","device":{"applicationVersion":2,"dateCode":"20190529","friendlyName":"Hue Sign SPA","hardwareVersion":0,"ieeeAddr":"0x001788010923c60f","manufacturerID":4107,"manufacturerName":"Philips","model":"4080248P9","networkAddress":45766,"powerSource":"Mains (single phase)","softwareBuildID":"1.56.7_r29434","stackVersion":1,"type":"Router","zclVersion":2},"linkquality":65,"power_on_behavior":"off","state":"OFF","update":{"installed_version":16779274,"latest_version":16784640,"state":"available"}}'
info 2024-09-09 21:48:58z2m: Update available for 'Hue Sign SPA'
error 2024-09-09 21:49:11z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:50:06z2m: No converter available for 'get' 'identify' ()
info 2024-09-09 21:50:08z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lampe meuble cheminée', payload '{"consumer_connected":true,"consumption":120.73715209960938,"current":0,"device":{"applicationVersion":22,"dateCode":"09-10-2019","friendlyName":"Lampe meuble cheminée","hardwareVersion":1,"ieeeAddr":"0x04cf8cdf3c8238bf","manufacturerID":4447,"manufacturerName":"LUMI","model":"SP-EUC01","networkAddress":31384,"powerSource":"Mains (single phase)","stackVersion":2,"type":"Router","zclVersion":3},"device_temperature":22,"energy":120.74,"linkquality":69,"power":0,"power_outage_count":41,"state":"OFF","voltage":236}'
error 2024-09-09 21:50:12z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:50:27z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:50:27z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:50:29z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
info 2024-09-09 21:50:44z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":65,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
info 2024-09-09 21:50:58z2m: Successfully changed options
info 2024-09-09 21:50:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":false},"status":"ok","transaction":"5wqry-1"}'
info 2024-09-09 21:51:03z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":43,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
info 2024-09-09 21:51:04z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise solaire cellier', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":78,"dateCode":"","friendlyName":"Prise solaire cellier","hardwareVersion":1,"ieeeAddr":"0xa4c138e980cc5be3","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":41169,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":7.48,"indicator_mode":"off/on","linkquality":40,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":227}'
info 2024-09-09 21:51:04z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise SàM-Cuisine', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"device":{"applicationVersion":77,"dateCode":"","friendlyName":"Prise SàM-Cuisine","hardwareVersion":1,"ieeeAddr":"0xa4c138cfd7909ba7","manufacturerID":4417,"manufacturerName":"_TZ3000_gjnozsaz","model":"TS011F_plug_1","networkAddress":21350,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":4.57,"indicator_mode":"off/on","linkquality":54,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":232}'
error 2024-09-09 21:52:05z2m: No converter available for 'get' 'identify' ()
error 2024-09-09 21:52:12z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:52:13z2m: Publish 'get' 'state' to 'Hue Sign Cheminée' failed: 'Error: ZCL command 0x001788010c66987b/11 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:52:21z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:52:27z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:52:27z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:52:29z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:54:05z2m: No converter available for 'get' 'identify' ()
error 2024-09-09 21:54:12z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:54:15z2m: Publish 'get' 'state' to 'Hue Sign Cheminée' failed: 'Error: ZCL command 0x001788010c66987b/11 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:54:21z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
error 2024-09-09 21:54:27z2m: Publish 'get' 'state' to 'Prise SàM-Cuisine 2' failed: 'Error: ZCL command 0xa4c1389907c6a5f5/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:54:28z2m: Publish 'get' 'state' to 'Prise Multiple' failed: 'Error: ZCL command 0xa4c1386845a66057/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
error 2024-09-09 21:54:29z2m: Publish 'set' 'state' to 'Prise solaire cellier' failed: 'Error: ZCL command 0xa4c138e980cc5be3/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
Ludis
