Lancement dependances rxfcom impossible
Suite à plantage disque dur j’ai Reinstallé Debian 11 (Bullseye) et restauré Jeedom, mais impossible de lancer les demons RXFcom et Zigbee
Log RXFcomd
File "/var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py", line 24, in <module>
from jeedomdaemon.base_daemon import BaseDaemon
File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py", line 14, in <module>
from .aio_connector import Publisher, Listener
File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/aio_connector.py", line 8, in <module>
import aiohttp
File "/usr/local/lib/python3.9/dist-packages/aiohttp/__init__.py", line 6, in <module>
from .client import (
File "/usr/local/lib/python3.9/dist-packages/aiohttp/client.py", line 39, in <module>
from . import hdrs, http, payload
File "/usr/local/lib/python3.9/dist-packages/aiohttp/http.py", line 6, in <module>
from .http_exceptions import HttpProcessingError as HttpProcessingError
File "/usr/local/lib/python3.9/dist-packages/aiohttp/http_exceptions.py", line 6, in <module>
from .typedefs import _CIMultiDict
File "/usr/local/lib/python3.9/dist-packages/aiohttp/typedefs.py", line 16, in <module>
from yarl import URL, Query as _Query
ImportError: cannot import name 'Query' from 'yarl' (/usr/local/lib/python3.9/dist-packages/yarl/__init__.py)
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
import aiohttp
Log PlugIn RXFcom
[2024-10-11 10:05:03] ERROR  : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-10-11 10:05:04] INFO  : Lancement démon rfxcomd : python3 /var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py --device /dev/ttyUSB0 --loglevel debug --socketport 55000 --serialrate 38400 --protocol 12,13,18,20,21,22,23 --callback http://127.0.0.1:80/plugins/rfxcom/core/php/jeeRfxcom.php --apikey FJhm4R5B4l4la2uR1BH65PduwHxUVatpNrKK0egkB20OO991wa2gHRGht1hd7CMS --cycle 0.3 --pid /tmp/jeedom/rfxcom/deamon.pid
[2024-10-11 10:05:35] ERROR  : Impossible de lancer le démon RFXcom, vérifiez le log rfxcmd
Sante jeedom
Informations Jeedom
Core : 4.4.18 (master)
DNS Jeedom : non
Plugin : RFXcom
Version : 2024-07-28 01:02:37 (stable)
Statut Démon : Stoppé - (2024-10-11 09:40:04)
Votre post est illisible.
Aucun log entre balises, pas la page santé
Bref. Regardez quelle version de linux vous avez installée.
Lisez le change log des plugins concernés
Rfxcom je laisse à d’autres.
plugin-zigbee est obsolète donc il faut passer à son successeur plugin-z2m
PS: même remarque que Luis, tes logs sont illisibles. Tu dois utiliser le bouton </> Texte préformaté pour leur formatage.merci.
Pour rfxcom j’avais gardé ça dans un coin donné par mips, mais je ne sais pas si c’est toujours d’actualité.
Si plugin RFXCOM ne fonctionne plus :
le workaround actuel est d’installer les dépendances (qui s’installent en réalité correctement) et ensuite d’exécuter cette commande: `sudo python3 -m pip install pip==24.0`;
il faudra de nouveau exécuter cette commande après chaque nouvelle installation de dépendance générant un fichier xxx_packages (=installation effectuée par le core)
le problème se produit, pour l’instant uniquement sous Debian 11 car:
* le package gpg a la version 1.14.0-unknown => aucune autre version n’est disponible
* pip 24.1 crash si un package utilise des numéros de versions non-standard (et le core met systématiquement à jour pip avant de lancer une installation)
Non ce n’est plus d’actualité si core > 4.4.9
  1. on dit « bonjour »
  2. dépendances installées?
