Voici le log de la commande sudo python3 -m pip install --upgrade Pillow
root@jeedom:/# sudo python3 -m pip install --upgrade Pillow
Collecting Pillow
Downloading https://files.pythonhosted.org/packages/4b/83/090146d7871d90a2643d469c319c1d014e41b315ab5cf0f8b4b6a764ef31/Pillow-9.1.0.tar.gz (49.8MB)
100% |████████████████████████████████| 49.8MB 12kB/s
Building wheels for collected packages: Pillow
Running setup.py bdist_wheel for Pillow ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ttbp74k8/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-xefg4k4v --python-tag cp37:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.7
creating build/lib.linux-x86_64-3.7/PIL
copying src/PIL/BdfFontFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/BlpImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/BmpImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ContainerIO.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/CurImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/DcxImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/DdsImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/EpsImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ExifTags.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/FitsImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/FliImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/FontFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/FpxImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/FtexImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/GbrImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/GdImageFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/GifImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/GimpGradientFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/GimpPaletteFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/IcoImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/Image.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageChops.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageCms.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageColor.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageDraw.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageDraw2.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageEnhance.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageFilter.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageFont.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageGrab.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageMath.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageMode.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageMorph.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageOps.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImagePalette.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImagePath.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageQt.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageSequence.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageShow.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageStat.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageTk.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageTransform.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImageWin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/ImtImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/IptcImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/JpegImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/JpegPresets.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/MicImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/MpegImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/MpoImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/MspImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PSDraw.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PaletteFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PalmImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PcdImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PcfFontFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PcxImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PdfImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PdfParser.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PixarImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PngImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PpmImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PsdImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/PyAccess.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/SgiImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/SunImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/TarIO.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/TgaImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/TiffImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/TiffTags.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/WalImageFile.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/WebPImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/WmfImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/XbmImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/XpmImagePlugin.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/__init__.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/__main__.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/_binary.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/_tkinter_finder.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/_util.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/_version.py -> build/lib.linux-x86_64-3.7/PIL
copying src/PIL/features.py -> build/lib.linux-x86_64-3.7/PIL
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
writing requirements to src/Pillow.egg-info/requires.txt
writing top-level names to src/Pillow.egg-info/top_level.txt
reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.clang-format'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.ci'
writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
running build_ext
The headers or library files could not be found for jpeg,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
https://pillow.readthedocs.io/en/latest/installation.html
File "/tmp/pip-install-ttbp74k8/Pillow/setup.py", line 996, in <module>
zip_safe=not (debug_build() or PLATFORM_MINGW),
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.7/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.7/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.7/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/usr/lib/python3/dist-packages/wheel/bdist_wheel.py", line 188, in run
self.run_command('build')
File "/usr/lib/python3.7/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python3.7/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/usr/lib/python3/dist-packages/setuptools/command/build_ext.py", line 78, in run
_build_ext.run(self)
File "/usr/lib/python3.7/distutils/command/build_ext.py", line 340, in run
self.build_extensions()
File "/tmp/pip-install-ttbp74k8/Pillow/setup.py", line 804, in build_extensions
raise RequiredDependencyException(f)
__main__.RequiredDependencyException: jpeg
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "/tmp/pip-install-ttbp74k8/Pillow/setup.py", line 1009, in <module>
raise RequiredDependencyException(msg)
Failed building wheel for Pillow
Running setup.py clean for Pillow
Failed to build Pillow
Installing collected packages: Pillow
Running setup.py install for Pillow ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ttbp74k8/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-emfru86e/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running egg_info
running build_ext
dist.run_commands()
cmd_obj.run()
File "/usr/lib/python3/dist-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/usr/lib/python3.7/distutils/command/install.py", line 589, in run
cmd_obj.run()
cmd_obj.run()
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ttbp74k8/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-emfru86e/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-ttbp74k8/Pillow/
root@jeedom:/#
je lance les dépendances …
Toujours pareil
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Building wheels for collected packages: numpy
Running setup.py bdist_wheel for numpy: started
Running setup.py bdist_wheel for numpy: still running...
